Everything posted by frag
Thanks for all replies. I will keep the fuel level at 2/3 max for the time being. As soon as possible, i will go to the cottage and prepare for a multi days mechanical endevour spiced with bicycle trips to the nearby town (15 km) like I did two summers ago when I replaced clutch, timing belt and a left side burnt exhaust valve. Shade tree mechanic work at it's best. I'll report back.
I can access the fill pipe and even replaced it. It's the tank end of the rubber hose connecting the pipe to the tank I cannot access. I checked the cover behind the rear passenger seat and, like Welder said, it only gives access to a cover on top of the fuel tank (leads to the fuel pump and fuel gage sender). but not to the hose. If no one says otherwise, the only alternative to removing or at least lowering the rear cross member seems to be cutting a hole just to the rear of the fuel pump cover between the cover and the spare wheel well. On the other hand, the rear cross member is pretty much rusted so maybe I could replace it with a good used one and strike two blows with one stone. Anyone ever removed and replaced a rear cross member ? How much of a job is it?
Maybe cutting a new trap over the fill rubber hose would do the trick and be less of a hassle than removing the rear cross member? 96 Legacy, so it's pretty rusted under there. Of course if it's the tank that's leaking i wont be able to bypass removing the crossmember. But I doubt it's the tank itsel leaking cause the leak began just after I yanked at the hose. Opinions?
I just replaced the rusted and leaking fuel filler tube. Repair apparently successfull but... i had to yank a little hard to get the tube out of the rubber hose connecting to the tank. Result : either the hose cracked or is partially dislodged from the tank = anything over 3/4 or a tank produces a leak at the tank end of the hose. Do I have to remove or lower the rear cross member (major work apparently) or do I have access to this hose from the trap at the rear of the back passenger seat? I'm crossing my finger and hope for the best. Thanks in advance for all inputs.
A simple toggle switch on the wire going to the starter's solenoïd. Under the hood. I dont think thieves are going to look for that. My .02$ What I did was a little more (excessively perhaps) complicated. I cut that wire and soldered the ends (with proper extensions) to side by side small bolts going thru a blank switch plastic insert on the dash. Hardly visible. I just have to bridge the two bolts heads with a key or a penny for the starter to be activated when I turn the ignition switch.
You could even ask the shop to machine the outer crown (where the pressure plate bolts on) a few mills more than the rest to give the disk even more grab. That's what was done on mine the last time I replaced the clutch and it works super. The machinist offered that to me. I did'nt know it could be done. If you choose to do that, ask the guy if he has done that before and knows what he is doing. Not a good idea to be a guinea pig. Good luck!
Car Battery
frag replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Or you might make a foray north and buy an Eliminator battery at Canadian Tire. That's what I have and it's a very good battery. Ten years warranty, and around a hundred bucks.
