Everything posted by frag
If someone somewhat intellectually challenged can be permitted to join, for a moment, this learned assembly of geniuses, I would propose that if your misfire never returns while the vac gauge is connected, maybe the problem has to do with the vaccuum connexion you used to connect the gauge. A little too obvious maybe, but I'm trying not to exceed my range.
Looking at the head, top going left to right 3 - 1 - 6 bottom going left to right 5 - 2 - 4 All tightening must follow the usual sequence 1 to 6 1) All to 22 ft-lbs 2) All to 51 3) Loosen all 180° 4) Again 5)1 and 2 (non turbo) to 25 ft-lbs 6) 3,4,5 and 6 (non turbo) to 132 in-lbs (divide by 12 for ft-lbs) 7) all an additionnal 90° 8) Again You gave the bolts 12 times the recommended torque. I'm very surprised the bolts broke. I would have thought an aluminum head would have stripped before breaking a steel bolt of that diameter. Good luck!
I do not have the expertise to really answer your question, but interestingly, I planed to make just that test - with an electronic thermometer - the minute I suspected I had a bad wheel bearing. If it were my car and no other source of heat was present (like dragging brakes for instance) I would conclude that something is amiss with the bearing.
Another possibility worth exploring. Since the only thing done to the car recently is timing belt and if the noise seems to come from the front of the engine (timing belt cover), maybe the tensionner is bad (what method did you use to compress it ?). A bad tensionner is known to produce sounds comparable to what you describe. Just another possibility.
Hey, Grossgary, you're making all sorts of assumptions here. I only asked a question and replied to one of your sentence in a humorous way. Nowhere did I wrote or even imply " that this kind of stuff will blow your engine off". You're also implying that maybe "intelligent discussion" is not my style. I find that insulting and uncalled for. You should reread the thread. Maybe you're confusing me with another poster. Like I wrote in my last post, i'm only anxious to know if my well used (old) pulley should be replaced as preventive maintenance and if so with same or something else. Cool down man!
In the case of my 96 2.2 L MT, IIRC, the throw out or release bearing could go only one way. Maybe cause of the way the spring clips are connected to it... (?) Anyway, since this bearing fit on a round shaft, if your's can go both ways, the angle relative to the fork and relative to the pressure plate will be exactly the same. My two...
I fill the filter by hand when doing an oil change, but I could use your method easily. My antitheft system cuts out ignition and fuel delivery. So if I dont desactivate it, I can turn the engine over as long as I want without the engine starting. Is'nt that also possible with most other kiinds of antitheft systems?
Dual port
frag replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I should have written: "my" 96 2.2L engine with MT does not have EGR. Sorry for the faulty generalisation. -
Dual port
Also no EGR on the 96 MY (1996 Brighton, MT, 2.2 L). FYI -
Hypermiling
frag replied to FSRBIKER's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Imagine what 5.60 a gallon can do... (price of fuel here in Montreal)
