Hey Guys!
I have a problem with my 86 brat Ea81 1.8L. IT WILL NOT START. I have spark, I have compression, I have good fuel supply, I have good air. Heres the deal:
Car has always had an irregular idle. I installed new fuel and vac lines with a reman carb. Start engine, it runs fine, but i still had an odd idle. I had a reman dist. assembly (with new cap and rotor) and new high end wire set i then installed ( and yes i was careful to put the dist back exactly as it was). car would not start. Checked and rechecked everything and could not find any reason for this not to work. I noticed the ing. coil looked like it has been in the car for over 200,000 miles, so i when and got a new one and installed it, still no start. Then we decied to reinstall the old dist and wire set as the car was at least running with the old config. Still the car will not start. So we decided to re-time the dist. found dead center and aligned the rotor to #1 cycle. Still wont start. we set the timing back to dead center, HOWEVER the rotor was pointed 180* off,so we reset the rotor again, and the car did not start, and again found the rotor to be off 180*. No matter how you reset the timing, the rotor is always 180* off. What the heck is going on!!!. i would like to think that the timing gears are fine as the engine came from CCR about 1.5 years ago. PLEASE HELP!!!!!!!!! thanks BlueRu
