legacyak
Everything posted by legacyak
Living through the wonderful Northern Indiana winters full of lake effect snow really makes me appreciate my 00 OBW. This morning was pretty slick and I slid a little bit at a stop sign and my ABS light came on. It stayed on for a while, but once I restarted my car up again it was gone and has stayed off. Could this be normal? I also have a torn rack and pinion boot that I noticed the other week that I need to get fixed. Could that have any effect on it?
I am going to replace the drivers side CV joint on my 00 Outback this weekend. Last year I replaced the passenger side one and the pinch bolt that holds the steering knuckle to the ball joint was an absolute **** to get off. When the car was built they did not put anti-seize or anything on the bolts so they are exteremly easy to strip and can be a huge problem to get out. Anybody else have similar experiences? I've been spraying it down with PB blast for the past couple of days in hopes that it may make it easier. Any other ideas?
Hi Drew. Welcome to the Subaru world! You will be very happy! The things to definitely look out for on the years and models you specified would be head gasket repairs and timing belt changes. The 2.5 is a good engine, but unfortunately the head gaskets are the most notorious enemies for this engine. Check to see if the head gaskets have been replaced. Also make SURE if you find a Sub with over 100,000 miles the timing belt has been replaced. If you can find a Subaru within those years that has not had head gaskets replaced, I would haggle the seller down and use the savings to replace the head gaskets and various other components. You can easily find a good mechanic and OEM parts for under 1,500 to do the job. Or you can jump in and do the job yourself! Changing timing belts every 100k and regular oil changes are the keys to keeping a Subaru long running.
I'm going to replace the front oxygen sensor in my 00 OBW manual transmission. I just got the part from 1stsubaru and checked the OEM number and it checks out fine. However I got digging in my garage and forgot a couple years ago I bought an genuine subaru o2 sensor on ebay. I think it is the rear o2 sensor. The part number is 22791AA00A. Will this part work at all for my car?
Ok, last week had my head gaskets,clutch, and other oil seals done in my 00 OBW. I've driven about 150 miles since I got it back and have been very pleased. Not leaking anything great performance. Tonight my CEL came on. No difference in performance sounds great, drives great. I've got 160,000 on the car and the oxygen sensors has never been replaced. I just changed the knock sensor last summer. Is it most likely the front oxygen sensor? I'm having it checked tommarow.
