Everything posted by zukiru
Trying to picture fender mirrors on the 86 xt.... I love them but I am but sure it would suit the retro-futuristic xt. This Wagon will be awesome, and I'm not really a wagon lover!
Damn EA82 Timing belt tensioner
zukiru replied to 81EA81's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Another vote here for trying a longer bolt. Working fine here. Blow out the bolt hole to be sure its clean. Mybolt was too long and I need a couple washers. -
shock tower rust, bolt head broken wtf?
zukiru replied to c0r3f1ght3r's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Or he's got a low rust car like my dl. -
I marked that vid to my watch later list. Somebody post a link to the miles fox videos? Please!
EA-82 Adjustable Cam Sprockets
zukiru replied to Quidam's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Do you really need the bushings? I had adj cam gears on my old zx2 and the bolts held it in place just fine. Really all it needs is the slotted holes, right? (and the index marks of course.) :edit: after reading your other thread I got my answer. -
Need a little bit of help on this one
zukiru replied to Subaruby Doo!'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sorry for the off topic, but subaruby doo has to be my favorite screen name yet. -
Will you help a subaru.
zukiru replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
cute. lol -
ooh great idea! you guys know where to get a high rev cam? subscribed. -
finding this interesting. I had no idea you could do so much to a disty. subscribed.
4 lug rim options, how to get my tires bigger
Ooh columbus. That's almost local. -
thanks fox but I have it wired right... I haven't at it in afew days.. I have something else to drive and this probably lead me to an EJ....
I actually also tried tuning the engine over by jumping the starter in the engine bay. this should negate the whole spark while cranking scenario. at least I think. I have not checked the ground to the engine....
tried 3...
yeah I checked that first,.. and the rotor... turns out I have the kind without a screw.
coil gets power but no spark at the coil either. I get volts at the coil but no spark...
checked all links and fuses. ecu light comes on with key so it is powering up.
changed coil disty and ignition relay coil gets power 86 XT DL what am I missing?
TBS-(exist for subarus?)
zukiru replied to hardtail_pride's topic in Old Gen.: 80's GL/DL/XT/Loyales...
there's actually to many variables. one would have too build an use several models to find something that worked right. not worth it imho .73 inches might be the magic number. it might be an inch even... you might LOSE power AND economy.. nobody here wants that! unless it's the same Ej22 and exact style spacer that Chux used experience from someone you trust is worth a lot too. -
it's a lot of effort for an Ea motor considering nobody already makes one. since we do have a coolant filled intake a phenolic spacer might be worth something... it's a TBi ? right? so be careful you don't hit the hood. going to mpfi and a spider intake would net you HP and better fuel comsumption. (buy you'd have work swapping an EJ) -
89 GL10 low power, stumbles under boost.
zukiru replied to crazy_squirrels's topic in Old Gen.: 80's GL/DL/XT/Loyales...
good! if that doesn't work check all your injector clips for corrosion.
