zukiru
Everything posted by zukiru
  1. my uncle taught me a little trick... run a brown paper bag (or peice of brown paper bag) through the ring and pinion if every thing is right it should not eat the bag up but it should run through tightly. just a cheap test so you don't eat it right up. he sets up Chevy rears on the cheap for offroading.
  2. check the dash trim. gonna put the mirrors on the new brat?
  3. yeah don't then... I figured it might be an existing code I couldn't tell with that car if the dash light should have been coming on or not and it did come on in the 86 DL cause well it wasn't a turbo car. you checked for spark you checked the timing so all that's really left is fuel... and that's easy to check just like was said above.
  4. for the squeal check the EGR mine sounded like blowing on a blade of grass.
  5. pics of the Scirrocco?
  6. if that's the ECU I sent you that could very well be an old code. that car had a fuse box corrosion issue and we had the igniton coil jumpered to the battery and the starter was engaged from the engine bay. it was a basket case but the computer worked in my other car.
  7. look here! http://www.ultimatesubaru.org/forum/showthread.php?t=98064
  8. this is just sick! I got into this back when we just called it "black out" but yeah ... the old soobies look hot blacked out... there's a wagon on here that's be lined on bottom and camo on top but the bedliner is really sexy... I may find that and post it up for ya.
  9. yep they work great! and look good too...
  10. yeah I'm going to have this problem... the cable is all the way tight on my fairly new (newer than his) clutch... I can't complain to the shop cause they did it for free... washed and resurfaced.. well half resurfaced.
  11. those are very cool rides! wish they were available here... guess I'll import one when they are 25 years old...
  12. do the thing in red!!! that's how my first Xt was rigged up... drove it 1800 miles home that way,
  13. impreza dash in xt... this is likely the GC dash but any thing can be done if you want it badly enough.
  14. I thought DHL went under? the few people I know from here that worked there lost their jobs.
  15. those use a photo-electric eye and light through a disk with slots. the assembly can be cleaned.
  16. what are those wheels? I like 'em sent you a friend request too.
  17. I don't have the schematic but that short you are talking about could be the culprit as the radio will dim and brighten with the running lamps. also wiggle the rocker switch on top of the column you can have it sitting just right and they will not come on.
  18. looks a little more sleek! I love it! more closely resembles the xt now and makes me think about getting some RX bodykit pieces for my Winona.
  19. and he never posts or anything. I need to move... lol
