zukiru
Everything posted by zukiru
  1. did you buy a running RX out of Atlanta?
  2. ^^+1 id you want 300 or better HP you need to build an EJ22t. (and you may want to put in a turbo tranny too.)
  3. all that prettying the hood up just so you can cut a giant T in it for Turbone... you egomaniac!
  4. this is a joke... I feel sure of it.. I mean who misspells their home town?
  5. hmm maybe I should check that I was really leaning towards my TPS... my wires are from my old Starion but the were fresh and not cheap so I used them on the Subie. maybe I just need some new wires (that aren't all over the engine bay)
  6. any of these legacies have distributors on them?
  7. since it's out there. I am highly interested in your control arms.. then all I need to find are 2wd XT6 rear hubs and I'm in.
  8. the only internal difference between the impreza tranny I opened and the XT tranny I opened was the size of the shaft right at the point where the speed driven gear is. it was thicker there on the impreza. impreza also uses the smaller shaft and smaller clutches. (and why "upgrade" the tranny for the same clutch?) truth be told either way I agree with you that any tranny that allows for a bigger clutch is the best option. sadly enough the 93 impreza clutch disk is identical to the one in my 85 xt non turbo clutchkit.
  9. oooh glow in the dark vinyl anyway... what I came by to ask is your hatch rattle canned, or rolled, with rustoleum?
  10. In my honest opinion if you can get the xt6 for 200 do it... put a timing belt on it the 2.7 flat six is very nice that would make a very fun rig for you.
  11. FWD Impreza 1.8 trannys are no different internally. 2.2 FWD imprezas might be different not sure... the legacy 2wd tranny will accept the 4wd clutches opening the clutch options back up. (you will need turbo axles for this) and it's what kingbobdole has in his EZ30 XT6
  12. your lift kit looks great! where are you getting those little cubes? or is that a secret? I have no need or want for a lift but the ingenuity impresses me!
  13. very interested in the affordable alternative... I hate the idea of xt6s parted for five lug swaps on wagons.. lol
  14. actually you'd be fine with a FWD car and a big engine. you'll need to do a five lug swap to get some better rubber on the car though...
  15. yeah but in stead of drilling hole where they aren't any you widen the 10 mm holes out to 12 and you're done... the ATV lugs are 10 mm.. as far as tires you could use car or truck tiresm, right? I don't see any reason you can't?
  16. run a sweep test on the tps. (analog mutli meter) I had a similar issue with a bad TPS on a different turbo car.
