Everything posted by zukiru
rear tortion bar on EA81...how strong is it?
zukiru replied to hatchsub's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the torsion beam does the job of a sway bar... what you want is to strengthen the beam between the arms.. does it unbolt? so you can bolt in something heavier? -
anybody played with the clock spring ring??
cool.... those rims look great for 200 plus ship!
(Fixed)Need HELP! Fuel Pump not kicking in
zukiru replied to SubaRube's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check all the fuses and the fusible links. -
god, found this on search..... and had to add If you can't Duck it, you know the rest!
Need some help... one cylinder low compression
zukiru replied to misledxcracker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
broken timing belts make a whirring sound also. FYI when you turn the key have someone check if the cranks turns and pull the disty cap and see if the disty turns this should help with your answer. -
Debate: mpfi vs carbi in ej'ed older vehicles
zukiru replied to Yo'J's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I need help with that part, lol if you can help me figure what to trim I'd like to do an EJ swap ,,, but I am going to be so lost...... mechanical I handle -
ha anybody got a third light video? you know the center one? can't seem to find any.
EA82T Fan Modifications....?
zukiru replied to EvilDead's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you have the ea81 fan run all the time? or is it set for a certain temperature? -
don't do it to your only one like this works too
XT / XT6 site is...back up again
zukiru replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had lunch and it was back! -
I like this idea of running an EJ on the existing fuel setup... -
http://xt6.proboards50.com/ we are also kind of meeting up here again. thanks for the update Gary! -
My Coupes Journey!! Is Over..He is in CT!!
zukiru replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I feel alone here too. time will pass and LB will be there! -
Where do I get these? like last week, lol
pull and save primerblack xt
zukiru replied to spokanesoob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sad....... -
loyale water pump need help!
zukiru replied to NewDriverOlderRide's topic in Old Gen.: 80's GL/DL/XT/Loyales...
oooh Then I'll be watching you....... lol -
I'm with you on this my uncle has a junk yard and I never see pugs.. I'm going to put the H wheels on off my parts car. but something has to give! the xt6 rear parts needed for 5 lug are rarer here than the pugs. (in fact my XT and the only other 4 or so i've seen in the area are all DLs)
Please don't .......
When do you change your belts?
zukiru replied to MTSuby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
change 'em! you want to do it on your terms, not the car's! -
Should I go for this? UPDATE: I went for it!!!
zukiru replied to Subaru_dude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I see 80s honduhs here all the time. just today I saw 2 89? preludes (could have been 90 91) almost no subies round here though...... -
you scare me..... and I'm from alabama!
+eleventy billion........ must have the book! the xt6 the sierra and the rs200 all on the same page!!!!!!!!!
that, my friend is a tasty old subie!
