junkets
Everything posted by junkets
  1. I have inherited a Sub that sat for a long time and have tried to fix it. I have failed. Any suggestions would be welcome. Below are some helpful facts. Thanks. SYMPTOMS Car will not idle. Cranks and will run if reved up and down, but dies even if peddle is held to the floor. Idled high once for a few minutes, but would not run after restart. (The choke probably kept it running this one time.) SUSPICIONS Carburetor is the problem. Old gas may also be a/the problem. Vacuum hoses are causing a leak. HISTORY Car sat for several years with a blown head gasket. Engine would crank and milky fluid would shoot from the radiator. Engine replace with engine from a 1989 Sedan with fuel injection and 130,000 miles. Could not keep the fuel injection because of electrical differences. (Lights had constant power on one and constant ground on the other.) Engine donor 1989 car was running but wrecked and had a cracked valve cover. Valve cover was taken from original engine but is leaking at the bottom of the gasket. Installed a new clutch at the same time as engine swap. Have never had the chance to test. Rebuilt carburetor at the same time as engine swap. I can't remember which of the two carburetors used on this model that it is. I can’t find any markings that have helped identify the carburetor. Car has never run since the engine swap/carburetor rebuild/clutch replacement. The gas is a mix of old and new but I did treat the gas with some "gas renewer". At this it's all old gas and probably should be drained. It does appear not to be a fuel pump problem though, as the carburetor gets gas. The vacuum hoses are a jumbled disconnected mess. This is the way that my dad left them and I do not know enough to sort them out.
