42
Everything posted by carfreak85
I can see the clips on the back side of the bumper but I only have two hands and there are somewhere around 15 clips that all feel like they'd need to be released at the same time for the skin to peel away. Hard to get that many hands in one place during a pandemic! Hoping the early EA82 FSM provides some hints.
86 brat cutting out on acceleration
carfreak85 replied to J.T.R's topic in Old Gen.: 80's GL/DL/XT/Loyales...
New carb? Used carb? Did you replace the fuel filter at the same time? Sounds like the accelerator pump isn't doing it's job. -
Ahhhh, FPM, not FSM... I've got an 85-90 parts catalog, same illustration. Looking for the how-to instructions from the 85-86 FSM. I do appreciate the help though Paul, you're a gentleman and a scholar.
Stock 2-Core Radiator (?)
carfreak85 replied to MSSLGECKO's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I bought mine from MAPerformance during a Black Friday sale, but the best price appears to be at Sohi Performance now, free shipping too: http://sohiperformance.com/i-1974983.aspx It will require some modification, which was pretty scary with a brand new part, but it does fit pretty nicely. I'm not done installing it yet, but @Nico has and can provide more insight. If you have Instagram you can see some of the modifications on my page: @templeoffuji -
1985 Subaru Brat vibration at high speeds
carfreak85 replied to Zarengo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Last visited June 2019... -
The radiator out of a BRZ has a core that is pretty much perfect for the EA82 chassis, I've modified an aftermarket Koyo radiator in my '87. @Nico has the same radiator with a slightly different mounting system. Not sure about the EA81s, I think there is an outfit in Australia that has large aftermarket aluminum radiators, but the shipping to the states costs more than the radiator. -
L series touring wagon roof racks
carfreak85 replied to Raynman1989's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That is the style of mount that will fit rain gutters, unless you're willing to remove the trim I don't know how else you would mount a roof rack without attaching it directly to the sheet metal? -
They use normal gutter clamps, I've used Yakima 1A mounts in the past with no problem. -
Water leak in hatch area - 93 Loyale
carfreak85 replied to Scoby4wd's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I constantly battle water intrusion on my three EA82 3-doors. While they have several leak paths compared to your wagon, my first inclination would be to check your taillamp gaskets, those are pretty easy to inspect. If perished/flattened reconstruct them out of closed-cell foam. Make sure any drain holes aren't plugged in those cavities. Does your wagon have a sunroof? Check that the rear drain tubes aren't leaking or disconnected. If you're really unlucky you won't have found the leak yet and you'll need to get drastic. Best way to find leaks is with two people using high volume, low pressure water, like from a garden hose on full flow. Remove the interior plastic panels in the hatch area and sit yourself inside with the tailgate closed. Have your helper direct the water onto various areas like the taillamps, window gaskets, hatch seal, body panel seams. Inside the vehicle you'll want to be watching for any little drips or rivers of water getting into the interior. -
I've got an idea I want to investigate, but was wondering if anyone had any experience removing the bumper skin from the early EA82 front or rear bumpers. There are brackets bolted in the corners little clips on the skin that match up to cutouts on the bumper frame, but I would need 12 arms to compress all the clips at once. My only EA82 FSM is for the 1987 model year, so not helpful on the early bumpers. Thanks!
Any updates on the '87 evaporator core?
used Gen 1 '76-'78 4WD wagon parts in ID
carfreak85 replied to NLAParts's topic in Historic Subaru Forum: 50's thru 70's
User has not logged in since creating this post... -
Sway bar end link bushings
Could create the rounded section with a sanding drum. -
BRATs never got a 4-speed automatic (4EAT), only the 3AT.
4WD XT Coupe Air Struts
carfreak85 replied to SiriusBlack's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Convert to 5-lug and use the air suspension designed for the late model Imprezas and Legacys. -
SuperPro, or a rubber replacement? -
EJ22 Brat Swap with 5spd dr questions
carfreak85 replied to Skubaskott's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's what they're traditionally called down under, in N.A. we just call them the "EA81" chassis. -
What color are the interior parts? Also, do you know what year and the mileage of the 5-speed transmission? Thank you!
Sent you a message @Crazyeights
Central locking Differential
carfreak85 replied to Glfanboy9967's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ugh, I'm dealing with this same issue myself, but I haven't finished diagnosing the problem due to other projects. Start here, these threads have been helpful so far: https://www.ultimatesubaru.org/forum/topic/157979-4wd-diff-lock-not-engaging/ https://www.ultimatesubaru.org/forum/topic/169810-getting-to-know-my-xt6-1st-suuub/
