carfreak85
    41
Everything posted by carfreak85
  1. What about cutting the strut top mount off an impreza and weld it to the tops of the coupe's? Maybe add some extra material to keep them from deforming under extreme use? I wouldn't trust myself to do it yet, but I plan to and although it sounds like a big mod, it will allow the use of newer, aftermarket parts in an otherwise useless suspension design. I also plan on installing modified control arms using Phizinza's method: http://www.ultimatesubaru.org/forum/showthread.php?t=69643 Or the BattleVersion mod at the bottom of the same thread. This would provide many brake, wheelbearing, steering and suspension part options from XT6 to STi. The rear suspension is adequet, but adding a rear anti-roll bar would be a welcome modification. An Ea82 bar needs minor tweaking and some custom mounts to fit our cars. I plan to re-clock the trailing arms to lower the rear end as well, though stock would be much better for a rally machine. Throw on some rear discs and 200SX rear calipers or go with bolt on XT6 brake parts to start a five lug swap. I think that with some work on the intake and exhaust systems on the EA81T, you can have a decent engine. After that, a larger turbo and new valvetrain parts to take advantage of the higher rpm power the new turbo would provide. Megasquirt 'n' Spark for engine control and maybe see if higher comp pistons can survive on a better constructed engine. Other than that; a cage, welded up sun roof (Like so many turbos had) and some decent seats and harnesses and you'd have a sweet little gravel blaster. Johnnyboy, do you have any high res photos of your car? I love gen 2 hardtops and a gen 1 RX is the sweetest of 'em all!!
  2. All you need to do is remove those four bolts and replace the rubber coupler. Thats about it...
  3. I haven't driven cross country, but I have driven to Hood River. Expect about 21 MPG with a 5 speed and a fully loaded car. Overheating was an issure for me becuase I had no 02 sensor, but leaving the heat on keep it out of the red.
  4. Welcome to the EA81T clan! Let us know if you have any problems with the car, we're happy to help!
  5. This topic was brought up just a month or so ago. Use the search function to find what mods will work for you.
  6. Not to toot his own horn but, BEEP BEEP!! Just kidding Ken, we love you!
  7. Turns out its a low battery and a bad CD player. Charged the battery, exchanged the player and all is well. Thanks guys!
  8. I stashed those there for a future soob lover to find. I love collecting rare alloys, but I'm done with that. Trying to sell my stockpile.
  9. Dude, that is just a regular EA81T car. Multiport injection and such. I know because I have the turbo, injectors, windshield, axle, digidash and grill hardware off that car. What makes you think it was SPFI?!?
  10. I just installed a CD player in my girlfirend's Forester. While she was driving home the volume required to hear the audio increased, and when she came back for me to look at it, the car refused to start. The starter clicks like its binding. Could this be due to me mis wiring the stereo? Sounds far fetched to me, but any input would help since the car is stranded in my driveway!
  11. Its not that hard of a mod, just time consuming. Basically, you just have to cut along the diagnols around the light cover and then trim the backside of the grill to clear the rest of the cover throughout its movement.
  12. Uhhhhh, don't remind me. I've only scratched the surface of that death mud...
  13. Just a thought for the next time you pull a carb, mark the hoses and their barbs numerically, so when you put it back on, you know right where everything goes. Can't help you otherwise.
  14. Both EA81 and EA82 engines have horrific port geometry, and unless you port the $#!T out of them or cast new heads, you will have a hard time making power without forced induction.
  15. A white EA81 wagon with an auto just showed up, but nothing else for a long time...
  16. My wagon needs its exhaust reconnected, clutch replaced and an alignment. When all that is fixed, I'll have numbers for you.
  17. Check your grounds. I find that when odd stuff starts happening to your electronics, loose, corroded or missing grounds can usually be the culprit.
  18. I would assume that a shock for a Jeep TJ designed for a 6 inch lift would be what you're looking for. Try an online 4wheeler dealer.
  19. Are those prices new or used? Subaru = $75 for the bolt on setup
  20. Do you have a higher resolution copy of that magazine article? NOTE TO MODS!!! We should add it to the archive!!
  21. I pulled a seat with an arm rest, not a pass though, from an 84 GL-10 coupe. Couldn't tell you about the sedans, since I don't seem them very often.
  22. Do a Google search for Possum Bourne. He started the Subaru/Rally pehnominon, starting with RXs.
