41
Everything posted by carfreak85
Wow, its so..... small.
"Desert Fox" Edition Hatch Decals???
carfreak85 replied to 75subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
+1 -
What about cutting the strut top mount off an impreza and weld it to the tops of the coupe's? Maybe add some extra material to keep them from deforming under extreme use? I wouldn't trust myself to do it yet, but I plan to and although it sounds like a big mod, it will allow the use of newer, aftermarket parts in an otherwise useless suspension design. I also plan on installing modified control arms using Phizinza's method: http://www.ultimatesubaru.org/forum/showthread.php?t=69643 Or the BattleVersion mod at the bottom of the same thread. This would provide many brake, wheelbearing, steering and suspension part options from XT6 to STi. The rear suspension is adequet, but adding a rear anti-roll bar would be a welcome modification. An Ea82 bar needs minor tweaking and some custom mounts to fit our cars. I plan to re-clock the trailing arms to lower the rear end as well, though stock would be much better for a rally machine. Throw on some rear discs and 200SX rear calipers or go with bolt on XT6 brake parts to start a five lug swap. I think that with some work on the intake and exhaust systems on the EA81T, you can have a decent engine. After that, a larger turbo and new valvetrain parts to take advantage of the higher rpm power the new turbo would provide. Megasquirt 'n' Spark for engine control and maybe see if higher comp pistons can survive on a better constructed engine. Other than that; a cage, welded up sun roof (Like so many turbos had) and some decent seats and harnesses and you'd have a sweet little gravel blaster. Johnnyboy, do you have any high res photos of your car? I love gen 2 hardtops and a gen 1 RX is the sweetest of 'em all!!
and the fun just keeps on coming *steering issue*
carfreak85 replied to crazy D's topic in Old Gen.: 80's GL/DL/XT/Loyales...
All you need to do is remove those four bolts and replace the rubber coupler. Thats about it... -
Anyone else go cross country with an EA81T?
carfreak85 replied to mikeshoup's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I haven't driven cross country, but I have driven to Hood River. Expect about 21 MPG with a 5 speed and a fully loaded car. Overheating was an issure for me becuase I had no 02 sensor, but leaving the heat on keep it out of the red. -
Just bought an 84 Turbo BRAT
carfreak85 replied to Scott F's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Welcome to the EA81T clan! Let us know if you have any problems with the car, we're happy to help! -
IMMEDIATE ATTENTION NEEDED, ORV opinion poll-time sensitive
carfreak85 replied to chazmataz's topic in Off Road
Done! -
Not to toot his own horn but, BEEP BEEP!! Just kidding Ken, we love you!
PAP update...'83 Turbo coupe at Lynnwood
carfreak85 replied to edrach's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I stashed those there for a future soob lover to find. I love collecting rare alloys, but I'm done with that. Trying to sell my stockpile. -
Dude, that is just a regular EA81T car. Multiport injection and such. I know because I have the turbo, injectors, windshield, axle, digidash and grill hardware off that car. What makes you think it was SPFI?!?
I just installed a CD player in my girlfirend's Forester. While she was driving home the volume required to hear the audio increased, and when she came back for me to look at it, the car refused to start. The starter clicks like its binding. Could this be due to me mis wiring the stereo? Sounds far fetched to me, but any input would help since the car is stranded in my driveway!
Its not that hard of a mod, just time consuming. Basically, you just have to cut along the diagnols around the light cover and then trim the backside of the grill to clear the rest of the cover throughout its movement.
Uhhhhh, don't remind me. I've only scratched the surface of that death mud...
ok now im just getting pissed
Just a thought for the next time you pull a carb, mark the hoses and their barbs numerically, so when you put it back on, you know right where everything goes. Can't help you otherwise. -
Why isn't an EA82 a raging "hot rod"?
carfreak85 replied to bgd73's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Both EA81 and EA82 engines have horrific port geometry, and unless you port the $#!T out of them or cast new heads, you will have a hard time making power without forced induction. -
A white EA81 wagon with an auto just showed up, but nothing else for a long time...
ea81t owners: whats your oil pressure like?
carfreak85 replied to Ross's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My wagon needs its exhaust reconnected, clutch replaced and an alignment. When all that is fixed, I'll have numbers for you. -
1984 Ea81t electrical question
carfreak85 replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check your grounds. I find that when odd stuff starts happening to your electronics, loose, corroded or missing grounds can usually be the culprit. -
I would assume that a shock for a Jeep TJ designed for a 6 inch lift would be what you're looking for. Try an online 4wheeler dealer.
Are those prices new or used? Subaru = $75 for the bolt on setup
Do you have a higher resolution copy of that magazine article? NOTE TO MODS!!! We should add it to the archive!!
EA81 coupe/sedan pass-through back seat?
I pulled a seat with an arm rest, not a pass though, from an 84 GL-10 coupe. Couldn't tell you about the sedans, since I don't seem them very often. -
Do a Google search for Possum Bourne. He started the Subaru/Rally pehnominon, starting with RXs.
