42
Everything posted by carfreak85
That's always an option, but I have to imagine this same socket, or similar was used on at least one other model by at least one other manufacturer... Just our luck and it'll be from a Peugeot 504...
I was wondering if anyone had found a direct-replacement for the parking lamp bulb socket on the EA82 chassis. Nearly every one I've laid eyes on is brittle, broken and turning to dust. They're getting to the point where they don't even hold the bulb inside the lamp properly and I've resorted to taping the socket to the back side of the lamp. I haven't pulled up the OEM part number yet (assuming it's obsolete, based on the failure rate I'm seeing in the field) and RockAuto doesn't list a direct replacement. So, what have you folks been doing about these bulb sockets?
The quick and dirty answer would be Harbor Freight, but honestly, I just use my trickle charger and swap batteries around between cars if one is completely flat, so I'm not much help, sorry.
So my rear defrost wasn’t working.
carfreak85 replied to Unknownjeremiah's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This forum is full of penny pinchers! (Sorry, couldn't resist...) -
84 gl turbo wagon running rich
carfreak85 replied to oczuk32's topic in Old Gen.: 80's GL/DL/XT/Loyales...
14.7 (or the stoichiometric ratio for a gasoline engine) is fine for cruising in any gasoline engine. It's under power where a turbo engine will typically want a more rich air/fuel ratio than a normally asperated engine, and Subarus in particular have a pretty poor BSFC, so they tend to run even more rich than your typical turbo tuner car. -
'87 RX - No Gauge Illumination?
carfreak85 replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
During the process of removing the gauge binnacle to inspect the dimmer switch connection I discovered that my repair to the HVAC control module lower mounting point has failed, again... Looks like I get to refine my repair process, this will be "Field Repair v4.0" of the HVAC control module mounting points. -
EA82T Coolant leak on driver side
carfreak85 replied to Leebo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Water pump sprung a leak, perhaps? -
Closing the loop on this, the dimmer switch was unplugged. I feel stupid... -
You can buy shorter boots from NGK and swap them, I did that for the COP conversion on my EJ20G.
front wheel knocking and grinding
carfreak85 replied to czaray's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Like this one? I'm not finding ton of options outside of SKF. Have looked on Amazon, Grainger, McMaster-Carr, etc. Nobody has a great description. (Spoon feed me, please, oh Mighty General of Disorder ) -
@GeneralDisorder Do you have a particular brand or model of 7207 that you prefer? Looks like there are 1,000,001+ options out there, just not sure what features/specs are must-haves, nice-to-haves, etc. -
You can probably disassemble that switch and clean up the contacts. I think you can still get them on RockAuto... -
Have you checked that the fuel return line to the tank blows clear? -
Alright, good to know. I was going to run the Mobil 1 Mobilith SHC 220 I had leftover from doing my WRX wheel bearings (The Mobilith is safe for nylon bearing cages). Is there a reason you prefer the Amsoil waterproof grease over their other grease applications? -
I may have slapped and tapped, but not enough to remember. I think I'll pull the binnacle off today to check that the dimmer switch is indeed plugged in. Yes, dimmer is the thumbwheel-style switch. -
The dimmer switch setting does nothing. I'll have to double check that it's plugged in, but I'm pretty sure it is. -
Test that pressure regulator, sounds like you're dumping fuel into the engine. -
@GeneralDisorder You still stand by this recommendation, or have things changed in the last 9 years? Are the 7207's worth the extra effort, or are the 6207-2RS-C3's the way to go? I'm a little concerned that the grease in the C3's might not be as robust as the stuff I already have used for my WRX wheel bearings. -
First time driving the new RX in the dark and surprise, surprise, the gauges don't light up! Anyone have any idea why my gauge cluster would be totally dark? The gauges still work and the telltales light up for things like low range, but there is zero back lighting in the gauge cluster with the parking lamps or headlamps on. I'm not near the car at the moment, but do these lamps share a fuse with something else? Run on their own fuse? I did a search and came up with lots of results for swapping in LED bulbs. The cluster has never been removed on my watch but I did just repair the HVAC module mounts on the gauge binnacle and didn't notice any signs of suspicious activity.
These little VFs seem to hold up pretty well, I would be surprised if the seals are blown out on this car in particular. I would first look for any vacuum leaks. Inspect all the rubber hoses, hose clamps, etc. Make sure the inlet pipe from the airbox to the turbo isn't severely cracked (it was rubber once, now more like brittle plastic). Put a long screwdriver on each injector and put your ear on the other end, making sure you hear each one clicking. I forgot to take photos of the troubleshooting tree, but I'm making a note to do it today. -
Have you found the turbo supplement yet? I can try to take some photos of the troubleshooting section this evening, if I remember. -
I didn't know you sold the turbo coupe...
90 whp out of an EA81 is still pretty damn good! If a big valve made 84 chp and you figure in driveline losses a stock EA81 is putting out 63-71 whp. Given the breathing issues these engines have I'd say you're doing well, with some room still to grow that output!
Ea81 transmission swap into a Ea82
carfreak85 replied to DominicLeeWadkins's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Fixed it for you... -
I don't know how your vehicle inspectors could have an issue with simply replicating the exact same style anti-roll bar mounts that Subaru themselves used. It's literally square tubing with a slot cut and hole drilled with a captive nut welded behind the hole...
