carfreak85
    41
Everything posted by carfreak85
  1. Have you tried cleaning the MAF? I would only buy an OEM MAF sensor, the aftermarket ones just aren't worth the savings, but then again, I pretty much only have turbo'd Subarus.
  2. Any rust or body damage to the vehicle? (Can't view CL at work, hahahaha).
  3. I concur with czny. The reservoir is unique to the EA81T.
  4. Does anyone know the angle/size of the reamer you would use to modify an EA82 control arm to fit an EJ spindle? I've been searching and searching but I must have missed it...
  5. Ahhhh, yeah, it's a washer/bracket combo part, probably still available from the dealer. EA shifters just suck, even with delrin bushings.
  6. Picture of the spring, to jog my memory?
  7. Silicone has high permeability, I'm not surprised you're seeing the sweating.
  8. Jiggs, you ready for a photo shoot of our fraternal twins?
  9. While GD is correct in all his statements, you CAN turbocharge this engine and DD this car, but you'd better have a backup vehicle ready to go. No aftermarket of any substance exists, NOS parts supplies are quickly drying up and even the supply of parts cars is getting thin. The longterm method of keeping these cars on the road is an EJ-swap + 5-lug swap.
  10. There is no such thing as a heavy duty halfshaft for the 4-lug cars because, generally speaking, all the aftermarket or rebuilt axles will fail in short order. Do a search for non-OEM axle reviews and you'll find that people have had to replace "brand new" rebuilt axles over and over again.
  11. Also, I had to clearance my transmission to not tap on the tunnel. Sounds like people have had different experience though.
  12. Used is your only option at this point, I don't think there were ever aftermarket control arms available. The anti-roll bar end links are basically just crimped bar stock on the EA82s, you can fabricate your own without problems.
  13. Do you want an open differential or an LSD?
  14. Anybody looking for a set of DL headlamps? I've got a set that I don't plan on using...
  15. My coupe should be back on the road in the next week or so. Jiggs, you should bring yours to the Old School Reunion on the 10th, we could park our cars next to one another!
  16. There is a stud embedded in the rubber, IIRC. I've never had luck removing them (granted, I haven't tried very hard) but I would thing you could slit the rubber to expose the stud then turn it out with some vice-grips.
  17. IIRC big valve heads only came in '83 automatics, then every EA81 from '84 on. I probably have that wrong, but nothing pre-'83 will have big valve heads.
  18. Obviously my mileage is varying because I needed the sleeves for the bolts. OP, feel free to skip the sleeves, but do have a backup plan if you do end up needing them.
  19. elFreddo, not the pressure plate moving, the EA82 flywheel moving on EA81 bolts. And trust me, they were torqued to factory specs.
  20. EA81 flywheel bolts don't play nice with the hole size in an EA82 flywheel. When I started my car for the first time after the conversion, I thought I had rod knock. Turns out the flywheel was rattling around on the skinny EA81 flywheel bolts. I'd say if you're using the EA82 flywheel, the bolt sleeves are required (but what do I know).
  21. Well gang, looks like I'm jumping on this bandwagon. Nolathane upper anti-roll bar endlink bushings, Superpro lower anti-roll bar and leading rod bushings for the EA82. I'll report back once installed with some miles on them.
