Everything posted by carfreak85
85 Brat Headlight replacements
They'll last three years instead of 10, for example.
Loosing Coolant - Leak or burning?
carfreak85 replied to booki's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you have any silicone hoses on your forester? I ask because silicone has x10-x15 the permeability of EPDM rubber and can allow for coolant loss through evaporation.
84 GL wagon VS. 85 4WD Turbo RX
Keep me posted on what you decide Jaysus.
Your best bang for the buck would be to create a new, beefier headlamp harness. This will reduce the electrical bottleneck in the system. Also to note, brighter halogen lamps generally do not last as long. Replace in pairs.
I'm interested in buying the RX. Do you have photos? What's the mileage on the car? Any rust?
- 1985 Turbo Brat Turbocharger upgrades?
"Icarus" 1988 xt6 build
Whatever happened to this project?
Third eye questions
I'm still waiting to see it mocked up on a stock, quad-beam '83+ GL front end.... Cuz that's how they came, right?
- XT6 air suspension/lift
My brat's been stolen, heart is broken
Still no photos...
- Base to WRX Suspension Conversion
Discontinued Bushing HELP!
GD, I'm going to disagree with you here. I've used this stuff on two cars so far, one of which was my T-wagon 4 or so years ago. I picked up this trick from Dave Coleman, current design engineer at Mazda R&D. If it's good enough for his championship rally cars, it's good enough for our differential outrigger bushings. Now, that said, I'm not suggesting that a new bushing be made from this material, just that a failed bushing could be refreshed by filing the voids with 3M Window Weld.
Classic Car Insurance?
It depends on what you value the car at. Too low and they'll ignore you. I looked into it for my EA81T wagon and they rejected both the model and the value I set it at.
Just buy a tube of 3M Window Weld, tape up one side of the factory bushing and fill in the voids in the bushing with the 3M product.
Ever Seen A Nardi Steering Wheel Adapter?
Just curious. I know MOMO and Grant had applications for Gens 1-3, but I've never seen or heard of an adapter from Nardi.
AGM Battery Upgrade
carfreak85 replied to suprunner's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, I'd say the brushes in the alt probably took a dump.
1990 ej 22 head gasket oem or felpro ?
carfreak85 replied to ivantruckman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn just the EJ22, or any EJ engine?
- Best Subaru Instagram Accounts of 2017
Need Advice: 4EAT Front Diff Bearing Failing
carfreak85 replied to carfreak85's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo close the loop on this thread I installed two SOA-reman'd front axles and this appears to have solved our issue.
EJ Shifter Fix - EA-EJ swapped cars
CrazyEights, you got those photos handy? I'd like to start reviewing what needs to be done.
RX Turbo Stock vs TechWorks Dyno Results Big Pics
Yo, Myxalplyx, any updates on the parts?
Third eye questions
Well if that's what some stranger told your daughter, who told you, who is telling us, then it must be correct. Post pics once you've got it all mocked up!
Third eye questions
You must trim a 4-beam grill to fit the center lamp. The switch mounts to the left of the steering column, in one of the holes by your left knee. There should be a diagram in the USRM.
