Everything posted by carfreak85
EA82 HVAC Blower Works Only on Speed 3?
I've got an EA81 (for the failed resistor pack in the T-wagon) and an EA82 resistor pack on the way to my local dealer. I'll see if I can get a fan speed switch too. Thanks!
Need Vehicle in Baltimore Inspected
Gosh, I hope the seller doesn't think I'm a Nigerian Prince, all I did was ask for their number, then gave them mine... Grossgary, my computer was acting up so I didn't have access. I'll give it another go today.
Anyone have any idea why my HVAC's blower motor will only operate on fan speed 3? I thought that if the blower motor's resistor pack failed, it would only work on fan speed 4...
Grossgary, I'll get you the info when I get home (work computer doesn't like copy/paste on USMB, Craigslist is blocked too...). The seller doesn't want to call me or provide me their phone number...
I guess some unpaid time off is in my future then. Your offer of assistance (or lack thereof) will be noted for future reference...
Does anyone live in or around the Baltimore area? There is a subie out there that I am very interested in buying, but I live 2,754 miles away. I'd be happy to pay you for your time. If you're able to act as my proxy and store it for a short time as well, I would compensate you accordingly. Tell your friends!
Tapping when first starts. What is it? Ways to remedy?
carfreak85 replied to revtim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy wife's Forester has the same symptoms you describe and her 2.5l has piston slap. Was this noise present before your valve work? As for oil additives, not a good idea. I work for a vehicle manufacturer and we don't recommend using any sort of additive in the engine oil.
- Infinity 4x140 rims
"Heavy Duty" Cv Axles
@skishop69 - Well the engineers behind EA81/82 axles never intended these vehicles to be lifted, much less Rubicon-capable.
Real experiences with going way over 300K with your 90-94 Legacy and those 2.2's
carfreak85 replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTrans rebuilds on a Subaru are NOT cheap. I'd almost recommend sourcing a good working used trans. You'll probably be looking at over $1,000 at least, for a rebuild.
EA81 Performance - The intake manifold
To piggyback off what GD said above: On any engine in general, carb'd or fuel injected, you want to keep the intake ports a bit rough. Not as-cast, per say, but not polished. This is because of the boundary layer of turbulent air right next to the port wall that keeps atomized fuel from dropping out of suspension. The exhaust ports in general, regardless of fuel delivery, may be polished to expedite the flow of the exhaust gas column.
EA81 Cylinder heads
I've seen cracked cylinder heads on at least three different generations of Subaru engines: EA81, EA82, EJ205. In many cases the engines run fine and I've been told that the cracks are both bad for the engine and that they are harmless. Since you'll be in a plane, I'd suggest having them repaired or replaced, for piece of mind. Flygas is an outfit in Italy that makes custom cast, dual port EA81 heads. Ram Performance in the States is an engine builder who specializes in EA81s for aircraft use.
Monroe struts
KYB all day.
- VERY short RAM on my 88 GL (with pictures)
EA82 Coupe Can't Adjust Door To Shut Completely
FIXED! New strikers for both doors fixed the issue. The driver's side had worn through the plastic coating and was starting to wear down the striker itself. The passenger's side still had the plastic, but it was loose and in pretty rough shape anyway. I should note that while I was able to order the strikers from SOA, the hardware to mount it is NLA...
Remove XT Side Mirror Glass for Respray?
Ahhhhh, I see it now. Do you know how thick the head is on the top of that pin in the joint, before I destroy the mirror to measure? I'm a little nervous to stick a screwdriver between the mirror and the housing, it looks like there are six or seven screws back there and not all of them have a direct line of sight to get a driver on them, much less being able to start them again during reassembly.
As an automotive design engineer I can tell you that it will make a difference in output, but with such a low-output motor, you may not even notice the difference unless you have a well-calibrated butt dyno. For every 10*F you lowere or lower your intake temperature, you gain 1% of total engine output. I would estimate (based on winter in MI) that your hot air intake has increased your intake air temperature by AT LEAST 40*F, so running through the math: (Your engine started life with 90 hp, but it's probably closer to 80 now) 80hp x 0.96 = 76.8 hp. And that's at the crankshaft. Let's assume a 20% loss from the drivetrain 76.8 x 0.80 + 61.44 hp. With 61.44 anemic horses dragging your Subaru around, you really need each and every horse working at its peak performance. If you're stuck on your new intake, at the very least you need to build a shield of some kind that seals off the filter from the rest of the engine compartment, no need to make a hood vent or scoop. Your original intake drew cool, dry air from the passenger's side inner fender.
1977 stage two - thru 1979 and to 81 BRAT
Front valance for a Gen1 Stage1?
Ej swap, Fuel starvation?
Get the appropriate fuel tank from any fuel injected Subaru (An EA81T, in the case of your BRAT) and be done. A surge tank is used when the OEM fuel tank is not baffled. It is essentially a mini fuel tank that is so small that fuel can't slosh away from the pickup. On a turbocharged car it is VERY IMPORTANT TO AVOID HIGH-LOAD/HIGH-BOOST FUEL STARVATION (aka RUNNING LEAN).
Rx Window Trim
Good luck finding replacement trim... Start looking for a parts car.
I recently picked up some XT mirrors for an upcoming project and I'd like to repaint them. I'm thinking it would be simpler if I could disassemble the mirrors. Is there a simple way to get the mirror glass off the side-view mirror assembly? Can the mirror be disassembled to remove the rubber bellows at the folding joint?
4x140 - 5x100 Wheel Adapters
Wheel adapters bad, converted hubs good...
Subaru Quad Beam Upgrade
Let me stop you right there. The first option you referenced is the correct avenue to go down. Proper 4x6" LED and HID lamps are expensive because there has been actual engineering and math put into the design and dispersion of light across your field of vision. These lamps WILL be an upgrade over your sealed-beam halogens. Cheaper alternatives are cheaper for a reason. They were "designed" around a halogen bulb, which is fine, but they were never intended to provide the correct beam pattern when fitted with an LED or HID "plug-n-play" bulb. The qulaity and legality of the PnP kits is enough for its own thread, so all I'll say about them is they are illegal for road use in all 50 states (IIRC) and are sold for "off highway" use only. These lamps WILL NOT be an upgrade over your sealed-beam halogens. The problem with slapping PnP LED/HID bulbs in these cheap lamp housings is that the shape of the light source from each of the three types (halogen/LED/HID) is different. The halogen lamp's reflector bowl shape and distance from the projector lens is different than that of a lamp that was intended to run an LED, which would also be different from that of an HID 4x6" lamp. There are other alternatives to the JW Speaker lamps, such as Grote and Truck-Lite, but you want to make sure you are buying DOT compliant lamps. That compliance testing and R&D costs money, no way around that...
Strikers are still available from the dealer!
