44
Everything posted by carfreak85
Need 3rd eye/Center Lamp Part Numbers
carfreak85 replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Bump! Please help! -
Rear disk conversion to hatch
carfreak85 replied to iceageg's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I replaced the rear brake lines like Numbchux did, but routed them along the semi-trailing arm on my EA81T wagon. I was even able to reuse the little metal tabs to secure the line, using some silicone tube to prevent premature wear. FYI, there are two lengths used for GD rear brake lines. STI and non-STI are different lengths, I think STI are longer, but I don't remember offhand. -
Bump! -
Subarus of the 80s is back!
carfreak85 replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks! -
I'm trying to replace the motor-to-emblem arm on a center lamp assembly and was wondering if anyone has a factory parts catalog they can look this up in. Thanks!
XT6 rear hubs EOI in 5x100 & 5x114.3 ?
carfreak85 replied to dfoyl's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What are the physical differences between XT6 and EJ lug studs? -
John Bloom has resurfaced on the Old School Subaru Group on Facebook. He is currently selling an EJ22T engine. If anyone has outstanding business with Mudrat79, now may be your chance....
Crazyeights - I'd be happy to have them shipped to me and we can either meet up or I can flat rate the hubs to you. Let me know what works for you. Dfoyl - I know you addressed it earlier in this thread, but do you plan on doing any additional runs of these hubs? -
1984 Subaru digital instrument panel
carfreak85 replied to Cadillacdog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Interesting analysis DaveT, I'm not an EE by trade, so don't have the knowledge base to triage the failed dashes I've come across. This may help my friends who are helping me with this project, so thanks! Do you think a similar phenomena is the reason for the EA81-digidash failures? -
DaveT, care to expand on the design compromises you mentioned? -
Shoot me a private message and I might be able to help you out. -
Chalk me up for a newly-studded pair, please. -
What sort of autoX do you run where your brakes get hotter than open track lapping?! I run Motul RBF600 in my WRX without issues. 600*F dry boiling point, so it should hold up to almost anything you can throw at it. They also make a 660*F formula. Change the fluid AT LEAST annually and use whatever fluid you like, just make sure the boiling point is decent.
DO NOT USE LUCAS OR OTHER ADDATIVES IN YOUR TRANSMISSION. Make sure both trans filters have been changed. At least on my wife's 1999 Forester there is a spin-on "oil filter" type mounted externally and a second, "traditional" AT filter, mounted internally. If flushing the trans and changing the filters doesn't cure what ails your transmission, there is probably some physical damage that no amount of magical soup is going to fix.
I would avoid using any Lucas additives in your engine, diff or transmission. Their additives tend to aerate lubricating oils, and as we all know, air is not a good lubricant. If they have that little gear-ladder-in-an-oil-bath display on the counter during your next visit to the parts store, give both hand-cranks a series of really fast turns and compare the oil afterwards. While the Lucas-infused oil will climb the gears higher and more quickly (That's what their trying to sell you on), you will almost immediately notice that the Lucas-infused oil becomes filled with hundreds of air bubbles. No bueno. Oil manufacturers spend MILLIONS of dollars on their formulations. Don't believe for a second that they would leave something out of the formula if it was truly needed. Lucas products are, quite literally, modern snake-oil...
- 261 replies
- 2
- Restoration
- Coupe
- (and 4 more)
As long as they're from a reputable company (I still consider MOOG a quality company, for most parts. Although they have started de-contenting their products) I wouldn't worry about the quality. I have used a set of Ingalls camber bolts on the front of my WRX without any issue. Full disclosure: When I swapped in Whiteline COM-C front strut tops, I removed the camber bolts.
Don't skimp on materials, don't build an exhaust with electrical conduit or mild steel. Back when I was considering a header for my turbo wagon I knew that paying more up front would net be a better product in the end. I ordered pre-bent 304SS mandrels as well as 304SS plate material to fabricate flanges. I'd have to look it up but I think I paid ~$200 for materials and some other amount for fabrication. If I were to do it all over again, there are a few things I would have insisted the fabricator do differently (thicker flanges, weld inside and outside of the pipe/flange joint), but this header is still going strong with only minor repairs after 11 years on my car. Even if it cost me $450 out the door, the header only cost me $3.41 per month for the last 11 years, less than the cost of one monster Starbucks drink per month. 100% worth it, IMHO. Vibrant Motorsports has really good prices on mail order materials, price check with them too.
- 261 replies
- 1
- Restoration
- Coupe
- (and 4 more)
Looking to Borrow some 4x140 Rims/tires
carfreak85 replied to jread's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have you looked in the yards nearby? Kelowna's PNP looks heavy with old subies. -
I've got what you need, but I'm a few hundred miles too far South to be of much help...
