41
Posts posted by carfreak85
There should be two bushings, one above and one below the mounting ear, that sandwich around the shaft. You said you replaced the bushing (singular) so do you have one, or two bushings up there?
Don't buy aftermarket replacement axles, re-grease and reboot your stockers, they simply outlast anything "remanufactured."
- 2
@Suberdave has been making some recently.
If you're blowing bulbs with frequency, you might want to look at the headlamp plugs and see if they have thermal damage.
- 1
- 1
You don't NEED XT6 parts these days. The front end can use EJ parts and there are a couple sources for reproduction XT6 rear hubs. Wheel adapters and wheel spacers are TRASH.
How are you guys killing EJ 5-Speeds?! My 2002 WRX was bought new by my father, we dual drove it in Autox for 5 years, maybe 10 events per year. I beat the piss out of my transmission: doughnuts and drifting in the snow, racing with multiple drivers, speed shifting, etc. The only thing we have never done with this transmission is a high-rpm clutch drop.
The engine spun a rod bearing at 80k, but it wasn't until about 150k+ miles that the center differential started making noise, which seems to be a common failure mode for the Phase 2 5-speeds.
I can't speak for anyone's experience but my own, and my experience it that if treated with even a modicum of mechanical empathy, the 5-speed transmission is as strong as it needs to be for the WRX. Heck, my 2002's "AA" transmission is the weakest one the USDM WRX was ever delivered with, still no problem shearing gears.
- 1
Has your car ever been in a collision? Bend trailing rod?
The OEM sensor is manufactured by Denso.
19 hours ago, Russelwiscosin said:
Hi I will try to take a picture. Can I send it directly to you?
Yeah, you can send it in a message, or email it to me: soobcrazy at gmail (dot) com
Do you have any photos of the Rabbit? My aunt lives in Waukesha and could possibly store it for me.
That WRX pump might put out too much pressure for the original rack. Did you research the specs on the two pumps before selecting, installing and plumbing the WRX unit?
BFGs are HEAVY, I'd look for a lighter tire. Could probably save yourself ~20+ lbs of unsprung.
Yes, 100% interchangeable between series 1 and series 2.
17 hours ago, Step-a-toe said:
Don't use CV in association with rear in search because only our fronts use a CV joint on the outer to allow for steering- unless you have four wheel steer ??
Double offset joint DOJ inner on fronts, both ends on rear
Time for me to check locally as some have said rear shafts are available through nationwide parts supplier
Later EA82s use CVs in the rear halfshafts outer joint, at least in USDM-land.
- 1
I don't know if it's the biggest factor when converting a Gen 1 to use Gen 2 front brakes, I've never done the swap. But if you're grabbing a hodgepodge of EA81 parts, it's something to keep in mind.
Wide calipers with vented rotors, skinny calipers with solid rotors. That's the major compatibility change to be aware of for EA81s.
Having spent time in EA81s, then a GD WRX before buying my first EA82 chassis, I'd have to agree on principle with @GeneralDisorder, if not in spirit. The EJ chassis is the easy button going forward for many reasons and have proven just as, if not more, mechanically durable than the EA82.
Yeah, that's not factory EA81T...
Delrin or urethane rod stock both work well for shifter bushings.
The previous owner of my EA81T coupe replaced the OEM pressure regulator with an aftermarket one. I'd go that route unless you can find a spare regulator someone has saved on a shelf.
- 1
On 7/14/2020 at 5:02 PM, GeneralDisorder said:
That would be on the 255/257 with the narrow oil pans and the short dip-sticks..... not applicable to the 205 with it's flat bottom pan and low oil level.
GD
Are you thinking the pan/oil level impacts the life of the oil pickup tube?
The semi-trailing arms already have adjustment built in.
I might be willing to let go of one of my spare EA81T longblocks. Shoot me a PM.
Someone convinced a company to manufacture stiffer rear torsion bars for the EA81. I forget the company, but they're available today.
best low-beam light?
Posted
@1 Lucky Texan and @Numbchux you two have no idea how heartwarming it was to read your replies to this. As somewhat of a lighting evangelist, it's nice to know there are others out there who "get it."
Carry on...
