Everything posted by Rooster2
worst ATF change ever.
Rooster2 replied to sonofbuster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt helps to use two filter wrenches at the same time.......one that goes around the filter, and another that fits on as an end cap, and is turned by using a 3/8 " drive handle on the filter end cap. This gives you two handles, and double your power to loosen the filter.
1995 Legacy Outback strut help please
Rooster2 replied to gregdavis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe jumpiness in tight turns sounds like "torque bind." The phenomenon is well written up in the archives of this forum. Changing ATF if your car has an auto transmission may help. Change the fluid 3 times with short drives between changes is recommended. Only about half the ATF can be changed at one time, the other half stays in the torque converted, and won't drain is the reason for the 3 changes.
Tires not balanced?
Rooster2 replied to Kwhistle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot doable to put your tires on rims at home. It takes a tire changer machine to do that. I have been a loyal Discount Tire customer. They have always been good to me until lately. Last time there, the counter guy was rather snotty with me. Maybe it was just him, I don't know. His spouting new Discount Tire Policy to me about not working on tires older then 6 years was ridiculous. All I wanted was to have them aired up on my RV. Walmart will mount and balance tires for $5 per wheel. The price is right.
Tires not balanced?
Rooster2 replied to Kwhistle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMostly likely crappy tires.
Check engine light came on.
Rooster2 replied to Highway_Star's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think that a bad KS results in "limp mode" computer function, that retards engine timing to prevent detonation (Ping). Does the KS do this, or affect rich/lean mixture instead?
95 starter problem
Rooster2 replied to califcamper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAZ stores used to have a testing station, where starters could be hooked up to power, and tested inside the store. However, I haven't seen a testing station in some time, so they may have discontinued that service. Tell the AZ counter guy that you know what you are doing in installing a starter, and your cables and hook ups are correct, but your electrical system continues to short out. After completing that discussion, they will swap out another starter to you with no hassle. Hope a "new' starter solves your problem.
Another What plug thread
Rooster2 replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think my 99 OBW has the same plug sitting up near the top of the firewall, just below the wipers. I don't know what it is for, I have never used mine.
95 starter problem
Rooster2 replied to califcamper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou have a dead short somewhere. Hard to believe the starter could cause a dead short. Usually a bad starter simply doesn't work, and produces no other issues, not the problems you are having. Like already responded here........are you sure your battery cables are not reversed?? Any chance the battery was removed, then installed 180 degrees wrong?? I buy quite a bit from AZ. I have never had trouble with their rebuilts, but others say they do. Regardless, AZ has a great guarantee on their products, so you won't have any trouble getting a replacement.
2000 4 cyl OBW - need new starter
Rooster2 replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt has been a while since I replaced a starter, but seem to remember the "swing" problem with the handle. I think I remedied that by using about a long 10 " extension bar between the socket and the drive handle.
New guy with an old Forester.
Rooster2 replied to upDUHcreek's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe trans spin on filter looks exactly like an oil filter, and screws into the side of the trany. Resist the temptation to replace with an oil filter. The trans filter requires a specific trans oil filter. They are pricey at about $30/filter, and available at auto parts stores. Call first to see if they have one in stock. Don't drop the pan looking for an internal trans filter. The little piece of screen wire inside there never seems to clog up. The problem is replacing the tranny pan is a nasty job of removing the old gasket, and then there is a strong possibility that your new pan gasket will leak ATF.
Rooster2 replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBolts too tight??
leaky oil pan
Rooster2 replied to the3rsss's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXClean the area super good with gasoline or rubbing alcohol on a rag. Dry thoroughly, then seal up the area with JB Weld. Let set over night before driving the car for JB to dry. JB should fix this easily.
Rooster2 replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know of any rebuilds that have a bad reputation. I have had good luck with the "Worldwide" rebuild brand. It is priced on the lower side of the rebuilds. I have only had to replace two starters over the past 15 years on my three Subies, so with the rebuilds holding up and doing well, I don't have much experience in running into bad rebuilds. The starter is not that difficult to replace. I do the work from the top of the engine. You have to be a bit of a contortionist to reach a bolt or two, but it can be done. The danger is dropping a mounting bolt upon reassembly. I stuff rags and paper towels under the starter to "catch" a bolt should I accidentally drop a bolt. The rags prevent the bolt from falling somewhere that makes it difficult to retrieve the bolt.
visual difference in 2.2 & 2.5
Rooster2 replied to old sub freak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook at the very front of the engines. The 2.2 will have two round circles in the plastic cover that covers the cams and timing belt. The 2.5 will have four round circles in the plastic cover that covers the cams and timing belt.
head gasket and convert to 2.0l JDM
Rooster2 replied to bpk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI did a google search for "used Subaru motors." That search produced quite a few sites for motors for sale. I tried in vain, but could not find the site that I requested a motor for 1995 Subaru Impreza 2.2 motor. The 2.2 motor from 1995 is the best match to replace a 2.5 in a 1998 Legacy. I read that asking for an Impreza motor would cost less then one from a Legacy. They are the same, but Impreza maybe costs less. It was a matter of filling out a form on line of the motor I wanted. Once submitted, I received about 10 emails from wrecking yards from Chicago to New York state. There were also several telephone calls too. However, for the life of me, I can't find that web site. However, I found my motor locally from a wrecking yard. So, it is worth making some calls to your local wrecking yards to see what they have. Good Luck!!
Rooster2 replied to bpk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am in the process of having my 2.5 replaced with a 2.2 from a '95. I checked several JDM sources, but found the motors rather expensive. I bought the 2.2 with 143K miles on the odo, and a 6 months guarantee for $375. I don't want to come across as bragging, but just want to show you what cost can be from non JDM sources. Other 2.2 pricing I got from other yards had 2.2 motors from about $700 to $875. I was also reluctant to buy a JDM motor because there might be issues of comparability to the US market. If your current motor has EGR, you will need to replace with a motor that has EGR, or your check engine light will always be on. Do you know if the 2.0 motor has EGR? Do you know if it will be OBD 2 compatible? I would hate to see you buy into a can of worms of problems.
Rooster2 replied to bpk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSince the block head bolt hole has been over sized, I don't see how swapping 2.5 externals will correct anything. Is dealer wanting to replace the block by going to a JDM engine?
2.5 head gadket issue
Rooster2 replied to califcamper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy wife just cooked our 2.5 motor in 98 OBW. I wish Subaru had installed a red flashing light on the dash, if the motor was over heating. My wife never pays any attention to the temp gauge. Better still, it would have been better to install a sensor that would shut down the motor, if it began to over heat. Crappy HG, and a less then great dash warning light system in Subie is not a good combination.
Sources for 2.2 motor??
Rooster2 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf your 2.5 did not over heat for a long period of time, or repeatedly, your engine is prolly not damaged. Still, it is good to keep listening to the engine for any heavy knocking noise that signals rod bearing trouble. Hope you used Subie HGs, as they are highly recommended. After market HGs don't have as good a reputation. I read something too about the "6" digit match, but don't know what it means. When I bought my 2.2, no one asked the question. So, I hope my motor will work without matching any VIN numbers. Maybe someone reading this can say what the "6" does?? Here in Indiana, there are a fair number of Subies on the road. I think having them assembled near Lafayette, IN has something to do with it.
Rooster2 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI felt fortunate to find a '95 2.2 for $375. I haven't had it installed yet, but was told that it came from a running car that had been hit in the side. So, I am keeping my fingers crossed that I got lucky and bought one that is in good shape, and hopefully, PO changed oil at reasonable intervals. I checked around on the internet and found a bunch of 2.2 engines that are priced at around $700 to $800. Who knows their histories, if they are good or not. Like already written, buying a good 2.2 for $200 doesn't exist anymore. Also, 2.2 motors are getting really old, with a lot of miles if they have been continually in service. I suspect the supply of 2.2 motors is dwindling away. Lower supply of good motors, yet with some demand, means prices rise. I suspect that lower bearing failure on an over heated 2.5 is prolly strongly related to oil lubrication failure. Super heating oil breaks down its ability to lubricate properly. With poor lubrication, a connecting rod failure is predictable.
Rooster2 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI printed out your advise, and will give it to my mechanic. Thanks again.
Rooster2 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou guys are great. Thanks for all the help. Special Thanks to John C for posting the info about the 2.2 '95 motor from Brickyard Wrecking Yard. That is not far from where I live. Funny thing.........I called there yesterday to inquire about a 2.2 motor, and was told they did not have any. Less then 24 hours later they have one. Go figure!! So, I bought the motor for $375, and consider that a good deal. Comes with a 60 day warranty. I have bought from this yard in the past, and they have a good reputation of being honest with me in previous dealings. I was told the car had been hit in the side, and they considered repairing it, and putting it back on the road. I feel good that the car was running just prior to the yard buying the car from an insurance sale. Thanks again guys.
My mechanic called me to say that my 2.5 is definitely cooked in my 98 OBW. It has a warped block, and knocking sound when held at 2K rpm. I am still mad at my wife for driving the car till the engine died. I am going the 2.2 replacement route, if I can find a decent one. My mechanic says he has a source for 2.2 motors that are imported from Japan by some company in Louisiana. He couldn't remember the name of the company off the top of his head. JDM maybe it is in Denver, but not sure. (Anyone know of the outfit in Louisiana?) He is going to check on cost but roughly $850 to $1,100 for a motor delivered, that has a one year guarantee. I am checking on line and locally for a 2.2, but if anyone could point me in the right direction to a good 2.2, at a good price, I would appreciate it. Meanwhile, I have a lot of reading to do on what 2.2 to install. I remember the '95 model 2.2 is a direct plug and play fit. Still........lots to read up on the subject.
98 OBW, death by driving it HOT
Rooster2 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUpdate.......my mechanic called me to say that my 2.5 is definitely cooked. It has a warped block, and knocking sound when held at 2K rpm. I am going the 2.2 replacement route, if I can find a decent one. My mechanic says he has a source for 2.2 motors that are imported from Japan by some company in Louisiana. He couldn't or wouldn't tell me the name of the company. He is going to check on cost but roughly $850 to !,100 for a motor that has a one year guarantee. I am checking on line and locally for a 2.2, but if anyone could point me in the right direction on a good 2.2, at a good price, I would appreciate it.
? 2006 Legacy sedan 2.5 ATF burnt 45k miles
Rooster2 replied to bheinen74's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDraining the ATF, only removes about half the ATF from the transmission. The other half remains in the torque converter. You really need to drain and fill three times (with short drives between refills) to do the job really right. Black burnt ATF is a sign that the trany fluid got really hot, and prolly repeatedly so during its life time. You have to drive a car really really hard to do that, or have the car severely over loaded on a long drive to over heat the ATF. Does your Subie have a trailer hitch on it? If so, maybe the previous owner pulled a heavy trailer, which caused the ATF to over heat. Subie automatic transmissions are built really strong. They do not have a history of problems. I suspect the previous owner is the culprit in this story.
