Rooster2
11
Everything posted by Rooster2
All those parts are "bolt ons," and none sound expensive, or time consuming to install. It is worth a call to a few yards to see what parts they might have. It sound like you have enough car left to be able to put her back on the road. Spray cans of paint that come close to matching your existing car paint are available. The result won't look perfect, but not bad either. I have an old Audi that I wrecked several years back. Parts needed were much like what you need. Cost came to something like $250-$300. Any structural damage to the uni-body, radiator, or head light support? Fan behind the radiator okay?
Glad your wife is fine. That is the best news!! I own both a 98 and 99 Leggie Outback wagons, and am satisfied with both. Gas millage is prolly in the range of 25 mpg with all around city driving. From what I have read Subaru AWD is about 90% front drive & 10% rear drive all the time. If slippery conditions are encountered, then the power is moved away from the slipping road wheel to a wheel that is getting traction. What hurts fuel economy more then anything else is the added weight of the AWD components, as well as all Subies got heavier with air bags, heavier bumpers, stronger bodies, and more accessories. I live in Indy, and get to the wrecking yards quite a bit. G.W. Pierce wrecking yard on Route 31 North of Indy has a fair amount of foreign car parts. They may have parts to rebuild your car. What is needed?
I checked on my 99 OBW, which is same car as yours. Fuse and relay panel is in the engine bay. Open the hood, it is right behind the battery above the road wheel. Fuses and relays are in a black box, marked "fuses & relays." Unlatch the clip closest to the windshield, and the box top hinges upward. I have read on this forum that there is, or are relay(s) under the dash, right above the lever that you pull to open the hood. There is an access door next to the lever, but it looks pretty small to be of much help. Hope this info helps..........Rooster2
I agree that running 91 octane is unnecessary. 87 octane runs well in my two Subies. The higher octane of 91 isn't giving you enhanced performance, or lower emissions. Just costing more. I would use E-85 on a regular basis. Your car wasn't designed for it. Yes, the alcohol does a good job of cleaning the fuel system, but is known to degrade rubber parts of a fuel system. So, don't advise running E-85 often. I use the Bosch Platinum spark plugs. The cheapest ones with just one anode. They work fine, plus don't need gapping. Cost maybe$2.00 - $3.00 each.
I think the alphabet rating system on tires misleads people. It is just not important. I never consider the alphabet ratings, when buying new tires, or have ever had a tire sales person bring up the subject in advising what tire to buy. Realistically, I think any tire will work well on any car that is driven within posted speed limits. A Forester is not intended to be driven as a sports car, and drivers know that, and I bet you know that. The T rated tires will work just fine on your car. Trust my advise.
Imho, in a situation of driving nearly double the legal speed limit for a sustained period of time, and having the tire blow out, then having the balls to sue the shop would be viewed as a frivolous law suit, and thrown out of court. What ever happened to being responsible for your own actions and misfortunes?
From what I have heard and read, you have to drive about 100K miles to break even cost wise: hybrid extra cost vs. saving money on gas. So, I guess anything driving over 100K miles becomes a dollar savings. My concern, is how long in time, and or, in miles do the rechargeable hybrid batteries last before they wear out? Then, what is the cost for replacement battery(s)? Plenty I bet, maybe like $1,000-$2,000, maybe more. Yes, it is cool to "go green" with a hybrid, just too bad it is at the expense of the "green" from your wallet. Had a conversation with a friend last night. He says a total replacement of battery pack on a hybrid car is about $7,000-8,000. However, some hybrids have a battery pack that just an individual bad cell can be replaced, instead of the entire battery pack. This saves lots of money, but still requires "green" from your wallet
I recently changed my 02 sensor on my 99 OBW, which would be the same set up as yours. A standard 02 sensor socket with a cut out for the wire won't work. There is no room to attach the 3/8" drive handle to the end of the socket. So, I bought an 02 sensor socket from O'Reiley's Auto Parts store. It is made with an offset for attaching the drive handle. It worked great. It helped to put a length of pipe over the drive handle to get extra leverage to loosen the sensor. With heat and time, the sensor can be difficult to loosen up. A regular open end wrench can be used to tighten up the new sensor.
Nipper......... The pedal does not sink to the floor when standing on it with the car running. Yes, I do my own brake work. I have replaced calipers, rotors, and pads, and know to lube the slides well. I have used a one man bleeder system to get rid of air in the lines. I have replaced calipers before, when the car pulls to one side because the pad is dragging. It is then, I have found the brake pad worn much more so at one wheel, compared to others. Pretty easy to figure out that the caliper piston is sticking. I wish I had a heat gun sensor to see if one brake is hotter then the others after a drive. That would indicate a bad caliper causing pads to drag. I have never replaced an M/C, but figure it can't be difficult. I have always thought that having to double pump the brake pedal was the indicator that the M/C is bad. Any other thoughts??
93 Legacy
Rooster2 replied to dixeyk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Subarus have very reliable automatic transmissions. They are built tough, and last a long time. Subaru is even thoughtful enough to have build their auto trannies with an ATF drain plug to make changing fluid really easy. Fluid change is seldom done, but it is nice to know that it is an easy job. With decent tires the AWD is great in snow. If you anticipate heavier snow, then think about an Outback model; they are a little taller off the ground, so can handle heavier snow better without bottoming out in the deep stuff. -
Just came back from a test drive to do the testing that was suggested. Brakes seem fine today, brought the car down to a dead stop repeatedly with nothing unusual. I could not detect any sponge in the pedal. The "pump the brakes" test did not improve braking. I did the PB booster test, and the pedal moved slightly to the floor as it is suppose to do. I can't figure out why the brakes felt weak for the last couple of days, and now feel just fine today. I know I am not loosing my mind. I clearly remember the brakes had diminished stopping power, and it concerned me. I can't imagine any slippery build up on the pads to cause problems, but if so, it is not there now. Guess, I will have to keep an eye on the situation to see if it returns. Thanks for all the solid advise.
My 98 OBW that my wife drives has developed weak brakes. It stops straight, pads in the front are 2 years old, rear pads 6 months old. I bled out the old fluid about 3 years ago, filled with new DOT 3. There are no odd noises when applying the brakes. Pedal seems to go down a little low upon applying the brakes. The problem is that pushing down hard on the pedal produces weak stopping power. There is not even enough braking power to come close to locking up the brakes, or setting off the ABS. I wonder if the rear brakes are working? Should I bleed out the brakes again, or is this a MC problem?? There is no warning dash light.
SOA sent me an email advertising the Impreza line for 2012, prolly others on this forum got the same email? The car looks great. It is now powered by a 2.0 litre motor. The ad says they have not increased prices for 2012. Also............my latest copy of Road & Track discusses all the new cars from all manufacturers. I read that SOA will introduce a small 2 seat sports car with the 2.0 litre motor, rear drive only. The sketch picture looked great. The article stated that the car appeared originally some time ago as a Toyota concept car, but now it is a Subaru. No name announcement for the car. Retail intro is slated for early 2012. I am thinking this car may be about the size of a Mazda Miada. Anyone know anything more about this new model?
