Rooster2
11
Everything posted by Rooster2
I continue to have a good experience with Advance. Just last night, I returned a warped front rotor from my 99 to their store that I bought on line last year, and picked it up at their store. Guarantee was for 2 years. Advance swapped it out for a new one, no questions asked, and no hassle. Great counter guys to do biz with. Seems like nearly always they have a coupon available when purchasing on line. It has become the way I buy major parts from them.
If it were me, I would change the oil, and add an additive. Old standbys like Bardahl, Rislone and Marvel Mystery Oil, instead offer things like "quieter lifters," "reduced oil burning" and a "cleaner engine." Most of these products are made up of solvents and detergents designed to dissolve sludge and carbon deposits inside your engine so they can be flushed or burned out. Rislone and Marvel are my favorites. They have been around forever, and are still great.
I don't know what that little hose is for, but would find it highly unlikely that the hose disconnected could cause any damage. The second round of sputtering is prolly a continuation of the first round of sputtering. Suggest you start doing with basic diagnosis....do you have spark at the plugs? Do you have fuel flow? Any chance you are trying to burn old gas that has been in this car for a long long time?
If all 4 bulbs blink when using the turn signals, then the problem is prolly a poor electrical connection at the bulb holder with the bulb. My 99 has twice had that problem, and in both cases the problem was with a front turn signal unit. The bulb was not making good electrical contact in the socket. Simply removing the bulb, clean the bulb contacts, reinsert the bulb, and your rapid blinking bulb should now blink normally. Prolly some diaelectric jelly would help the bulb make better contact, but it is not necessary to use that product. I have found that the do-it-yourself wrecking yard prices are much less then the traditional yard, that will only let their employees remove parts. So, the pricing that you presented doesn't surprise me.
Wire boots
Rooster2 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The last time I pulled off the plug wires, they were so tight it seemed like they were shrunk wrapped onto the plug. Guess the engine heat does that over time. If they are so difficult to remove, it is a pretty good indication that they need to be replaced, and not worth saving. I just yanked pulled and pried with channel locks and long angled needle nose pliers until they came off, which was mostly in pieces. I added some electro jell upon installing new wires. Maybe the jell will help the next time I want to remove the wires. -
Power steering pumps and racks on Subies seldom go bad. Is it possible that you may be low on P/S fluid? Can you go into detail about the particulars of your stiff steering? Under what circumstances does it occur? Is it all the time, or once a week? A detailed description helps us better to help you.
I have a lot of aftermarket parts on my Subies. My dealer is not convenient to go to, and auto parts stores are conveniently nearby. If you buy the middle, to the top of the line parts at a parts store, they are good. Where trouble lies is in buying the low line cheapie parts they sell. The cheapie stuff doesn't hold up in my opinion, and results in some anti parts store negative press. BTW, anything made by Bosch has worked well in my Subies. Also, I have the impression that people on this forum that continually cry, almost demand that you buy OEM replacement parts exclusively, may be people employed by Subaru, or working at a Subaru dealer. If so, I can understand their bias. I think Subaru financially supports this forum, so I can understand their plugging their parts.
At age 66, I am on my third Subaru, and wife and I still drive 2 out of the three. Subarus are very dependable, will easily go 300K miles in a lifetime with proper maintenance. They are easy to work on.....the serpentine belt is up front behind the radiator, alternator is at the top front of the engine, starter is high on the back of the motor. The spark plugs are a little difficult to change, but seldom need changing. Brake pad changes are really easy. However, with high reliability, there isn't much work to do on the car. I have ridden in Volvos, and owned several Audis and VWs. All of which have very rigid bodies and suspensions in the European tradition. A Subaru won't feel quite as solid, but that is not a negative. They drive and ride well. All Subarus have symmetrical all wheel drive, which makes the car feel very planted with high adherence to the road. In rain or snow, they pull nearly straight as an arrow through anything slippery. Their type of all wheel drive is superior to that of other manufacturers for traction. My cars have no rust here in Indiana, but we prolly don't get as much snow, and subsequent salt added to the roads like you have. So, I am thinking all cars in your area suffer corrosion damage if not well cared for. Suggest you look on line for used cars available in your area at dealers to learn pricing. Also look on Craig's list for Subarus for sale. Happy car shopping, and join us here at USMB, if you buy a Subie. A lot of nice folks here, with lots of good advise.
JB Weld does a marvelous job of sealing up exhaust leaks. Maybe using it will make your exhaust system a little more quiet, depending on application accessibility. I have enjoyed your videos.......very informative and entertaining. Your work is indeed a labor of love bringing your 98 back to life. It is always a satisfying experience, when I have done this, and I am sure a satisfying experience with you as well. Please continue to keep us posted on your work progress.
Glad to read another Trans-X success story. I originated this thread about three years ago. I agree that the slight clunk is prolly from PO reving the motor to get it to engage a forward gear. Subie tranies are built tough, so your trany may give you many more miles of service. It has been my experience to fill and drain the ATF with 2-3 miles of driving between changes to mix old and new ATF. Add a can of Trans-X on the last fill. Reason for the 3 changes, is that only about half of the ATF can be drained from the trany at one time. The remainder stays in the system. After about a year to a year and a half, the trany will start to get lazy again about shifting into Drive. A drain and refill with ATF and another can of Trans-X will restore to quick Drive engagement. A nice buy for $1800, and only 80K on the odo. Enjoy your new ride!
Evap ?
Rooster2 replied to john40iowa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Is your thought of using Bondo to forestall further rusting?? If that is you want, I would simply buy a can of fiberglass resin. Then after cleaning off as much rust as possible with a rag, I would simply use a paint brush to paint the resin on. The resin comes with a hardening agent that you mix with the resin to get the resin to harden up. Once the resin hardens up, the metal that it covers will no longer be exposed to air, salt, whatever, and will no longer rust. I just stopped a CEL light from displaying a code for evap control system on an Oldsmobile by buying a new gas cap. The counter guy at AZ advised this fix, and it worked. Surprised me that a new gas cap fixed the problem. I hate to think what a dealer would have charged to diagnose, and sell me a new gas cap. -
The only reason that Subaru installs the heat shields is to prevent a grass fire should you park in tall very dry grass. Which, I am guessing is almost never. Unfortunately over time, the metal heat shields crack, then when loose, it vibrates to make that shrill buzzy sound at certain engine rpm......very annoying. I prefer to drive my car up on ramps, then have someone hold the gas pedal down at the right rpm to make the noise. From underneath, I identify the offending shroud, then with a hammer, I drive a bolt in between the shroud and the pipe as a wedge to stop the shroud from vibrating. It is a low tech solution to a low tech problem. Good luck on your fix!
The difficult part is cleaning off the old gasket off both surfaces. The old gasket is a bear to remove. It really bonds itself to the metal surfaces. A rotating metal brush head on an electric drill is the best way to remove the old gasket. Gentle work with a putty knife helps also to remove the old gasket. Just don't grind or gouge into the metal. You want smooth surfaces afterwords. PB blaster won't work. Replacement gasket is sold for pan replacement. I don't think that using only a sealant will work. Pan replacements are very prone to leak. I know mine leaked, and became a pain in the butt to stop the leak. Simply snug up small 10 MM head bolts upon reassembly. Don't super tighten, or you will bend and distort the pan and cause ATF to leak. Adjusting the linkage is not really an adjustment on automatics. Just look to see if anything is bent or binding with the shift linkage at the trany. If linkage looks okay, don't mess with it. Bending the linkage when it looks correct will just cause more problems.
Yea, you are correct about "real test is on the road." A 2.5 Gen 1 motor with bad GHs will idle all day, and not over heat. However, run it at highway speed, or drive it up hills, and it will over heat rather quickly. I will keep my fingers crossed that your HGs are good. Nice job of cleaning your headlight lenses. What product did you use??
I don't know the specifics on your 2006, however, when changing coolant on my 99, I pull and drop the lower radiator hose. Coolant will drain out fast. I run the engine for a short period of time to pump out coolant in the engine block. Just don't let the engine over heat for lack of coolant. When changing coolant, I also change the thermostat at the same time, even if the existing thermostat is not causing problems. Just remember to give the cooling system a good burp, when adding new coolant. I also use a garden hose to run water through the radiator, and thru the motor until the water runs clear, then reattach the hose, and refill with coolant.
Suggest drain and fill 3 times on the ATF, as only about half the ATF will drain at one time. The remainder stays in the torque converter, and won't drain out. Drive 2-3 miles between drains to get a good mix of new and old ATF available to drain. The old AT pan gasket will be nasty to remove. It really needs to be ground off, but be careful not to grind metal off any surface. Maybe removing pan dent and adjusting linkage will help. Did your tranny problem start immediately after hitting the rock? Crazy radio sounds like a wiring short. Pull out the radio, and check power wire going to the radio, maybe it is loose or frayed. Also, maybe the radio has just gone a bad with an internal short. You can prolly pick one up for cheap at a wrecking yard.
