Rooster2
11
Everything posted by Rooster2
98 gt woes
Rooster2 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I hope your luck improves. -
My OBW just started leaking oil badly. I had no leaks, then a bad leak developed quickly. I crawled underneath to see it is not leaking from the drain plug, or from the oil filter. The oil pan cover seems okay. It seems to be from the front of the engine. It is too cold and windy today to take off the cam covers, but suspect the leak is from there. Maybe the oil seal?? I will pull the cam covers off tomorrow to check. Are there any other suspicious places to look for a massive oil leak?? Thanx!!
Wouldn't a bad plug/wire cause a misfire based CEL? Yes, very likely to cause a CEL, but still a possibility that previous owner went cheap with low cost plug wires and spark plugs. If so, the cheapies don't hold up well. Pull a spark plug, identify manufacturer, and part number to see if from a quality manufacturer. You don't want to see that the plugs are made by Champion or Autolight. They don't work well in a Subie. Best to see that NKG plugs are in use. Probably impossible to identify manufacturer of plug wires, however, does the wire set look robust with thick diameter wires?
No, the fuse changing to 2 wheel drive still does not permit towing with 2 wheels on the ground. Flat bed towing, or towing with car on a trailer with all wheels off the ground is still needed.
- 5 replies
- outbacklancaster
- tow
(and 3 more)
Tagged with:
problem 1.....how long since spark plugs and plug wires been installed? Bad wires in particular can be okay at park when revving the motor, but spark will break down under load of driving. Recently I had a wobble in steering that turned out to be fixed by replacing a half shaft that had a blown out outter rubber dust cover. Check your half shafts for that problem. Does howling noise sound like it is coming from the front or rear of the car? A bad wheel bearing will sound like an rrrrrrrrrrrrrrrrrrrr sound, and will get louder if the bearing is bad at the front and stressed, like when exiting a freeway ramp on a sweeping turn.
Agree with above. With 236K miles on the clock, I would be very reluctant to rebuild an engine with that much wear. A 2.2 motor is a nice swap, but what works is something back in the mid to late 90's. It is now a stretch to find a 2.2 that is still good, and worth buying and installing.that is that old.
thermostat definitely on lower hose. Good luck with the Blue Devil. I hope it works. Just my 2 cents worth........when my 99 Outback blew a head gasket, I did a lot of reading on the subject. The crux of the problem is that Subaru built the motor so that the top of the piston protrudes so very slightly out of the block at top dead center. Because of that, Subaru had to use extra thick head gaskets. The "extra thick" hasn't worked out real well. There have been several head gasket upgrades by Subaru to correct the problem. I think my 99 has the last upgrade. The chatter on this forum is that the latest head gasket is probably good for 100K miles, beyond that i need to keep my fingers crossed that the head gasket will hold.
- 38 replies
Recently had a slight pull to the right on 98 OBW. It wasn't much so put up with it for a while. Finally, had tires rotated, ball joints replaced, and 4 wheel alignment. Slight pull still persisted. Then noticed the outer right side boot was blown out on the half shaft. I had the half shaft replaced, and that fixed the slight pull. Sometimes, very difficult to find the source to correct the problem. Fairtax4me, I can fully understand your frustration. Glad you got yours fixed.
Sounds like it is key slot only problem you really have. Key slot lube should fix the problem. If at some time you have rusty latch unit on your tailgate, the latch "grip" will bind and stick upon pulling on it with your fingers, and then won't spring retract as it should. If sticking, spray with PB blaster, and lube well with spray grease. That will work for a while, until rust reforms, and then it is time to buy a replacement latch unit.
Sounds like you should have lubed the cylinders in the key slot mechanism. There is key slot lube that comes in an aerosol can with a tiny wand to squirt into the key opening. Has the broken part of the key stayed inside the key way, and blocking a new key from entering the key slot? Subarus are made with one key that fits everything. There is no trunk or hatch key that is separate. With my 99 Leggie, I had trouble with the latch unit on the hatch. It was rusty, and would jam up. I finally installed a new latch unit to fix that problem. Is this perhaps your problem as well?
If there is anything left of the rounded off bolt, I have taken an old 3/8" drive socket that is just slightly smaller then the bolt head. It will be a socket that I don't care about, and I will then hammer down the socket over the bolt head. Often, this will remove the bolt or nut. However, what remains in the socket may be difficult to remove, so have thrown away the socket with rusted bolt or nut inside.
Salt is the real killer. Under coating isn't done anymore. It was really made for sound deadening, not rust proofing. Your dad had the right idea of using oil as a barrier method to prevent salt from getting into direct contact with steel to form rust. Just like how a condom works. Washing the salt from the car helps a lot, but not too practical in the dead of winter when the temp is below freezing level.
