Rooster2
11
Everything posted by Rooster2
Years back, I had an Audi with a rattling cat. I ignored it, only to have the loose cat material clog the exhaust pipe. It was so much back pressure that I could only drive the car 45 mph. It would go no faster. The bad part was that I was 300 miles from home, driving on a Sunday afternoon from Cleveland to Indy. Impossible day and time to find anyone to work on a car. I drove home mostly on the berm of the interstate, dodging road kill, with my 4 ways on, with cars and trucks whizzing by me on the driver's side. It was a most miserable trip that I will never forget. The only savings grace is that I figured out at the time that the cat was the problem, and was sure that the car would not stall out in the middle of nowhere leaving me stranded. Trust me, if you know for sure it is a bad cat, then replace it. A cat from a family owned muffler shop that does torch and weld, and pipe bending repair, will install a new one on the cheap. It would be well worth it.
I have a 98 OBW with the same power antenna. I have not had to replace it, but, I have some thoughts........I don't think you are going to find an after market antenna assembly that will fit that odd shape body hole. Unfortunately, this pretty well mandates that you replace the antenna with a new power antenna that is OEM designed for Subaru. It will be costly, but it is prolly your best and easiest solution. Look around on E-Bay Motors in Subaru parts section for a power antenna unit. You just might get lucky and be able to buy one on the cheap. You might find a used one from a wrecking yard, or you could always drill a hole on the top of a front fender to install a universal antenna. It is also possible to drill a hole in the roof, and install the manual type antenna that is OEM Subaru. However, personally, I don't feel comfortable about drilling holes in a Subaru for any reason......... Just another break in the paint that allows rust to form.
I hang out on this forum, and read most everything. I have not heard of any(?) phase 2 head gaskets being replaced. It is the usual complaint of slight leakage of coolant out of the engine, that is corrected by Subaru additive to the coolant. This does not result in a road side break down with an over heated motor. So, I don't recommend kissing off a very nice 2002 phase 2 motor just because you can't verify if it ever had a head gasket issue. That's nuts. I'm thinking your Sub mechanic guy must have misunderstood your question. His "NO" answer must have been directed to the phase 1 motor head gasket issue. The head gasket replacement talk is always about the 2.5 phase 1 motor that over heats and causes the break down. This is the motor that requires head gasket replacement, or some guys just replace with the venerable 2.2 motor. BTW, I own and drive two Subies, a 98 and 99. Both are Phase 1, that I bought both used. My wife and I have put 50K miles each on both cars with no head gasket trouble. I don't know if the head gaskets were ever replaced. I bought both before joining this forum, and never heard about phase 1 doom and gloom until joining USMB. I don't consider all Phase 1 motors as head gasket time bombs. Sure, it is a reputation that I live with, but with timely coolant changes, and replacing the rad cap every 3 years, I have't had any trouble.
I too have never been very happy with NAPA. Prices always seem about 20% more then other auto parts stores, and their counter people seem none to happy to wait on walk in customers. I'm thinking that their business is really geared to sell parts to garages that call in for parts, then NAPA truck delivers the parts to the garage.
When you changed the trany fluid, did you do it 3 times, with drives between drains? That is what people recommend here, because a single drain only drains out about half the ATF. The other half stays in the torque converter, and won't drain out. Doing the 3 drain does a lot better job of swapping out old to new ATF. Be aware that the dip stick for the ATF measures a pint increment from low to high marks on the stick. A lot of guys make a mistake, and think it is a quart increment, and over fill. I know what you mean about the ez removal of the trany pan bolts. I simply gently snugged them up when I replaced a pan gasket. You don't want to super tighten, or the pan lip will bend to cause leaks. If there is a torque wrench spec for this, I am not aware of it. I hope somebody chimes in on this.
Yea, I would prolly do what is advised above. Just drive it till it dies with thick oil, like 20W-50W, and the Lucas bearing fix, and never change the oil again. I had a car like that, I called it my "Town Car," meaning I wouldn't drive it out of town, and in town, only on city streets, never on interstates, and never venturing more then about 5 miles from where I live. When it finally broke down, it was no big deal. Maybe put some cheap brake pads on it, fix nothing else, and drive on as is.
Just a by-line to say that battery cable connectors do go bad. Just last week my car was driving fine with no issues. Then stopped for a bit, and could get no restart. The cars electrical system was completely dead. I traced it quickly to a badly corroded pos terminal. When I tapped on the terminal, the cable fell off the battery. This left me stranded with no way to attach the battery cable. I had no idea it was completely corroded, as the cable terminal is/was covered with a red rubber bootie, and out of sight. So, yea......check all battery and alternator wiring connections for trouble.
If it were me, I would return to the parts store with the new alternator. Ask the counter guy to test the performance of your current (old) alternator that is on your car. If your old alternator passes the performance test, then return the new alternator, and get your money back. Like previous poster said, check v- belt for tightness, as it could slip when wet. If so, just tighten the belt, or inspect the belt for wear, if bad, replace the belt.
Go to E-bay motors website, click on used auto parts for Subaru, year, and model. I just went there to check for you. Several tail lights are available for sale for both sedan and wagon. Cost is $35-$50 + shipping, or maybe less if you want to bid, but I am not sure if these are bid items. Read the ads carefully to determine if the tail light is for sedan or wagon, as that info is not easy to spot.
Whenever I buy a used car with no maintenance records, I begin changing the "wear" items on the car. I change the spark plugs, check, maybe replace the air filter, change oil/filter, and trany fluid. That way, I know they are good. Check your owner's manual.......it prolly will say Dextron quality ATF. To me, there isn't any company selling poor ATF, though others here may disagree. I really don't know of any great advantage using synthetic ATF, verses regular ATF. Prolly, the synthetic type has higher test (lube) values that would perform better in heavy duty application like racing or heavy towing, but for every day driver use, I would recommend the non synthetic ATF. It works just fine. On your car, there is an external ATF filter. I would replace the filter, when replacing the fluid. Don't recommend dropping the pan to change the screen filter. That is just a waste of time. You may want to pull the road wheels to check the wear on the brake pads. I think you will prolly need to change the timing belt and pulleys. Subaru says to change the belt at around 100K miles. Saying they were inspected, means they were not changed. At 109K miles, I am betting the timing belt is the original. It is important to change the belt, because if it breaks, you get stranded, and the motor gets bent valves. Bad valves are expensive to repair. Check for weeping coolant from the heads. Subaru sells an additive to the cooling system to fix this. Good luck and have fun with your new Subie!
I'm planning to give it to my girlfriend to run until it's dead, and it would be good to know what she's up against. I don't want to ruin the relationship Thanks again!!! I don't think giving the car to your girlfriend is the best of ideas. Guys don't necessarily care, but don't like a car to break down. Women are much more concerned about getting stuck with a car that breaks down. If fact they live in fear that a car may break down. Just my 2 cents worth.
Rather then swap out the gas tank, on other cars, not a Subaru, I have sanded and cleaned the leaky area around the seam very well, then used JB Weld to seal the leak. It has worked surprisingly well, but the air temp needs to be above 70 degrees F to get the JB Weld to harden, or do this inside a heated garage. The key is to get the area where you apply the JB Weld extremely clean, then let it harden up for several days before filling up with gas to where it was leaking. As far as the broken strap, I would use a large nylon cable tie, or a series of them linked together to form a strap. I would strap it around in several different locations to assure a good tie down. Have you applied PB Blaster, then let it sit for an hour, then use an impact gun on those frozen bolts, if you still want to do that. I bought an electric impact gun from Harbor Freight tools on the cheap. It does a surprisingly good job
Yea, I have heard of hand tightening, but always felt better tightening a little more with a filter wrench, or filter cap that fits over the end of the filter and is tightened with a 3/8" drive with extension. Hand tightening always worries me that I won't get the filter tight enough, and it will leak.
