Everything posted by Rooster2
2.5 to 2.2 converstion costs
Rooster2 replied to mtboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI remember that Subie engines were used in ultra light airplanes, but don't know if that was the earlier 1.6, 1.8, or the 2.2?
90 Legacy L overheating
Rooster2 replied to billtom's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAt the time of over heating, suggest you look to the inside of the radiator overflow container. If you see bubbles, then it confirms a bad head gasket. I have read where others having your problem, have loosened the vent screw on the opposite end of the radiator from the rad cap. Loosening that screw vents off some of the exhaust gas that accumulates in the cooling system, and helps the engine from not over heating. Some of the coolant is lost doing this. It's certainly a band-aid approach, but a consideration. I see that you are new on this forum, and glad to have you join us. There are many others on this forum that are Subaru pros that know a lot more about Subies then me. I am sure you others will have good advise for you as well.
Rooster2 replied to billtom's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had the same problem on a 91 Subie. It turned out to be a bad head gasket. Your 2.2 motor does not have a reputation of developing a bad head gasket like later model Subarus do, but none the less the 2.2 will blow a head gasket. The major clue was your saying that the heater blows cold air. That results from the bad head gasket allowing exhaust gas to enter the cooling system. Enough gas causes a big bubble in the cooling system. A big bubble does not flow through the heater core like radiator coolant does, so no flow, no heat. The hot exhaust gas also causes the motor to over heat. If the HG is not completely blown, you can prolly drive the car on short distance trips, and not at high speed. You must keep an eye on the temp gauge, it it starts to over heat, you will need to pull over and let the motor cool down. Otherwise, driving with an over heated motor, will ruin the motor, but I bet you prolly know that.
Front end shudder - warped rotors?
Rooster2 replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have had good results with Advance Auto Parts store ceramic pads at all four corners of my Subie. I bought their store brand ceramics. Price was reasonable.
IDLE Problems
Rooster2 replied to dhewitt85's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would add a can of fuel injector cleaner to the gas tank. Use the good stuff costing $6.00+ The cheap stuff is mostly alcohol, and doesn't help much.
Rooster2 replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes sound like rotor warpage. Do both rotors need turned when this happens? If it is only one rotor, then I would suspect that one brake is slightly dragging due to a caliper piston not fully releasing pressure from the rotor, when your foot is off the brake. If that is the case, replacing the caliper should solve the problem.
A few coolant questions -- 98 OBW
Rooster2 replied to Kwhistle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think all brands of antifreeze will work in a Subie. Just so many cars now with aluminum engine components that all mfgers. make antifreeze compatible with aluminum. I use Wallmart's house brand with no issues for years. Even says on the label that it is compatible with all engines. 20 to 30 years ago, there was a compatibility problem, but now solved. Orange stuff in the cooling system is a mystery. Maybe PO put an additive in to address HG or leaking rad or heater core.
Fog lights
Rooster2 replied to lesstutrey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am thinking that driving lights can not be wired up to existing wiring to headlights. Driving lights pull some strong amps that the existing headlight switch, wiring, and fuse system are not designed to handle the higher amperage pull. New wiring, in line fuse, and dash mounted switch is the way to wire up driving lights.
Updated squealing noise
Rooster2 replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, the heat shield can not cause a CEL to come on. The heat shield has nothing to do with the operation of the car. It's sole purpose is to prevent a grass fire should you ever pull in and park in an area with high grass and weeds. The heat shields prevent the weeds from coming into contact with hot exhaust pipe, which could cause a fire.
set gap on plugs
Rooster2 replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI use the Bosch Platinum, single electrode model. They never need to be gaped before installation. With such a hot spark going to plugs these days, I don't think that gaping is that important anymore. Seems like anything that I have bought already has a decent gap as set at the factory. Plugs that I pulled out of my OBW with 148K miles were very widely gaped from wear, and had to be way out of gap spec, but still performed well enough.
SOS 105 Mile sparkplug removal???
Rooster2 replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had similar problem, a few years back when I replaced the plugs after buying a used 99 OBW. Pretty sure the plugs and wires were original, with 148K miles on the odo. The wires seemed shrunk wrapped to the ends of the plugs, and the plugs nearly bonded to the heads. I had to rip and tear the plug wires off in order to get a socket to go over the plug. Same result you had, kind of a creaky sound caused by rust and corrosion. I think that is called galling. Once I had a plug break loose, then I would slowly loosen, then tighten, then loosen a few times to finally be able to unscrew the plug. Just take your time, and slowly remove the plug with out torquing the drive handle at an angle. Upon replacement, I used antisieze cream to lube plug tightening, and to prevent galling in the future for plug replacement.
98 LGT limited :D
Rooster2 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- 98 LGT limited :D
Rooster2 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks really nice for $400. It is a Limited, so it has the leather interior. I have same in a 98 OBW, those seats are so comfortable. They do require some cleaning and conditioning to keep from cracking. Dropping in a 2.2 is a good choice. When replacing the TB, suggest you replace the tensioner pully as well. You don't want the old one to sieze up on you.- How do you open up the brake calipers?
Rooster2 replied to nickolai's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI disagree on opening the bleeder when retracting the caliper piston. That is unnecessary. Keep the bleeder closed when tracting the piston, will push the brake fluid back through the line to the m/c reservoir. The fluid level will rise slightly in the reservoir. If the reservoir is already filled to the max level, then remove the reservoir cap, and wrap a rag or paper towel around the reservoir to catch any over brake fluid flow. The bleeder should be opened only when you want to drain dirty brake fluid from the system, and replenish with new. Otherwise, you make work for yourself at pad changing by having to bleed air out of the line.- Preserving an 08 Legacy for 2.5 years?
Rooster2 replied to subie25's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLots of rats???............oh that doesn't sound good at all. All rodents like to chew on wiring to sharpen their teeth, and build nests everywhere. I hate to think what damage they could do to your car's wiring under the hood, or seats if they get inside the car. I have seen what damage mice can do over one winter to the interior of a car. Rodents can enter the interior of a car via the smallest of openings. If they can squeeze not much more then their noses into an opening, they can wiggle the rest of their body through the opening. Any chance of parking the car elsewhere for 2.5 years? Irregardless, if it were me, I would consider selling the car, and buying another car after 2.5 years.- Securing an aftermarket radiator (97 Legacy GT Wagon)
Rooster2 replied to dldunckel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree with you, but like said, it was an aftermarket radiator added to an old Subie with 200+K miles on the odo. The holes just did not match up. However, I think the car will find its way to a wrecking yard before flexing with the chassis takes out the radiator due to cracking. It prolly would have been a good idea to wedge some rubber between radiator and chassis, before cinching together with cable ties.- Securing an aftermarket radiator (97 Legacy GT Wagon)
Rooster2 replied to dldunckel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had the same problem some time back. My problem was that the mounting holes did not match up. I secured using nylon cable ties. This worked just fine in securing the radiator tightly, but I wasn't proud of the red neck look. So, you might try this approach. It is important that the radiator be tightly secured, otherwise it can cause rattles, and the flexing can eventually cause the radiator to leak.- How do you open up the brake calipers?
Rooster2 replied to nickolai's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe caliper bolt I am referring to is the one bolt that secures the caliper to the bracket on the lower side mount. On the upper side mount is the slide pin that lets the caliper rotate up and out of the way to be able to change the pads.- weird brake problem 95 leg awd
Rooster2 replied to bigpimpinben's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree that there is a caliper problem. Either the caliper is bad, and not releasing, or like said, the hill holder is partially engaging the caliper on a continual basis. Even with a new caliper, it could still be bad. Especially, if it is a rebuilt unit from Autozone. I buy a good amount of stuff from Autozone, even though some of their rebuilt stuff sometime turns out to be junk. However, they always stand behind their product with a good lifetime warranty, and will replace what they sold you without hassle at no cost. I would take the caliper, rotor, and pads back for free replacement. Upon installation, make sure the hill holder mechanism is either made to work properly, or fully dismantled. I don't think anything with bearings would be causing your problem.- How do you open up the brake calipers?
Rooster2 replied to nickolai's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just replaced the pads on the rear of my 98 OBW last Sunday. I had used anti-seize cream on the lug studs, caliper bolt, and caliper pin, when doing the last brake job. This made everything come apart so easily for pad replacement. Add some cream to the slides that the pads move on is also advised. I can't believe a caliper bolt backed out, and fell off. Someone must not have tightened the bolt during the last brake job. Also be aware, that the caliper bolt fits the two threaded holes in the rotor facing to facilitate rotor removal. Simply screw in the bolt, and the rotor backs out and off for ez removal. Subaru was so smart to think and design this.- Car and Driver article
Rooster2 replied to Chip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgood informative article........thanks for posting this here.- 93 Legacy AT filter or screen?
Rooster2 replied to SubaruFred's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am the guy who wrote the original thread about using Trans-X on this forum. It has been a god send to people with years 99 & 00 auto tranies, that have a particular shifting problem due to a defective seal. However, you don't have this problem, so I would vote NO on using Trans-X. Like you stated, you don't need seal added conditioners that Trans-X provides. Recommend three successive ATF changes for your car, with short drives between drains. You will need to do three, as only about half the ATF can be drained from the trany pan at a time. The remainder stays in the torque converter. Others have removed a fluid return in order to bleed out all ATF at one sitting with the motor running. If you do this, just be sure to stay ahead of the bleed out process by adding fresh ATF during the bleed, so the trany does not run low or out of ATF.- Aftermarket Fan = Dead alternator?
Rooster2 replied to EastCoastEJ22T's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit is just coincidence. Replace the alternator, 10 volt output tells the story. It's shot.- 91 Subaru won't even start...
Rooster2 replied to knor91's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would suggest you check the obvious. Are you sure the new battery is charged? They usually are, but no guarantees. I have bought more then one battery that was new, and really low on water that created starting problems, so check the water level. I would put a charger on the battery to see if it needs charging, or first try jump starting the car. With battery cables connected for a jump start, see if your car's lights will come on before turning the key. If your new battery is totally dead, a jump start may take 5-10 minutes before enough juice is built up in your battery to start your car.- The mentality of Subaru
Rooster2 replied to Allpar Mod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTim Mahoney is a sharp marketing guy. When you are a small fry auto company, and Subaru certainly is, you gotta find or develop your niche in the auto industry. To me it began when Subaru made a corporate decision in the early 90's that their entire product line would become all wheel drive. This made them different from Honda, Toyota in particular, as the car to drive where and when the weather gets slippery. Back that up with a continued well engineered and quality made product at a reasonable price, and sales will climb, and that they have. Add to that, a loyal customer following that continues to buy new Subarus, and spreads the word to their families and friends, who in turn buy Subarus. I still would like to see Subaru bring out a small sports car that would compete against the Mazda Miata. There have been pics in the last couple of years of that possibility with a Toyota concept car with Subaru drive train. How cool would that be to see that car or very similar badged car as a Subaru. I am thinking that Subaru could make some money with that product. Share the love..........it's a Subaru. - 98 LGT limited :D
