Rooster2
11
Everything posted by Rooster2
I have always used a high quality injector cleaner additive to the gas tank. Chevron Techron is very good, as well as one sold by Lucas Oil. The good cleaner additives cost $6 to $7/bottle. Avoid the cheaper cleaners that sell for less. They are mostly just alcohol, and don't work well. I keep thinking about how your motor is misbehaving, and can't help but think that it must be something simple, and prolly inexpensive to fix the problem. Otherwise, the motor would not rev up and run well and strong at high rpm. I hope pulling the codes tells you exactly what is wrong. PO saying the problem is misfire, may or may not be accurate. You have no way of knowing if he was telling you the truth. Yea, it could be the injectors, but maybe something simple like a sensor. But, I see that you replaced possible problem sensors.
Since you see the plugs are soaked with black gas/oil, I agree with you that you are not getting spark to the plugs. If you haven't done so, check to see that all plug wires are on correctly, and are plugged in properly to the coil pack. However, I am thinking that you have already done this. Swap out coil packs, if you have access to one. Any chance that you accidentally crossed plug wires on reassembly to 1 and 3?
It is a 1.6 never mind the performance Had four Rotarians from Holland visit our Rotary Club in Zionsville, IN last summer. They put on a good power point show and tell about Holland that was very interesting. I remember seeing some interstate roads in the presentation, but most appeared to be 2 lane slow driving roads, so I guess your 1.6 motor is sufficient. The group also said that gasoline cost was about twice as expensive or more compared to the US. No wonder you use direct injection propane.
Changing the ATF three times get rid of all the old fluid may help, as each plug drain only drains about half the ATF from the system. Then drive around some between changes. Then, add the Trans-X at time of third and final ATF change. Hmmmmmmmmm....guess also that Trans-X could be added before ATF changes to clean out gummed valve body. Just drain out a pint of ATF before adding Trans-X.
Your '95 would have had the 2.2 motor, which is a non interference motor. So, when the timing belt broke, it would not have damaged the valves or pistons. A simple belt replacement would have put your car back on the road, if that was its only issue. I would suggest you look around on Craig's list, or E-bay for a used Subie. If for sale by owner, ask to see the service receipts on the car to see what repairs have been done. You may also want to do a Carfax on a car to learn about its history. I think it is difficult to tell if a motor was half cooked from over heating before head gasket replacement. I simply listen to the motor at idle, and at speed for any strange noises, and see if the motor has good responsive power during a test drive. I also try to test drive for an extended period of time to see if it wants to over heat. As far as Subie wagons go, the Impreza OBS is narrower and shorter then a Leggie wagon or Leggie Outback. In my opinion, the Leggie's extra room is the better choice of the two sizes, but that is only my opinion. Drive train is pretty much the same among all Subarus. Good luck on your car search!
When my knock sensor went bad on my OBW with the 2.5 motor, the CEL would come on, then turn itself off, for varying period of times. It is a rather easy do it yourself replacement job. It is kinda hard to find, if you don't know where it is, and what to look for. Assuming you know what to look for, it is best to use a wobbler and a short extension on a 3/8" drive to R & R. The reason for this, is that there is not a straight shot with a drive and socket to reach the sensor to remove it from the block. Using the wobbler, you can reach the sensor from an angle. Upon installing the new sensor, take care to not over tighten it. Just snug it up, to avoid damaging it. If you are talking the equivalent of $180 in USD, then that is expensive. Here in the U.S., I am thinking I bought mine for about $80 out the door about 3 years ago. You should be able to buy a knock sensor on line at a reasonable price. You can continue driving your car with a bad sensor for a while. However, your fuel millage and performance will suffer a little. Good luck on getting this repaired.
help
Rooster2 replied to alleos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Welcome to this forum. Lots of people willing to help you here. Suggest on any future thread that you write, to be very specific to describe what your problem is on the title line. You will get more people to respond to you that way. Simply titling your thread as "help," doesn't say much. Swap out the intake, putting 97 intake on 95 motor. Should bolt up. I am thinking the wiring harness can't be that much different, though I really don't have hands on experience on 95 or 97 model. My guess is that the wiring may just have different style connectors. That was the issue I had when I swapped a 2.2 from a 92 into a 91. -
If it were me, I would go to a shop that has a good reputation for doing front end alignments. Have the front end aligned, and have the entire front suspension checked for anything worn which could cause any "play", like bad ball joints and tie rods. +1 also on bad half shaft as a possibility. I had that happen on my OBW. It shook like crazy for a few miles on the interstate one day, but then the shaking went away, and never returned. Then the half shaft started making some noise, so I swapped it out. Now no noise, and no shaking.
Disagree about dropping the trans pan. I did that only once to learn that was a mistake. I found very minimal metal particles on the magnet, and fine mesh screen was absolutely clean. So, dropping the pan accomplished absolutely nothing. Then the fun began. Cleaning off old gasket is really a nasty job, prolly best done with a dremmel tool. Then upon reassembly, it is really difficult to keep from having a pan leak, no matter how nicely you torque the bolts. Simply use the drain plug to drain old ATF, or pull a return line to pump the old ATF out. Just my 2 cents worth.
Glad to hear that the ATF change and Trans-X have improved your trany performance. I hope the slipping issue is behind you. Nice pix on your 92. I had a 91 that was the same color as yours. In fact looks the same all over. I miss those nice mouse fur fabric seats that I bet yours has. They were so compfy. Much better then my current 99 OBW.
Be aware if you are unaware, that your Subie has a drain bolt on the bottom of the trany pan. Draining fluid will only drain about half the trany fluid in the system. The remainder stays in the torque converter. To do a good fluid change, suggest draining, filling, then drive for 5 minutes between changes. Do this routine three times. Don't drop the pan cover on the bottom of the trany. The little screen mesh never gets clogged inside the pan cover, and then it is a bear to clean off all surfaces when reinstalling the pan cover. Then, really difficult to prevent fluid leaks from the pan. It is possible that the quart of extra fluid in your trany is causing your problem. It may be foaming, and not lubing your trany. Be aware that low to full mark on the ATF dip stick is only about a pint of trany fluid. So, easy to over fill it. I bet that is what previous owner did. Keep us posted on your progress.
1st, i prefer to buy locally vs online for some things, tires being one of those things. Same thought, I buy locally. By the time you buy tires on line, then pay the shipping cost, the overall cost works out to be about the same, as buying locally and paying the sales tax. I don't think that Subarus are any different then any other car as far as tire needs is concerned. I remember reading that Subaru AWD is about 90% front wheel drive, and 10% rear wheel drive. So rolling wise, not that much different then any other car. I personally like Michelin tires. Expensive, yet always perform very well, and can wear for 80K miles. In the long run, cost per that many miles makes them an excellent value. Never had an issue ever with Michelin tires as far as tire balance or quality.
