Rooster2
11
Everything posted by Rooster2
Do the cats and exhaust system need to come off the car or can a competent welder do it with the car on a lift but everything still in place? I have not done the welding work, but watched my local cut/chop/weld muffler shop work. They work with the car up on a lift, with the exhaust system attached to the car, then use a support post to hold up and support the pipes in place for welding. The support post works just like a jack stand to hold the pipes up. The welder does have water available to spray around the welded area to cool things off, should the bottom of the car get too hot.
Reminds me when I was a kid. I wanted a loud exhaust system, so people could hear me coming. Like mentioned, a straight through system will give a little noise, without being super loud. Suggest not buying one of those extra large chrome mufflers attached to the exhaust at the rear bumper, sometimes known as a "fart can." All they do is magnify the exhaust sound, and what comes out just sounds extra loud and really boomy. You prolly have seen and heard them before. Their racket really attacks the cops. Be sure to tell your son that, even at a young age, he will realize that he doesn't want to be attracting unwanted attention from the cops.
I can understand your logic using expanded foam. However, treating the metal with chemicals before body assembly is more practical. I have owned two Audi 5000s from the 1980's, and they simply don't rust anywhere. Pulling off a door panel, reveals massive rust proofing that is not found in Subarus. At the time, I lived in the Cleveland, OH area, and they use plenty of salt on the roads there. I don't know what Audi uses, but they found a way to make cars totally rust proof.
I certainly understand your frustration regarding DFE. I am the guy, who wrote this original thread. I am not bragging, but so far Trans-X has continued to work well for me after 2 years and 30K miles of driving. You talked about draining and adding new ATF. Did you add and drain three times, with maybe 5 minutes minimum of driving between ATF changes? I ask this, because a single drain of ATF, only drains about half the ATF from the system. The three drain and fills does a better job of getting rid of old ATF. Maybe it is worth trying that, and adding a 15 oz. bottle again of Trans-X to your trany. If you trade, I hope you consider another Subie. The DFE only affects cars in the late 98 thru 2000 model years. After that, no trany problems.
Yea, too many shops want to convert a $50 repair job into a $500 repair job. They just don't want to let any customer out the door without paying hundreds, no matter what the job to be done. They even try hard to find something else that they want to fix. It seems worse at dealerships, or chain operated shops. It is all about greed, and covering expensive over head. The worst seem to be Firestone and Goodyear auto repair, and Midas muffler shops.
If you are wanting to fix the exhaust system, so it passes inspection, so you can sell it, then I would suggest going to a muffler shop (usually family owned) that does cut and weld. I recently had similar problem, shop used a saws all to cut out the rusted pipe that had a hole in it, then welded in a new pipe. Cost out the door was $46. They should be able to weld the pipe to the muffler with no concern about the condition of the flange.
99 4spd AT
Rooster2 replied to Suba9792's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yes, the AT tranys are reliable. Just remember the car is for your wife. If it makes her happy, then it should make you happy. $6,500 is a whole lot of money for an 11 year old car, even if low mileage, and very clean. Suggest you check Edmund's, NADA, or even Kelly blue book pricing guides to see what car should be selling for. Info is available on line. -
To prevent stuck caliper pin/slide problems on future brake jobs, I lube up the pins and bolt threads with anti-seize. I even put it on the facing of the rotor that meets the back of the road wheel, also on the threaded studs for the lug nuts. It doesn't take much extra work to do this, but eliminates in the future all the stuck pins and bolts headaches you guys are describing.
If you have any wire arcing, then your wires are bad. Subie OEM wires are good, but not impossible to have them go bad. I use Bosch wires on my OBW. They have been on the car for 4 years, and still performing well. I bought them at an auto parts store, which is a lot closer to where I live, compared to going to the Subie dealer. Avoid the cheapie wires at the parts stores, they just don't hold up.
What a joke they have for a police force. Next thing you know, they will think you had something to do with the armed robbery, since it was your car used as the get away car. I can't think of any better advise, except to keep calling them. Somehow, you need to find the right person (mentor) in the police department, who can move the paper work, so you can get your car back.
