Rooster2
11
Everything posted by Rooster2
brake pads
Rooster2 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I just installed Advance Auto Parts (house brand) ceramic on my 99 OBW. Price $43. I wouldn't be surprised if they aren't the same as the AZ Duralast ceramics. They perform just fine, at a good price. -
If not rusted to oblivion, I would install the rusty rotors, and drive ez for a while, and let the brake pads sand down the rotors. If rusted badly, it is best to remove the rotors and get them turned. There are two bolts that hold the rotor in place. They can be difficult to remove. Suggest you use some PB Blaster, and wait a half hour or so for the Blaster to loosen the rust. I just replaced my front rotors this past weekend, so the rusted in place bolts are fresh in my memory.
I can understand your wife's emotional attachment to her Subie. All of us here on this forum have the same love affair with their Subie. However, the reality is that you are calling it a rust bucket with 229K miles on the odo, with bad HGs. This presents a picture of a very tired car that is not worth repairing. If it were me, I would think that future time and money would be best spent on upgrading to a better car, and let the Brighton RIP in a wrecking yard.
If, as you say the Continentals are a "soft" tire, then they would grip well as stated in their name, but I gotta think they won't last for long millage. Since you hate "vague steering," your best bet is to buy a tire with a strong and rigid side wall. The less the side wall flexes, the more responsive the steering. The trade off is that the stiffer side wall produces a rougher car ride.
I still think your problem is in the amplifier. I had a radio once that lost the right channel totally, while the left channel still worked. Changing speakers did not fix my problem, so that told me that the amp was bad. I suggest replacing the system where the amp is located.That is prolly the unit with the radio, the CD head unit is prolly a separate unit, and is still good.
Pulling off a door panel is not difficult, even if you have never done it before. It is pretty ez to figure out. From your write-up, I don't think that your speakers are the problem. I am assuming that your replacement head unit uses the same amp as the original. Does AM/FM radio play through the system? If so, is sound distorted when playing the radio?
Yea, it could be the amp, or a bad board level component. It may be more trouble then it is worth to try to figure out, let alone repair. Well, repair is not really an option either. CD players, car radios, and all consumer electronic products are really disposable products. When they break, they get thrown away, as there are not shops around to repairs them. Unfortunately, my advise, is that it is time to replace with a new unit.
If you have narrowed it down to a weak alternator, then simply replace it. I have had good luck with Autozone alternators. All have performed well after many years and miles of work. I also like their lifetime warranty, if I ever get a bad one, they will replace it for free. Just be sure to keep the sales slip. Subie dealers don't offer a lifetime warranty. It is a very easy swap out to install a new one. Even if you have never changed a Subie alternator, it is really easy to figure out which bolts to remove. The adjuster bolts make tightening the belt very easy.
I agree with above advise. If it is your tail gate squeeze handle that is "sticking," then lube it with spray grease to free it up. In my case, this worked for a few months, then the rust would return, and it would need greased again. Finally, I replaced the squeeze hand unit last year. Subaru part number 62150AA211. Cost $22, plus $10 to ship, from Lee's Summit Subaru in Missouri. Their website is: http://www.leessummitsubaru.com. Other on line car parts stores prolly sell as well. Installation of new squeeze handle is rather easy. Suzanne, this is a rather common problem with Subaru Legacy/Outback wagons. If you check the archives here, you will see a bunch more written about this problem and fix in previous postings.
Yes, I have to agree with you, that you will be fortunate to get $100 from a wrecking yard. The yard will know that they will have trouble themselves parting out the car that is not in hot demand. Most likely you will only get scrap metal value. When it comes to parting it out yourself, you have to think of yourself as a one man wrecking yard, that has only one car to part out. Yes, this can be done, but it is time consuming, as others have said, you will need to get some publicity to tell people what you have. List what you got on Craig's list under car parts, or on e-bay, or here at the USMB forum on the section listing cars and car parts for sale. You may also want to consider donating the car to a charity organization like Goodwill Industries, that conducts car auctions to resell donated cars. You will only be able to get a charitable federal tax deduction in the amount that the car sold for at their car auction.
A/C problem
Rooster2 replied to Flycat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
When the system is low on refrigerant, the compressor will cycle on and off in short bursts of about 3-5 seconds. If it were me, I would add another can of 134 refrigerant to see if that lengthens on/off cycle times, before swapping out the relay. You need to see if you can stop the small leak before adding refrigerant, or if it is just a very small leak, then adding the second can of refrigerant just might get you through the heat of summer before running out.
