Everything posted by Rooster2
91 lego Oil pan replacement.
Rooster2 replied to Dannomanno's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it is strictly an issue of your hands being large and in the way, yet there is still room to insert the bolt into the hole, try this: Apply something like a bit of sticky putty, chewed bubble gum, or window caulk to the inside top of your socket. The idea is apply a substance that will temporarily hold your bolt inside the socket to keep it from falling out. With your hands turn the drive extension, with maybe using a wobbler (if at a bad angle) with socket attached, then hand tighten the bolt (a few threads) to get it started into the hole. Then apply the drive handle to completely tighten down the bolt. The hand tightening gives you a lot better feel of correctly inserting the bolt to prevent cross threading, however, I bet you already know this part.
acceleration hesitation
Rooster2 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks Legacy777, both good ideas..........Rooster2 (Larry)
Rear sprayer sprays when accelearting
Rooster2 replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am thinking your pump is bad, if not pumping. Pull the output line at the pump, then have a friend operate the switch, and you watch for water output from the pulled line. If nothing happens, then your pump is bad. Also, may want to look at the fuse, it is possible that the fuse is blown.
Brakes go out, pedal goes to floor, MC replaced
Rooster2 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would have replaced the MC as well to fix the problem. Since you have bled the system, all should work. If you replaced with a used or rebuilt MC, there is a chance the "new" MC could be defective. Are you finding any rust on the brake lines that is severe enough to cause even minor fluid leak? That could be why the brakes are weak.
I have a 99 OBW. Recently it has decided to slightly hesitate or stumble upon acceleration from a stop for the past month. Once above 20 mph, it runs great. I am thinking it is a fuel problem. With my previous tank of gas, the problem went away. Now with new tank of gas, it is back again. Anybody with any thoughts? Good to see USMB back again after being down for a week. I suspect a hacker created problems, or maybe it was down time for maintenance and upgrade. Anybody know?
My first legacy! Lots of pictures!
Rooster2 replied to crazyman03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had this problem on a 91 Leggie. Finally got it super tightened, and used lock tight on the bolt threads to keep the bolt from ever thinking of backing out.
Knock sensor- is my mechanic trying to rip me off
Rooster2 replied to tjxtreme's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYES, big time gouge on your wallet from that shop. If it were me, I would never go back there again!
Which o2 sensor?
Rooster2 replied to GEORGE G's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you buy and 02 sensor, suggest you buy one with the correct electrical connector. I have never had any success buying a generic sensor, and soldering the old connector to the new sensor.
1st gen legacy tires
Rooster2 replied to Markus56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy suggestion is to go with 195X75X14. It will be a little taller, without running the risk of rubbing front wheels when turning and hitting a bump at the same time.
92 legacy thermostat questions
Rooster2 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSuggest you post above as a new thread. You will get more response to your question.
grease squirting out of outer tie rod end boot
Rooster2 replied to Kwhistle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am thinking that squirting out a little grease is not anything to worry about. However, try yanking back and forth on the tie rod to see if there is any wear that has created "play" or looseness at the joint. I rather doubt that you will find any play, but if so, then consider replacement.
97 Outback seeping oil
Rooster2 replied to johnny9k's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1 on above. I have a 99 that leaks oil from somewhere, prolly mostly valve covers. With high mileage and age, I have a hard time justifying time and money on tear downs just to fix minor oil leaks. With my last oil change, I aded a pint of oil stop leak, and it has helped a lot. My oil drips on the drive way have practically ceased. I will prolly add a pint of stop leak at all future oil changes.
Knock sensor from ebay any good?
Rooster2 replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen doing the swap out, suggest using a wobbler between your drive extension and the socket, as the securing bolt cannot be removed on a straight line set up. Also, just snug up the bolt on replacement, as over tightening will break the plastic sensor unit. Good luck on this project. Hope it eliminates your CEL, and your car runs better.
A/C system pressure/capacity
Rooster2 replied to bosango's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSince R-12 was declared environmentally unsafe, I have to think the switch to R-134a must be good for the environment. I would be concerned about adding something else to a system designed for 134a.
EJ22 to 97 OBW swap update
Rooster2 replied to tricked919's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would have concerns regarding using a quart of ATF to replace a quart of oil. Yes, ATF would certainly lower the oil viscosity to some degree. Why would you want to use ATF as a substitute for motor oil? Are you thinking that ATF is a way of adding detergent quality to the motor oil? In my opinion, I would instead be more inclined to change oil every 3000 miles to keep the engine clean.
First-time brake job questions, '02 Legacy
Rooster2 replied to FreeLegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen I replace brake pads, I find something to rest the caliper upon while replacing the pads. Usually, it is an old cardboard box. The idea is that you don't want the caliper to "hang" down from the brake line. Rubber brake lines aren't designed to support the weight of the caliper. I agree with others, you don't need to replace the rotors if they have not been producing vibration or pulsing, when the brakes are applied. I used to live in the Cleveland area (Strongsville), so I remember that a lot of salt was applied to the roads. Suggest you spray the caliper bolts with PB blaster and wait a while for the liquid to soak in. Otherwise, the bolts may be rusted in tight. Suggest that you also replace (bleed out) the brake fluid in your braking system. If it is the original since 02, the fluid is prolly pretty dark and nasty looking. Brake pads from an auto parts store don't cost much. Suggest you buy their better pads, but not necessarily their best pads. Good luck on your brake job! Larry (Rooster2)
Washed motor and......Fixed!!! WOO HOO!!
Rooster2 replied to SubieDaddy80's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have had this happen before, prolly moisture on wires and connectors. Suggest you let the motor idle to get hot, or at the least open the hood and let the sun beat down on the motor for several hours. Once dried out, car should run normally.
New to the world of Subaru -- just got a 1996 Impreza Brighton and asking for help
Rooster2 replied to kickascii's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it were me, I would install new spark plugs and wire set to fix the slight miss problem. If that doesn't fix it, I would add a can of injector cleaner to the gas tank. Use the good stuff that cost about $6/can, like Techron. Anything cheaper won't work well in my opinion. I have used aftermarket half shafts from auto part stores with no problems. However, others have had problems. At a consumer cost of about $65 per axel, I don't think the axle rebuild companies spend much labor time, or install many new parts to complete a rebuild. I suspect they mostly clean up the joints, add fresh grease, new boots, and call it a rebuild. I agree that your shifter bushings are prolly shot. I have never replace bushings, but don't think it would be that difficult. Others here can advise you on work involved. I don't know if the 2.2 motor in your 96 is a valve interference motor or not. Irregardless, you will need to replace the timing belt, and prolly some pullys to gain engine reliability. Otherwise, breaking a worn out timing belt makes for a bad day. Perhaps previous owner can tell you when the belt was last changed, or a receipt in the glove box can tell you that, and if changed not long ago, then the current belt will last you for a while. Prolly a good idea to look at the antifreeze in the cooling system. If the coolant looks dark and ugly, then best to drain, and flush, then add new antifreeze. Subies are long distance cars. Many owers are still on the road with 300K+ miles on the odometer. Have fun with your new car, and welcome to this forum.
My first EJ!
Rooster2 replied to Markus56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice car for little bucks. Suggest you change radiator caps. It is possible that a bad cap is the problem. Keep an eye on the temp gauge. If it is indeed a bad head gasket, it will drive fine for a while, then the temp gauge will very rapidly over heat. Just keep watching the temp gauge. If it starts to over heat, turn off the engine immediately.
Spark Plug and Wire advice
Rooster2 replied to RedRum's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have had good luck with Bosch wires and Bosch Platinum plugs. Don't recommend chain auto store cheapie house brand wires. They will give you trouble.
extra play in brake pedal OK?
Rooster2 replied to efseiler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid the dealer tell you why the caliper needed replacing? If brakes worked okay, then I can't image anything wrong with the caliper. Would replacing the missing bolt have fixed the problem? It would have required removing the road wheel to find a missing caliper bolt. Something just doesn't seem right about their doing this "service". I guess I am suspicious of going in for an oil change, then mechanics start doing unsolicited inspection work to find problems that they are so conveniently available to fix, unless of course, you requested this additional diagnostic dealer service. +1 on what others have said that the brake caliper has not been bled properly, so air is still in the brake line. A re-bleed on the brake line should fix this.
how does a '91 legacy measure up?
Rooster2 replied to crazyman03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBack in 91, Subies were made as front wheel drive or, optional all wheel drive. It wasn't until a few years later that Subie went to all wheel drive across the entire product line.
Rooster2 replied to crazyman03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI guess it doesn't run, if you are wanting to flat bed the '91. Is the flat bed rated to carry something as heavy as a car? Does the trailer have it's own braking system? What are you using to pull the trailer? It will be close, but think the Subie will fit the trailer.
What trannys will fit my 2000 outback?
Rooster2 replied to PMXER's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes your 2000 model have the fuse holder under the hood near the firewall on the passenger side? If so, check to see if there is a fuse installed in the fuse holder. If so, then the fuse is making the car front wheel drive only. Under normal conditions, the fuse holder does not contain a fuse to operate in all wheel drive. Let us know if there is a fuse there or not.
How Do I Figure Out My Build Date?
Rooster2 replied to SchwarzeEwigkt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you can solder it, then I would suggest using JB Weld. It is an epoxy that sets up rock hard. The trick is to have a very clean surface, and wait 12 hours before using after applying. I have used it successfully to seal up a leak in metal tubing on high pressure A/C line.
