Rooster2
    11
Everything posted by Rooster2
  1. I have had this happen before, prolly moisture on wires and connectors. Suggest you let the motor idle to get hot, or at the least open the hood and let the sun beat down on the motor for several hours. Once dried out, car should run normally.
  2. If it were me, I would install new spark plugs and wire set to fix the slight miss problem. If that doesn't fix it, I would add a can of injector cleaner to the gas tank. Use the good stuff that cost about $6/can, like Techron. Anything cheaper won't work well in my opinion. I have used aftermarket half shafts from auto part stores with no problems. However, others have had problems. At a consumer cost of about $65 per axel, I don't think the axle rebuild companies spend much labor time, or install many new parts to complete a rebuild. I suspect they mostly clean up the joints, add fresh grease, new boots, and call it a rebuild. I agree that your shifter bushings are prolly shot. I have never replace bushings, but don't think it would be that difficult. Others here can advise you on work involved. I don't know if the 2.2 motor in your 96 is a valve interference motor or not. Irregardless, you will need to replace the timing belt, and prolly some pullys to gain engine reliability. Otherwise, breaking a worn out timing belt makes for a bad day. Perhaps previous owner can tell you when the belt was last changed, or a receipt in the glove box can tell you that, and if changed not long ago, then the current belt will last you for a while. Prolly a good idea to look at the antifreeze in the cooling system. If the coolant looks dark and ugly, then best to drain, and flush, then add new antifreeze. Subies are long distance cars. Many owers are still on the road with 300K+ miles on the odometer. Have fun with your new car, and welcome to this forum.
  3. Nice car for little bucks. Suggest you change radiator caps. It is possible that a bad cap is the problem. Keep an eye on the temp gauge. If it is indeed a bad head gasket, it will drive fine for a while, then the temp gauge will very rapidly over heat. Just keep watching the temp gauge. If it starts to over heat, turn off the engine immediately.
  4. I have had good luck with Bosch wires and Bosch Platinum plugs. Don't recommend chain auto store cheapie house brand wires. They will give you trouble.
  5. Did the dealer tell you why the caliper needed replacing? If brakes worked okay, then I can't image anything wrong with the caliper. Would replacing the missing bolt have fixed the problem? It would have required removing the road wheel to find a missing caliper bolt. Something just doesn't seem right about their doing this "service". I guess I am suspicious of going in for an oil change, then mechanics start doing unsolicited inspection work to find problems that they are so conveniently available to fix, unless of course, you requested this additional diagnostic dealer service. +1 on what others have said that the brake caliper has not been bled properly, so air is still in the brake line. A re-bleed on the brake line should fix this.
  6. Back in 91, Subies were made as front wheel drive or, optional all wheel drive. It wasn't until a few years later that Subie went to all wheel drive across the entire product line.
  7. I guess it doesn't run, if you are wanting to flat bed the '91. Is the flat bed rated to carry something as heavy as a car? Does the trailer have it's own braking system? What are you using to pull the trailer? It will be close, but think the Subie will fit the trailer.
  8. Does your 2000 model have the fuse holder under the hood near the firewall on the passenger side? If so, check to see if there is a fuse installed in the fuse holder. If so, then the fuse is making the car front wheel drive only. Under normal conditions, the fuse holder does not contain a fuse to operate in all wheel drive. Let us know if there is a fuse there or not.
  9. If you can solder it, then I would suggest using JB Weld. It is an epoxy that sets up rock hard. The trick is to have a very clean surface, and wait 12 hours before using after applying. I have used it successfully to seal up a leak in metal tubing on high pressure A/C line.
  10. Kwhisles, I live in Indy, and find good parts at Happy Wrecking Yard on Tibbs Avenue on the south side of Indy. All Subarus there are kept at the farthest (north) end of the yard. It has been a while since I have been there, at that time there were about 8 Subies there. Sometimes, G W Pierce wrecking yard on highway 31 north of Indy has Subies. They sell both domestic and foreign parts. Both Happy's and GW will let you walk their yards. The Pick a Part (off 16th Street), and Pull a Part (off I-70) yards in Indy are very much hit and miss on Subarus in their yards. There are a few other yards around, but don't let you walk their yards, but maybe worth a phone call to ask what they have. Good luck, Larry (Rooster2)
  11. Not uncommon for idler pulley to lock up, I have had that happen before. It is really a sealed bearing, that can't really be greased. I sourced one from a pick and pull yard to fix.
  12. I have heard of a spray that will rid tobacco odor, but can't remember anything about it. Suggest calling a car parts store or auto detail shop, and ask to buy a can. Update, I just did a google search for "rid tobacco smell," and found a wealth of suggestions from fabreeze, vinegar, baking soda, citrus peel, and more. Do the same google, and I am sure you will find a solution.
  13. Wally world's Supertech has worked well for me. When adding fresh ATF through a long funnel into the dip stick tube, you will need to add 4 quarts, and just a smidge more. If it were me, I would add a little less then 4 quarts, and add a can (pint size) of Trans-X. You may actually want to change ATF twice, since you can only change about half the quantity that is in the trany system. The torque converter retains the other half. Then, add the Trans-X on the second ATF change.
  14. My recommendation is Wix, Purolator, NAPA. I avoid Fram. I heard a lot of negative talk about Fram. I was using one at the time, so at time of oil change, upon removal of the Fram, I used a hack saw and cut the filter open. I found very little filter media in the Fram, and also found the thickness of the casing wasn't much thicker then a coke can. Last Fram I bought. It is too far for me to go to the dealer, so I buy after market filters.
  15. I had the reverse problem several years back. I had a 91, and found that later years had a different bracket, prolly like yours, that I bought, and wouldn't fit my car. It is only a guess to say that Subaru 90-92 were much the same. To be on the safe side, prolly a Leggie in the 94-99 will have the bracket you need.
  16. Are you sure the belt is tight enough? May also consider adding oil to the A/C system.
  17. Thanks for the greasing advise. I appreciate it, and will work on it this weekend.
  18. Your problem may be similar to problem encountered with 99 and 00 Legacies. Their trany is reluctant to switch gears from R to D. A can of Trans-X may help you. Suggest you go to Search on this forum and read an old thread titled "Fixed!! Delayed trany forward engagement. I wrote this thread about 2 years ago, and Trans-X continues to help my trany.
  19. My 98 OBW, has developed a creaky strut bearing on driver's side. I have heard the strut bearing is sometimes called the "top hat." Any suggestions on how to quiet the creaky sound? Strut still performs well, so not interested in swapping out the strut, just to get rid of the annoying noise. Thanks for suggestions.
  20. When you start out with a cold engine, are you able to drive about 4 miles, then the temp needle abruptly goes from normal to high in a hurry? If so, then I am thinking head gasket trouble. I went through the same sequence as you with new radiator, cap, and some hoses, but still would "sky" the temp gauge in no time. This was on a 91 Subie with the 2.2 motor like yours. When starting to over heat, look for bubbles in the over flow tank.
  21. I replaced mine a couple of years back. The knock sensor bolt threads straight into the block, however, there are engine parts in the way that block a direct straight shot using a driver and extension. You will need to use a wobbler attachment to your driver, and work at an angle to be able to get your socket on top of the nut. The working angle is more like 60 to 80 degrees, when turning the driver handle. It is a little awkward when first threading in the bolt. This is best done by hand turning the drive extension and wobbler, to thread in the bolt a few threads, before attaching the ratchet drive to complete the tightening of the bolt.
  22. The 2010 Forester is a really nice vehicle. I helped a friend buy one a few days ago. I wouldn't be leery regarding any HG issue with the Forester. Subaru has had 10 years to get the HG fixed on the 2.5 motor. Don't know what was going on with your clutch on your 99, but the "shutters" indicates that something wasn't right from the beginning. Suggest you check out the Subaru Forester forum. There is a sub forum that is called Forester Shopping that addresses questions by people interested in buying a new 2010. Here is the web site. It is very helpful when buying a new vehicle. http://www.subaruforester.org/vbulletin/
  23. +1 on above. I have had a wheel bearing go bad, yet the others remain good for years. Like said, just replace the bad one, and motor on.
