Everything posted by Rooster2
Squeaky mornings PS pump driving belt 02' Legacy GT
Rooster2 replied to 740gle's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is an ez install, since the belts are at the front of the engine.
97 OBW bad HGs.. UPDATE , found donor 2.2l, couple ?s on swap...
Rooster2 replied to themoneypit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow much difference in performance from a 2.2l to a 2.5l is there? Having owned both and driven as daily drivers, there is not much HP advantage in the 2.5 over the 2.2. The 2.2 is not a slug. You won't miss the tiny HP advantage of the 2.5. I would not hesitate to do the swap, if my current 2.5 bit the dust.
Rooster2 replied to themoneypit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have also heard of running with a bad head gasket by loosening the vent screw/bolt at the top corner of the radiator on the opposite side from the radiator cap. This helps vent out exhaust gas that is entering the cooling system via the bad head gasket. A very tiny amount of coolant will escape from the cooling system, and the cooling system won't pressurize, but it will help your motor from over heating.
Won't run after head gasket job
Rooster2 replied to sean56a's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOil level prolly okay. Checking oil when parked on a slant, give a false reading. Does the engine run long enough to be able to pull codes? Check all your wiring to verify everything is hooked up properly, same goes for all vacuum connections. Doubt that alternator is source of your problem. The white smoke thing is prolly associated with your problem, but I am not knowledgeable enough to know the answer.
which lights will light the road better
Rooster2 replied to bheinen74's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe OEM Subaru lights are fog lights. The Hella lights are driving lights. The Hellas will light up the road much better for a far greater distance.
Knock sensor - life expectancy?
Rooster2 replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYea..........more like $75 to $85, for not looking like much, they are kinda costly.
Rooster2 replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is very easy to crack the plastic sensor because of over tightening upon installation. Like said earlier, look for cracks in the plastic, and if need to replace, just a gentle snug tightening is all that is needed to secure the knock sensor to the engine block.
1996 Subaru Legacy Wagon Issue
Rooster2 replied to gvr4737's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou mentioned buying gas at a shady gas station, that could be the source of the problem, particularly if you have had some rainy weather lately. It is easy for a shady place to have bad gas resulting from run off rain water getting past worn out seals on the top of the station's under ground gas tank. Years ago, a cheapie station in my town had this trouble. It resulted in stalled, or nearly stalled cars all over town. Suggest you try adding a can or two of "dry gas" to your gas tank in case this is your problem.
Stealerships replacing heat sheilds??
Rooster2 replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe chances of your Mom driving off road, and parking in high dry weeds to start a fire seem very remote. Did the stealership pressure sell her to replace the heat shield in the name of "safety"? The safety angle is the best scare tactic to sell any car product to a woman.
Toyotaru convertable?
Rooster2 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would be surprised if Toyota sells this car with a Subie motor. The cost of providing Subie replacement engine parts, and Subie mechanic training through out their entire dealer network for this one car only would be stupendous, and cost prohibitive. The car has killer good looks, that I think would sell well. If it is ever marketed, I think the logical choice is to see an established Camry or Corolla drive train under the hood.
changing antifreeze
Rooster2 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyep, good analogy............soda vs pop!
changing antifreeze
Rooster2 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOkay learned deionized is same as distilled. I keep a gallon around to add to car batteries when needed. I will put it to good use.
changing antifreeze
Rooster2 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou do use deionized water afet the garden hose flush or a 50/50 premix i hope. What is deionized water? That is a new one one me..........Rooster2
changing antifreeze
Rooster2 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the advise. It has been 3 years since antifreeze has been replaced. I will change thermostat as well. I will put the car up on ramps on the front. I hope raising the front end causes a good burp to rid any air in the cooling system.
Head gasket repair in a bottle
Anyone ever try this product to fix a bad head gasket in a Subie? Check out the following website: http://www.rxauto.com/demo.htm I wonder if this product is real or snake oil?
changing antifreeze
I need to winterize my Subie with fresh antifreeze. Do I pull the top or bottom hose to the radiator to drain out the old antifreeze. I know in the past, I have used a garden hose to flush water through the system. Just can't remember which hose to pull. Thanks for advise.
Oil is fuller not emptier ????
Rooster2 replied to mulcheese's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn draining your oil, you mentioned that the viscosity was light, so it drained out like water. By chance did you smell the drained oil? Did it smell like gasoline? If so, then you may have a stuck injector, that is allowing gasoline to drain down into the oil pan. However, this situation would have caused a miss fire, and your check engine light to be on. Didn't see any mention of that in your post. As advised, just keep an eye on the oil level to head off trouble before it arrives.
95 Subaru Legacy Wagon --4WD Question
Rooster2 replied to rainman19154's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAWD means full time all wheel drive. There is nothing to shift in or out of four wheel drive. If there are decent tires on the car, it will pull you through the nastiest snow and ice that Philly has to offer. You will be impresssed.
FIXED!! Trany delayed forward engagement
Rooster2 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnother Trans-X success story. I just love it. Trans-X has been in my 99's trany now for about 2 years and 20K Miles. Still running well on the product. It simply amazes me that the product works so fast to fix the problem. Seems like only the 99s and 00s are cursed with this problem
1994 Legacy Air con probs
Rooster2 replied to timfreddo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like you blew a fuse when adjusting that broken cig lighter. Since I am guessing all fuse box writing is in Japanese, you are prolly better off just pulling each fuse until you find one that is blown. I would recommend doing some dash disassembly to disconnect the wiring to the cig lighter, or you are likely to just keep blowing fuses.
Snow Tire Set
Rooster2 replied to StructEngineer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know their is a 96 Outback there with really good, nearly new all season tires on all four corners on OEM alloys. I asked, and know they won't take less than $200 for the complete set. I gave it a long thought to buy the set, because I need tires, but decided not to, because I don't need the alloys. Maybe we can work out a deal, I will get the tires, you get the alloys? Split the cost in half, plus, still would need to add in taxes and shipping cost to you. Tire/wheel size is 205/70/15. I will be out of town starting tomorrow, 10/22, back Sunday, 10/25, with no internet access. My email is fish6525@yahoo.com, cell # 317/270-8554 (Rooster2) in Indy, if interested.
06 Forester 60k on factory plugs
Rooster2 replied to mattri's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWay too early on the plugs too. Original plugs should last 100k miles.
Snow Tire Set
Rooster2 replied to StructEngineer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI live in Indy, and was at a wrecking yard on the south side of Indy. That yard must have six Legacys. Most were still wearing their tires/road wheels. I am sure you could find a decent set of wheels there at a decent price. I do know they sell tires and wheels only as a set. They won't sell the road wheels by themselves. Name of the yard is "Happy's Import Auto Parts" on Tibbs Avenue, in Indy. A google search will get you their telephone number. Hope this helps.
Fuel filter, brake fluid
Rooster2 replied to murphsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo replace the brake fluid..........pull off each road wheel, and bleed off the fluid in a catch bottle. I use a "one man" bleeder system. Hook up the bleeder, then press down on the brake pedal, pushes the fluid into the bottle. The bleeder system prevents air from being sucked back into the system. One man bleeders are available at Harbor Freight, and prolly at auto parts stores. It is pretty easy to do, just takes some time.
Overfilling auto tranny
Rooster2 replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI bet if you babied the trany, it will still last you for a good long time.
