Rooster2
11
Everything posted by Rooster2
Sounds like you blew a fuse when adjusting that broken cig lighter. Since I am guessing all fuse box writing is in Japanese, you are prolly better off just pulling each fuse until you find one that is blown. I would recommend doing some dash disassembly to disconnect the wiring to the cig lighter, or you are likely to just keep blowing fuses.
I know their is a 96 Outback there with really good, nearly new all season tires on all four corners on OEM alloys. I asked, and know they won't take less than $200 for the complete set. I gave it a long thought to buy the set, because I need tires, but decided not to, because I don't need the alloys. Maybe we can work out a deal, I will get the tires, you get the alloys? Split the cost in half, plus, still would need to add in taxes and shipping cost to you. Tire/wheel size is 205/70/15. I will be out of town starting tomorrow, 10/22, back Sunday, 10/25, with no internet access. My email is fish6525@yahoo.com, cell # 317/270-8554 (Rooster2) in Indy, if interested.
I live in Indy, and was at a wrecking yard on the south side of Indy. That yard must have six Legacys. Most were still wearing their tires/road wheels. I am sure you could find a decent set of wheels there at a decent price. I do know they sell tires and wheels only as a set. They won't sell the road wheels by themselves. Name of the yard is "Happy's Import Auto Parts" on Tibbs Avenue, in Indy. A google search will get you their telephone number. Hope this helps.
To replace the brake fluid..........pull off each road wheel, and bleed off the fluid in a catch bottle. I use a "one man" bleeder system. Hook up the bleeder, then press down on the brake pedal, pushes the fluid into the bottle. The bleeder system prevents air from being sucked back into the system. One man bleeders are available at Harbor Freight, and prolly at auto parts stores. It is pretty easy to do, just takes some time.
If your 2003 is like my '99, you have two "V" belts that run off the crank. I tighten mine to the point that I can only finger twist the belt 90 degrees at the mid point of the longest length between pulleys. With a new belt, I recheck the belt tightness after driving the car for about a week. New belts sometimes stretch a little when first put into use, then are fine there after. It is very important to buy a good belt. I buy the most expensive the auto parts store sells. It is just a few bucks more. The cheapies, I have found will continue to stretch, requiring retightening about every 4-6 months. That hassle negates the cheap price. Hope your daughter continues to enjoy her Subie!
Correct me if I am wrong, but I thought all 99 Legacys came with the 2.5 phase one motor, not the 2.2 motor. Unless, the 2.2 was swapped in later? The 99 Legacy model year (I have one) is prone to have delayed forward engagement, when shifted from reverse. Yes, adding Trans-X to the trany fixed it, but I am still concerned that the problem could return.
Warranty replacement is the way to go, if your car still qualifies on millage. If not, at http://www.Autohausaz.com, they are selling a Bosal cat, part number WO133-1842851 on sale for $366.44, that fits your 03. Their ad says that the Bosal unit replaces both the front and rear cats. Bosal is a good name in exhaust products, so I would trust their product. I am confident that it would perform well on your car. I am with you, it is insanity to spend $1,500 on a dealer cat. Lots of profit in that high figure.
My guess is that those depressed places you speak of on the floor pan rail, are there for use by the jack when changing a flat tire. As far as your rear cat problem, I could never figure out why Subaru and other car companies use the flanges with springs and such. Whenever I need a new cat, I go to a cut and weld muffler shop. They just torch off the old cat, then slide on a new cat, then use muffler "horse shoe" style clamps to secure everything. This would work particularly well for you, as the second cat does not have an oxygen sensor screwed into it. Don't know where you live to find a bend, cut, and weld muffler shop in your area. Chain shops like Midas, Car X, etc. won't do this type of work, so no use contacting them. The chain shops would want to install an entirely new muffler system from the first cat all the way back to include the final tail pipe for about $800...not where I like to spend my hard earned money.......btw.........welcome to this forum. Lots of good folks here to help you keep your Subie on the road.
I haven't tried this, but a friend who has, says it works........ Use some JB Weld product. Coat the bolt with a light film of Vaseline, so the JB Weld won't adhere to the bolt. Apply JB Weld to the stripped threads. It takes very little product. Wait until the JB Weld is just beginning to harden up, then gently screw the bolt into the threaded hole. Finger tighten the bolt. Let it harden up over night, or better for 24 hours, before gently tightening the bolt just a little more. Don't tighten the bolt much, or the new threads may pull out. Job is done. Only catch, is the JB Weld needs to dry (cure) where the air temperature is at least 70 degrees Fahrenheit, sorry, but I don't know what that temp converts to in Celsius, as I see you are from Canada. Hope you can get to a warm garage to try this fix, or rig up an electrical heater for warmth.
A/C noise
Rooster2 replied to subegrl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Think I borrowed a smaller puller from AutoZone, when I replaced the A/C clutch pulley on my VW years back. Seemed easy, don't remember the R&R being much of a project. Still remember that I did not have to remove the compressor from the system, forcing an evac and recharge of refrigerant. -
Prolly impossible to verify, even if the yard showed you the car that the trany was pulled out of, you would still not know if that was the truth. Like you say, check the vin against Carfax, and maybe learn something. Pretty hard to believe a 95 model would only have 45K on the odo after almost 15 years. If the yard is so proud of this trany with 45K miles, maybe they will give you an extended warranty.
A/C noise
Use a very long screw driver as sort of a stethoscope. Touch the end of the screw driver on the bolt head (or very near by) the suspected bad bearing, then touch the other end to your ear, or side of your head. The sound traveling up the screw driver will be a lot louder where the problem is. This is an old trick that my dad taught me, when I worked at his gas station many years ago. I know it sound a little dumb, but this technique works really well. Of course you do this while the engine is running. Just be careful not to let that screw driver slip out of your hand while moving it around those moving pulleys and belts. Agree with other poster, it could well be your belt tensioner. I have replaced those when the bearing goes bad, and starts making noise. -
A/C noise
If making noise when A/C is turned off, then it must be in the clutch unit at the front of the compressor. Suspect the bearing in this unit is going bad, so compressor unit prolly still works okay, and I bet is still pumping out cold air. Years back I had a similar problem on a VW. I just replaced the clutch unit, which is right at the compressor belt pulley to fix the problem. The compressor unit did not have to be replaced from the car to do the work, so there was no loss of refrigerant. I bet you could snare a clutch unit from a wrecking yard without much difficulty. Update: Subarupartsforyou.com sells pulley assembly AC idler for $22. -
Suggest using the Dextron type ATF, the type used in GM cars, and doing so three times. Read past posts on this subject using the search mode on this forum.It would be a good idea to replace the external transmission filter. It looks just like an oil filter, but has a different filtering media. The one I bought cost about $35 from a parts store.
