Rooster2
11
Everything posted by Rooster2
Suggest using the Dextron type ATF, the type used in GM cars, and doing so three times. Read past posts on this subject using the search mode on this forum.It would be a good idea to replace the external transmission filter. It looks just like an oil filter, but has a different filtering media. The one I bought cost about $35 from a parts store.
may need to replace the coil pack, and or, spark plug wires. You prolly have a crack or split in one or both, so that water/moisture causes an electrical short. Suggest replacing your plug wires first, if they are your originals. Welcome to this forum, loads of friendly people here with good advise.
I have a 98 Subie OBW, the front end is the same as your 97. So, I know what you have. Someone, about 6 months or so ago, talked about an inexpensive way to replace the fog lights. He bought the low beam sealed beam headlights that were used in cars back in the mid 60's through mid 70's. The system where cars had four round sealed beams for their head lighting system. This type bulb is easily found at all auto parts stores. The guy said he removed existing fog light, leaving the backing shell, then glued the sealed beam to the remaining backing shell. Bulbs fit in the shell perfectly. He drilled a hole in the middle of the backing plate, then used existing wiring to wire the bulbs. Finished job was said to look great, perform well in the fog, and was very inexpensive. sI think he drilled a hole in the middle of the backing plate to attach wiring. If you hit the search function on this forum, should be able to find the original post. I seem to remember the guy was happy with the result. The new bulb fit nicely, and worked well in the fog, and the bulb was inexpensive, according to my memory.
Mechanic saying potential front oil seal leak causing air to get sucked into the lubrication system makes a lot of sense. I kept reading your posts, and poor lubrication seemed like a likely cause to me causing all that ticking. I am thinking that the oil pump has to be removed to replace the seal. Hope someone for sure can tell you a "yea or nae" on pump removal.
Both locations will work. Using OEM type that mount in the bracket under the headlights would "look" more integrated into the over all design of the car, and maybe protected better by the bumper. If it were me, I would see if I could get some good after market units that would bolt in where the OEMs would go, prolly cost less then OEMs, and may work better, or at least as well as OEMs.
Looks like you did well for $400. Suspect it is not a GT, because it has the standard steel wheels with wheel covers. Hope the passenger side is free of dents. Sounds like you had fun buying over the internet. Cute how they run the engine, then put a mic near by, so you can hear the motor. When do you take possession? Send us more pics and update on condition when you can. We always like to hear $400 success stories.
Keep away from midas etc. Dont use a tube bending shop as those pipes are cheap metal. Agree with you on staying away from Midas and the other chain muffler shops. IMO they are expensive, and will work hard at selling you more than what you really need to fix an exhaust problem. I also agree that tube bending shops use cheaper metal that won't last as long as an OEM muffler system. However in my humble opinion, I think the pipe benders are a better value. In my experience, their "cheap metal" is good for about four to five years of service before rusting out. That is not bad considering I was charged $64 for work on an eleven year old car. That works out to an annualized cost of about $16 per year. OEM muffler parts are expensive, and would have a much higher annualized cost, while lasting much longer. I figure my 98 doesn't have many more years of service left in her. So, it's the pipe benders for me.
If you don't have a CEL on, and both ends of the cat look like good metal, then I wouldn't replace the cat. Is your current system loud from an exhaust leak? Then find out exactly where the leak is. If so, My story...........this is what I did with my wife's 98 OBW recently. I took it to a family owned muffler chain. It is a shop where they torch off muffler systems or parts of muffler systems and replace by welding on new pipe. Turned out that her exhaust pipe just right after of the middle resonator had broken apart. Only the shroud was holding the pipes in alignment. The shop suggested, so I had them cut out the resonator and weld in a straight pipe. They bent and cut their pipe to make it fit. Systems works great. I don't think the straight pipe makes the car any louder. Cost was $64 out the door. My system now has a portion of the shroud covering missing, but I don't care. We never park in high weeds to ever start a grass fire.
knock sensor
Rooster2 replied to mark h's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
agree with others, if the plugs and wires are old, replace them. CEL code of missfire on cyl #2 is not a sign of a bad knock sensor. I had a bad knock sensor some time back. Car ran okay, but was down on power and fuel economy, as I think the computer retards the spark, when the knock sensor is bad. That is not the same thing as missfire on cyl #2 -
If the gash is strictly in the rubber, and has not cut any tire cord, or cause the sidewall to bulge, I would not consider replacing the tire. There may not be structural damage to the tire. I would apply some clear silicon sealant to the tire wound, and keep an eye on it to see if any bulging appears. You may not have to spend $600 after all.
Plenty of power mirror switches available here in US wrecking yards. I would be happy to send a couple to you if you are interested. Cost would be what I would buy them at, plus postage. Happy to help!
- 96 replies
- Dual Range EJ
- LatinAmerican Domestic Market
- (and 7 more)
I've heard Subarus are notoriously leaky cars. Is that true? At what point should I be worried about an oil leak? Thanks again for your help… I am on my third high millage Subie, and all leaked a little oil. Not bad, just little drip spots that I could see on my asphalt driveway. I wouldn't worry about the little drips; catastrophic leaks are rare with Subies, so don't worry about a little leak here and there.
