Rooster2
    11
Everything posted by Rooster2
  1. You can get pretty straight answers by going to a tire store, and talking with the counter guys about sizing. They deal with sizing day and day out, so they know what they are talking about.
  2. Don't feel bad, I too have a 99 Leggy wagon. The first time I searched for it, I couldn't find it. Like said earlier, it is buried under some hoses on the driver's side right at the firewall. Weed through those hoses to find the yellow handled stick. It helps to use a flashlight to find it, then use the same flashlight to find the tube to reinstall the dip stick. It only takes a pint of ATF to fill from the low mark to the full mark.
  3. Hope you applied some anti-seize cream to the facing of the rotor before reinstalling the road wheels. The anti-seize does a good job preventing the rims from sticking to the rotors in the future.
  4. tire inflation sounds good........when was the last time you had a front end alignment?
  5. I am thinking that silverstars are head light bulbs only, not fog lamps. Someone wrote here about replacing fog lamps with low beam seal beam bulbs. I am sure doing a "search" here will tell you all about the conversion.
  6. Paul, Glad to hear another Trans-X success story. So far, no one has said that Trans-X has failed to cure the delayed forward gear engavement problem that affects 99 and 00 Legacys. If you can't detect any slipping, then don't think you prolly have any. I am thinking the dealer was recommending replacement on delayed engagement only. Their solution is always dedicated to do R & R (remove and replace) parts as a solution to all problems. No dealer is ever going to suggest that you first try Trans-X..........Rooster2
  7. Your 93 will have the EJ22, the 2.2 motor. The 2.5 phase 1 started with the 97 model. The 2.2 is a very bullet proof motor. They run a long time before wearing out. Typical to go 250 to 300K+ before needing a rebuild. Yep, sound like a bad wheel bearing with the noise from what you described. If it were me, I would pull the road wheels to see how much brake pad you have left? Is this car just front wheel drive or all wheel drive? Prolly best to replace the timing belt and water pump and front seal. Your 2.2 is a non interference motor, so if the timing belt breaks, the valves don't hit the piston and bend. Have fun with your new "free" car. I hope there are many miles left in the car for you to enjoy!
  8. Like others have written, I have heard that piston slap doesn't cause any damage, just sounds bad. Just sounds worse then really is. On my 99 Subie, I use 20-50W oil in the summer, switching to 10-40W in the winter for here in Indiana. Years back a mechanic suggested this for any car with more then 100K miles on the odo. I have followed his advise for years, and have been happy with the results.
  9. Paul, Sounds like your car has the dreaded Trany delayed forward engagement that this post addresses. Sounds like Trans-X is helping. Adding a quart quantity sounds like too much to me. The trany holds about 9 quarts total in the trany and torque converted, so running with a percentage of more than 10% of Trans-X is quite high in my opinion. If it were me, I would drain a quart or so, then refill with ATF.
  10. It is my understanding that torque bind is caused by problems with the differential, not the automatic trany. Are you asking about adding Trans-X to the differential?
  11. O man, I don't see a straight panel remaining on that car. Hope the occupant(s) survived.
  12. There was a similar post just a couple of days ago about a leaky fuel filler pipe and responses on how to repair it. Let the Search button be your friend on this forum to retrieve earlier responses. Don't think you will need to drop the tank to fix.
  13. Paul, Trans-X has been good at fixing delayed forward engagement of gears, when moving the gear shift lever from reverse to drive at a dead stop. However, If you are having a trouble with "slipping" between gears, then this is a different problem, and a problem that Trans-X has not addressed. Still, it is worth a $6 try. Suggest you change your ATF prior to adding Trans-X. I used the smaller round can, more like pint size with 15 oz. I am thinking that adding a quart amount may be adding too much of the product. The increment readings on the ATF dip stick is in pints, not quarts like changing oil, so it is very easy to over fill the trany, which is not good. Post your results........hope Trans-X works for you. My trany with Trans-X is still working fine going on two years with the product. Trans-X works fast. After just 10 minutes of driving, you will know if Trans-X has fixed your trany problem. Regards.................Rooster2
  14. Also, check out front suspension for any "play" in components. Though, at 24K miles, I would suspect tires, balance, and maybe alignment problems.
  15. Epoxy is pretty thick, especially when it starts to set up. I wouldn't worry about much of it leaking inside the hole. Just smear it on with a plastic disposable silverware knife, and your done. Don't use a putty knife or regular knife, as the epoxy is difficult to remove from a knife.
  16. Yea, you are right. That hole needs to be sealed up. You don't want dirt to get behind that cover. If it were me, I would use something a little more permanent then duct tape. Suggest cleaning up the hole area, using rubbing alcohol to remove all traces of duct tape adhesive. Then, apply some J-B Weld "Kwik" product. I am looking at a package of the product right now........it is a two tube epoxy, label says bonds in 4 minutes. The stuff works great to provide a permanent repair.
  17. I don't think that you are limited to a trany of specific years of 98 & 99, other years should work. I have both a 98 and 99 OB wagons. The tranys may inter change, I am not the one to ask. However, they are not exactly the same. The 99 has an external ATF filter, the 98 does not, and I have heard the bolt up may be different, but still do able. Also, the 99 and 00 model years only, have an inherent sometimes issue of delayed forward engagement when stopped, that can be addressed by putting an additive in with the ATF. Because of that, if it were me, I would shy away from installing a 99 or 00 auto trany.
  18. not sure if he has it or not. i'm trying to schedual a time to look at it. i'll take pix of the core support ect... It would be good to get the motor with the body, even if the motor is trashed, there are still a lot of bits and pieces off the bad motor worth having. Check to see what suspension damage there might be. How long has this car been sitting. If a long time, the brake system will need some work.
  19. It is a little hard to tell by the picture, but it looks like the engine bay is empty. Is there anything left under the hood?
  20. First thing I would do, is to check the fuse. On my cruise, I have to hold down the "set bar" for a second or two for it to lock in. I can hear a little click from under the dash that I have learned is an audible indicator that the cruise has engaged.
  21. I don't know which I have. My cars are 98 and 99 OBWs. Any way to know, without disassembly? Rooster2
  22. yea, had the same problem a few months back. I busted off a bolt holding on the rotor, took it to a shop, where they had to heat the broken part of the bolt with a torch. Yes, anti-seize should be used on those bolts.
  23. I have seen several posts here saying that 2.5 phase 1 timing belt kits are available on e-bay. I hunted around on e-bay, but couldn't find anything. Is there any special wording on e-bay "search" to find the kits? What is generally the cost for T-belt, pulleys, and seals kit? Thanks!
