Rooster2
11
Everything posted by Rooster2
Don't feel bad, I too have a 99 Leggy wagon. The first time I searched for it, I couldn't find it. Like said earlier, it is buried under some hoses on the driver's side right at the firewall. Weed through those hoses to find the yellow handled stick. It helps to use a flashlight to find it, then use the same flashlight to find the tube to reinstall the dip stick. It only takes a pint of ATF to fill from the low mark to the full mark.
Paul, Glad to hear another Trans-X success story. So far, no one has said that Trans-X has failed to cure the delayed forward gear engavement problem that affects 99 and 00 Legacys. If you can't detect any slipping, then don't think you prolly have any. I am thinking the dealer was recommending replacement on delayed engagement only. Their solution is always dedicated to do R & R (remove and replace) parts as a solution to all problems. No dealer is ever going to suggest that you first try Trans-X..........Rooster2
Your 93 will have the EJ22, the 2.2 motor. The 2.5 phase 1 started with the 97 model. The 2.2 is a very bullet proof motor. They run a long time before wearing out. Typical to go 250 to 300K+ before needing a rebuild. Yep, sound like a bad wheel bearing with the noise from what you described. If it were me, I would pull the road wheels to see how much brake pad you have left? Is this car just front wheel drive or all wheel drive? Prolly best to replace the timing belt and water pump and front seal. Your 2.2 is a non interference motor, so if the timing belt breaks, the valves don't hit the piston and bend. Have fun with your new "free" car. I hope there are many miles left in the car for you to enjoy!
Like others have written, I have heard that piston slap doesn't cause any damage, just sounds bad. Just sounds worse then really is. On my 99 Subie, I use 20-50W oil in the summer, switching to 10-40W in the winter for here in Indiana. Years back a mechanic suggested this for any car with more then 100K miles on the odo. I have followed his advise for years, and have been happy with the results.
Paul, Sounds like your car has the dreaded Trany delayed forward engagement that this post addresses. Sounds like Trans-X is helping. Adding a quart quantity sounds like too much to me. The trany holds about 9 quarts total in the trany and torque converted, so running with a percentage of more than 10% of Trans-X is quite high in my opinion. If it were me, I would drain a quart or so, then refill with ATF.
Paul, Trans-X has been good at fixing delayed forward engagement of gears, when moving the gear shift lever from reverse to drive at a dead stop. However, If you are having a trouble with "slipping" between gears, then this is a different problem, and a problem that Trans-X has not addressed. Still, it is worth a $6 try. Suggest you change your ATF prior to adding Trans-X. I used the smaller round can, more like pint size with 15 oz. I am thinking that adding a quart amount may be adding too much of the product. The increment readings on the ATF dip stick is in pints, not quarts like changing oil, so it is very easy to over fill the trany, which is not good. Post your results........hope Trans-X works for you. My trany with Trans-X is still working fine going on two years with the product. Trans-X works fast. After just 10 minutes of driving, you will know if Trans-X has fixed your trany problem. Regards.................Rooster2
Yea, you are right. That hole needs to be sealed up. You don't want dirt to get behind that cover. If it were me, I would use something a little more permanent then duct tape. Suggest cleaning up the hole area, using rubbing alcohol to remove all traces of duct tape adhesive. Then, apply some J-B Weld "Kwik" product. I am looking at a package of the product right now........it is a two tube epoxy, label says bonds in 4 minutes. The stuff works great to provide a permanent repair.
I don't think that you are limited to a trany of specific years of 98 & 99, other years should work. I have both a 98 and 99 OB wagons. The tranys may inter change, I am not the one to ask. However, they are not exactly the same. The 99 has an external ATF filter, the 98 does not, and I have heard the bolt up may be different, but still do able. Also, the 99 and 00 model years only, have an inherent sometimes issue of delayed forward engagement when stopped, that can be addressed by putting an additive in with the ATF. Because of that, if it were me, I would shy away from installing a 99 or 00 auto trany.
not sure if he has it or not. i'm trying to schedual a time to look at it. i'll take pix of the core support ect... It would be good to get the motor with the body, even if the motor is trashed, there are still a lot of bits and pieces off the bad motor worth having. Check to see what suspension damage there might be. How long has this car been sitting. If a long time, the brake system will need some work.
I think Mugs has the right approach by systematically finding and solving problems. He is the kind of mechanic that I would want to take my car to, and could put my faith in. I have seen dealer shops, not Subaru, and private shops pull the same nonsense on me, that you just received. The approach is to take minor questionable weak evidence and weave it into a story to tell the owner, that a bunch of work needs to be done. The result is a very pricey quote with some scare tactics thrown in about the need to get the work done ASAP, as the car is unsafe to operate, and going to break down. This sales pitch works really well on a lot of people, especially women, who are scared to death of having their car break down anywhere and any time. I think the most bothersome aspect of what you wrote, is the dealer trying to sell you wheel bearings and a front axel, when you brought the car in with an over heating problem. Unless you asked for these items to be checked out, it is my humble opinion that the dealer is "looking" to make work, and a fat profit, irregardless of what really needs to be repaired. If it were me, I would get my car out of that shop pronto, even if I had to have it towed out. I would also let them know why I was leaving without having any work done, and that I was never coming back again. A letter to the Better Business Bureau, and to the Subaru Zone Manager would follow. Let us know how you come out on this!
