Rooster2
11
Everything posted by Rooster2
I know just how tight those screws holding the door mirror on can be. To replace the mirror on my wife's car, I finally had to resort to using a ratchet with a philips screw driver tip, then pushing in on the handle as hard as I could to apply pressure against the screw head, I then used vice grips to rotate the screw. Otherwise, just working with a screw driver alone, you will round off the head of the philips screw.
I wrote the original thread here. Tried the Lucas Transmisson Fix, but found it did not fix my Trany delayed forward engagement problem at all. It was a few months later, when my problem became severe, that I drained the ATF, added the Amsoil syn ATF, and the Trans-X. I am convinced that the Trans-X is what fixes the problem. Something about the Trans-X swelling seals is the key to its success. It has been nearly 18 months of running with Trans-X, and my auto trany continues to operate with no problems. Be aware that this trany fix is for Subies manufactured during model years 1999 and 2000. Ealier and later model Subies with the 4EAT auto tranies don't have the delayed forward engagement problem that I am aware of. Larry (Rooster2)
Yes, the A/C push button lights up green when activated. I need to work on mine as well. I do remember in the archives here, that there have been several write ups on how to replace bad bulbs. One was really good with multiple "how to do" photos. Doing a "search" should yield the posts. Seem to remember that bulbs were easily obtained at Radio Shack.
You have the classic description of a bad head gasket. It is very typical on the 98 model. Engine temperature will be normal for a while, then suddenly "spike" to hot in a hurry. Suggest you do a search on this forum and read the archieves on head gaskets as to what many others have posted about this problem. On the 98, the head gasket goes bad, dumps exhaust gas into the cooling system, which causes the engine to over heat. So, in this situation, you won't find the oil milky with water. Suggest don't driving when motor is hot, or you will need to replace the motor.
My suggestion is to reinstall your old A/C compressor, if it was working properly prior to removal. You will prolly want to use new "O" ring seals when hooking up the lines. A new dryer would be nice, but not necessary. Suggest then going to an automotive shop to have refrigerant 134a installed in the system. Yes, the 134a conversion kits work well, but since it is necessary to draw a vacuum on the system to rid if of atmospheric air and moisture, you will need to go to a shop to do this. I had a 91 Leggie some time back. The 134a conversion gas works well in the system. Good luck!
Nipper, I just replaced my hatch handle on my Subie last week. The handle is secured by two threaded studs that are part of the handle. The studs are pushed through holes in the hatch, and secured with 10MM nuts on the inside of the hatch. There is nothing to unbolt on the outside of the hatch. The only way to unbolt the handle is by first removing the plastic panel on the inside of the hatch to gain access to the nuts. Rooster2
If you have the standard cloth seats, I have to agree with you. They are not very comfortable. You might look to upgrade to leather seats from a "Limited" OBW. Look on line at ebay, or check a wrecking yard for leather seats. The leather seat is so much more comfortable and supportive. It is a simple bolt in.
Before replacement, my handle would squeeze, and then retract upon release, but because of rust, the handle would bind up upon release just enough to prevent the handle from operating the next time I wanted to open the hatch. If I pushed the handle back further toward the spring return, I could get it to open. What a PITA until I replaced the squeeze handle.
On my OBW, the hatch interior cover is held on with plastic fasteners. Prolly the same with yours. The fastener has a plastic circular peg in the center of the fastener that forces the fastener's " 3 legs" to spread out and create a friction fit. Use a flat blade screw driver to gently pry up the edges of the fasteners to remove. The circular pegs will fall out, when the fastener is pried out. Be sure to find each peg to each fastener, as they are needed when reinstalling each fastener. If your hatch exterior squeeze release is defective, new ones are available on line at parts stores or dealer. Cost is about $35 on line, $45 at the dealer. Two 10 MM nuts on the inside of the hatch hold the handle in place. A pry apart plastic clip attached to the handle holds the release rod in place. Since you have another car to look at as a working example, you will have an easier time completing this project. Good luck!
Is the squeeze handle on the hatch rusty? That was my problem, so handle would bind and not retract fully when released by hand. I had to push the handle back down, then press the "lock, unlock" electric door button several times. Then press to the "unlock" position. Then, and only then would the squeeze handle work correctly to open the hatch. Finally, I replaced the rusty squeeze handle, and the hatch opens perfectly every time.
I too, have heard of using moth balls, but don't know how well it works. A friend tried that, but it was annoying riding in his car with the moth ball smell. I have also heard that the electronic sound repellers don't work well after a while. The critters get use to the sound much like humans get use to hearing fire truck or airplanes, if you live close to where those sound sources are located. Keeping a cat in that garage at night would prolly keep the mice away. Also, since my wife and I have two Yorkie terriers, have learned that terrier dogs are sworn enemies of all rodents. I have seen one of my yorkies kill two squirrels and a mouse. Just attack and kill them right on the spot.
Yes, it looks factory, just that Panasonic keeps changing radio models. I have both a 98 and 99 Leggies. Both have factory Panasonic radios, that are different from each other, and neither look like yours, still there are similarities, so here are my thoughts.......... Judging from your picture, I would try to set the time by pressing in, and continue holding in, the button marked display. While continuing to keep the button pushed in, after about 5 second, press either one of the radio station "tune" buttons. I am thinking one tune button will advance the clock time setting, the other button will retard the clock time setting. If this doesn't work, while continue to push in the display button, try pushing other buttons in. I have one radio that uses the station preset buttons to set the clock, while the display button is depressed. Yes, it is frustrating, just like setting the correct time on a digital watch. If you keep pressing buttons, I bet you will be successful.
It has been three years now since I have changed coolant in my 99 OBW. I annually added a can of Prestone water pump lube and rust inhibitor to the system. Now, I think it is time for a flush and replace the antifreeze. I have also replaced the radiator cap. So far, so good, no issues with HG trouble on my EJ 2.5 phase 1. I have no issues with existing thermostat, however, is it advisable to replace the thermostat? I bought this car used, so I have no idea how old the existing thermostat is.
