Rooster2
11
Everything posted by Rooster2
I have had a gasoline engine described as an air pump. It pulls air in from the atmosphere (intake) and pumps the same air out the tail pipe (exhaust). The result is horse power. So, horsepower is increased when more air is pushed out the tail pipe faster. Super chargers, turbo chargers, and four valves per cylinder are all designed to increase air flow for more hp. In addition to working on increasing exhaust air flow, suggest thought and work be put into the air intake system. There is a fresh post by someone working with the air intake box for hp increase. Suggest reading that post for some ideas.
I have been to enough wrecking yards to see exactly what you are talking about. Something shorts out the electrical system to start a fire and toast the engine bay and maybe more. I have never bought a motor from a fried car like that, but would think that the motor itself would be unharmed. An under hood electrical fire does not get that hot to damage the motor in my opinion. The reason the car sits in a wrecking yard is because the labor to install a new wiring harnass, and all other damaged under hood components is beyond the value of the car. Now that I think about it, I remember talking to a guy shopping in a wrecking yard years back. We were both looking at a car that had suffered an engine bay fire in the yard. In conversation, he said that he bought a car from a wrecking yard, and painstakingly rewired what was damaged in the fire, and put the car back on the road again. He said the cause of the fire was a leaking fuel injector, or fuel line that sprayed or leaked fuel on the exhaust manifold to start the fire. So, I guess that is a testimonial that the motor is prolly not damaged. Guess, I should also add that the engine fires that I have am talking about have not been catastrophic. Only wiring has been burned, not radiator or heater hoses, valve covers, or any belts burnt off the car.
Question
Rooster2 replied to android25ua's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Agree fully with you, especially the part about starting to "sound like my old man." I am age 64, and that is exactly what my old man would have said, God rest his soul. Funny how my old man got smarter and smarter the older I got. Never would have believed it. -
Car Battery
Rooster2 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Bet the batteries were installed low on water, read my later post! -
Car Battery
I have been using Wal Mart's EverStart Maxx in all three of my cars. It is a very good battery, and you save a few bucks. I have installed all myself. However, for some strange reason all three batteries have been low on water at time of purchase. Typical of the morons in Wal Mart's automotive section, they don't have distilled water available to fill the battery. However, Wal Mart sells a plastic gallon of distilled water for less than a buck. Good to pick up a gallon of the distilled. It is sold in the beverage section of the grocery side of Wal Mart. -
Deal???
Rooster2 replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Hard to believe an elderly lady would buy a new '91 Subie turbo, 5 speed, and keep it well maintained all these years. This is not the type of car that appeals to little old ladies. This ad does not sound believeable. "Elderly lady" translates to me as someone in their 80's, but maybe not to the latest owner. Tread lightly on this deal! -
I think you are going off the deep end too soon to worry about a bad HG. The bad water pump will cause coolant to leak and cause little puddles like in your photo. A small coolant leakage can flow and travel quite a bit from the source to show up on an exhaust manifold. Also, seems like all Subies with age and miles will leak some oil as both of mine do. A slight oil leak is not an indication of a bad HG. So seeing a bit of coolant and oil doesn't mandate a bad HG. Did your car ever over heat prior to the bad water pump? Or has it ever over heated? If it were me, I would replace the T belt, water pump, tensioner, pulley, and a new radiator cap. That may be all the repairs you need to make. Suggest also, going to a spray wand car wash, and clean the motor thoroughly. Afterwards, keep an eye out for leaks. If you see any leakage, it will be a lot easier to find the source. Remember the main indicator of a bad HG is engine over heating. I haven't read that you ever had that, unless it was caused only by the bad water pump. Hopefully, you shut down the motor quickly if you detected over heating.
From the picture, it looks like the wheel is towed in. Suggest getting the car up on a lift to see what is broke or bent. I would not so much think that there is a problem with the right rear strut, as probably a bent suspension issue. I bet the previous owner knows what caused this. A good slide side ways with some speed, with an abrupt slam into a curb would be a good way of causing the tow in damage.
ditto on Gloyale's comments. If the heater core was plugged, you would not get any heat output, or very minimal heat. Also, the heat output would be constantly poor, as coolant always moves minimally through the heater core. The air pocket theory is a better idea, as the air pocket is not a constant. Sometimes coolant is moving through the heater core, sometimes not much, depending on the air pocket, and the water pump circulating varying amounts of coolant/air pocket. As Gloyale suggests..........a bad HG, or a radiator cap. My vote is a bad head gasket.
The burping is a good idea. Also, it is possible that you have a bad head gasket which allows exhaust gas to enter the cooling system. This causes engine over heating and poor heater performance. That could be causing the need for 'burping." Car heating systems rely on coolant flow through the heater core to provide warm air to the cabin. A "gas" added to the cooling system reduces heater efficiency. I had a 91 Leggie that blew a head gasket resulting in pressurizing the cooling system resulting in a leaky radiator. Is it possible that same thing happened to your radiator? The early 2.5 engine introduced in 1997 gets the bad rap for blowing head gaskets, but the earlier 2.2 engine (as in your car) can still blow a head gasket. Check your radiator over flow for bubbles when the engine is warmed up and running. If you see bubbles, you have a head gasket issue.
Head gasket?
Rooster2 replied to floater's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
It has been a while, but I remember about 15 years ago that a shop tested my VW for head gasket trouble by using chemically treated paper which was inserted into the neck of the radiator into the coolant. Upon removal, if the paper changed to a certain color, that was the indication of exhaust in the cooling system. The process reminded me of using Litmus paper to detect an acid or a base from High School chemistry class. -
If you can pick up this car on the cheap, and as you say the body is clean with not that many miles, it can be worth your while to put some time on getting the motor to run. If you get it to run well, then resell for a nice profit, or drive it yourself, and look for a 5 speed elsewhere. Since the '90 has the 2.2 non interference motor, you will not have a concern of valve damage from T belt problems.
I have a 99 Leggie OBW. Yes, it is the DOHC motor with potential Head Gasket problems. Ask owner if HG has been changed. If previous owner can't be reached, Subaru mechanics can look at the head gasket ends (over hang)that protrude where the head meets the block, and tell by the material if it is the newer design HG. The 99 also has issues with the automatic transmisson of delayed shifting into forward gears from park or reverse. This can be remedied by adding a can of Trans-X to the trany. That product fixed my problem. Otherwise, the 99 is a good car!
