Rooster2
11
Everything posted by Rooster2
Since you have tried adjusting the speaker balance without success, a nice swap with a WRX 6 disc or Outback radio is a smart move. I have two Legy Outbacks with the weather radio. I never thought I would use the weather radio, but it has been surprisingly handy to have during bad tornado warnings and T storms.
Kyle, If you haven't done so, check the radio speaker balance controls. That is the radio control that variably adjusts radio (left to right) speaker volume output. It may have accidentally been adjusted so that only the right side speakers are operative. If when you adjust for more left speaker output, and the left speakers don't work, then I would suspect that the left channel on the radio output circuit has gone bad. If so, then it is time to replace the radio. Suggest finding a good replacement radio at a wrecking yard for a low price. It is an easy job to R & R a radio. Email me if you would like specific instructions, be glad to help.
I had a similiar problem recently. I went to AZ, but unfortunately the CEL had gone out. Their tech said the codes can be pulled only when the CEL is on. I don't know how true that is, but that is what I was told. A few days later, the light came back on, so I drove back to AZ. The AZ code reader said the knock sensor was bad. AZ sold me a new one; I installed it, and the problem was solved.
sometimes over heating coupled with poor cabin heating is a strong sign that a head gasket is going bad. 98 Subies are known to develop this problem. Look for bubbles in the radiator over flow tank when it is over heating. If you see bubbles, then you know that exhaust gas is getting into the cooling system through a bad head gasket. There is a lot written about the Subie head gasket problem in this forum. Look in the "search" section near the top of the USMB for past info posted about this problem.
Sorry to hear about your problem at AZ. I have had similiar problems with AZ and Advance Auto Parts rebuilt starters and alternators not lasting very long. It is reasonable for them to give you a free replacement per their lifetime guarantee, but no store including a Subaru dealer is going to give you your money back after using the part for 8 months. That is unreasonable, and not within the bounds of a lifetime guarantee. Refunds are only given in the retail industry when the part is returned unused shortly after purchase, usually because it was the wrong part. I have no affiliation with AZ. I have always found them to be honest in all dealings, and their staff very helpful.
I read several years ago about polishing dulled plastic head light covers using tooth paste and a wet paper towel. I did that on my Subie, and a Dodge mini van with good results. It doesn't matter what brand of tooth paste is used, though best to avoid the jell type tooth paste, as that type is not abrasive enough.
I have had to fix the same problem on my wife's car. I used a spray bottle of windex, and wiped everything down with paper towels. I pushed on all the buttons on the heater control while doing the wipe down to make sure that they were loosened up. I also had to do the same thing on the radio buttons. Earlier, there was so much soft drink sugar spilled on the cup holder that it wouldn't open or close properly. I removed the two screws holding the unit in, unclipped the sides of the unit that holds it together, again squirted everything heavily with windex, and reassembled. All works well now.
I agree whole heartedly with Nipper, slow way down and don't let the dealer overwhelm you and your brother with multiple diagnosis. What reason did your brother give in taking his car to the dealer in the first place? What firm evidence is there that the car has a HG problem? I am the guy that posted recently about the problem with the 99 and 00 Legy model with the AT problem of slow shifting when stopped from D to R, and conversely from R to D. I added a bottle of Lucas Trany Fix to my car. It helped a lot to solve the problem. It cut in half the delay time in getting the trany to change directions. I would also suggest changing the trany fluid and its external filter. This however, is a project to fix a relative minor problem. My guess is that the AT shifts well to all gears once moving. The inconvenience of slow shifting from D to R, and vice versa is not a sign that the transmisson is going bad. I would question the value of the dealer tell you other wise, if that was what was said.
Welcome aboard, as mentioned above there are a lot of people that know a lot about Subies on this forum, and are glad to share their knowledge with you. It is also good to dig through the archives on this forum for answers to a particular problem you may have before posting. Click onto "search" at the top of the message board, type in your subject topic, and watch what others have posted on the subject. It is truly a great resource. Again welcome aboard, don't be bashful asking for help, or writing your opinions in trying to help others.
I learned this repair trick from a mechanic who replaced a section of brake line on my old rusty '84 VW that I owned. Later, I had another section of brake line rust out, so I repaired the new leak myself using the same technique. Using a tube cutter, I cut out the bad piece of brake line on both ends where there was at least two inches of straight tubing remaining on both ends that was not rusted. I measured the length that I had removed, then took a small section of the old brake line with me to the auto parts store. There, I bought super heavy duty hydraulic hose that is not degraded by brake fluid. I bought the hose diameter that had an inside diameter just slightly larger then the brake line outside diameter. With the small section of old brake line that I brought with me, I made sure that the brake line would snugly slide inside the hydraulic hose. The hydraulic hose will look a lot like vacuum hose, but much thicker, and contain woven cord for strength. DON'T LET THE COUNTER GUY SELL YOU RUBBER VACUUM LINE, AS THAT PRODUCT IS NOT STRONG ENOUGH TO WITHSTAND HYDRAULIC PRESSURE, AND THE RUBBER HOSE WILL BE DEGRADED BY THE BRAKE FLUID. I bought a length of hose that was about 12 inches longer then the brake line section that I removed. The extra length allowed about 2 inches of hose to be slid on to each end of the original brake line tubing. Any extra length I cut off and threw away. Flaring the ends of the brake line before sliding inside the hose is a good idea, but not absolutely necessary. I secured the hose to the tubing with six hose clamps, using three hose clamps on each end. I wanted to make sure that the hose could not, and would not come loose, or leak. I used nylon cable ties to secure the new hose, so that it would not rub against anything on the car under body to create a chafe leak. I drove the car like this for a good five years with no problems. Finally, the car became such a rust bucket that I junked it. The hydraulic hose approach works so well, because you are not having to bend new metal brake line, that never seem to line up just right for connection. It is just so much easier working with a flexible hose. You will need to bleed out your brakes after using this, or any other brake line repair, but I am sure that you prolly already know that. Let us know how you fixed your problem.
Last summer my wife broke off the pass door mirror on her 98 OBW Limited. It was impossible to find a Limited in a wrecking yard with the heated mirrors. So, I had to replace with a non heated mirror. It was simply a matter of not hooking up the two factory wires in the door wiring to the non heated mirror. What was a bear was removing one of the philips headed screws that is accessed through a hole in the door frame. It takes a drive with the proper size philips head to get enough leverage to loosen. A regular screw driver will not give you enough leverage. Good luck on the update. I hope you can find the replacement mirrors easily.
You are right about the thermostat excuse. I looked at a 97 OBW last year. Seller said he thought the car had a thermostat issue. Sure, it would idle without over heating, but he said driving it for a while would cause over heating. He had also just installed a new radiator, but still had over heating. I told him I thought it needed a HG replacement. He ask me appx cost. I told him around $1,500. I think he really knew it needed a HG, so just really wanted to sell the car to avoid the repair expense.
Yep, my vote is bad HG. The big clue is your saying " temp gauge sky rocketing into the red", that is a sure sign of a bad HG, as exhaust gas forces its way into the cooling system. Be suspicious of buying that car, because you don't know how many times, and for how long, the motor has been over heated.
