Rooster2
11
Everything posted by Rooster2
When my 2.2 blew a HG, the exhaust gasses entered the cooling system to the point that the added heat and pressure caused the radiator to spring a leak and loose a lot of coolant. Not knowing about the over heating problem, as my wife drove the car and never said anything about over heating, I thought a new radiator would cure the problem. When finally I realized the car was over heating, I figured out the HG problem. It is rather amazing how an exhaust pressurized cooling system can cause the cooling system to leak mass quantities of coolant in a short period of time.
I bought Bosch plug wires, and use Bosch Platinum plugs on my OBW from an upscale foreign car parts house. Car seems to run okay. I bought and installed these items before joining USMB, where I constantly read about only using Subie OEM parts. The Bosch plug wires were expensive and work fine, it's when you buy the cheapie plug wires from AZ, Advance Auto parts, or other similar parts house that you run into trouble.
Agree that receipts from Advance and AZ have quick fading ink if exposed to sun light. Maybe that is how they get out of honoring life time guarantees by using invisible ink. I have manilla file folders for each of my cars. I buy something for a car, the receipt goes into that car's folder, and then the folder is kept in a filing cabinet in my home office. That way it is easy for me to see when I did brakes on a car, or any other work over the years. Just my 2 cents worth.
A parts store like Auto Zone or Advance will take their testing equipment out to their parking lot to test your battery and alternator function, while the battery and alternator are still in the car. No need to wrench out anything to carry inside the store for testing. Part store rebuilt alternators are not the best, but cost about $120, not like $300 when new from dealer. The rebuilt will come with a life time warranty, and since it is not difficult changing an alternator yourself, it is the route that I have taken. Take some tools with you if it turns out to be a bad battery. Many a time, I have swapped out bad batteries in the parking lot of the parts store. Only should take about 10 minutes to complete the job.
I posted a couple of weeks ago about using a "one man bleeder system" in response to someone having trouble with air in the brake lines. The little system works very well, and is great for the "do it your selfer." I wrote a lengthy step by step report on how to use the one man bleeder. Should be easy to find in the archives. My bottle kit is pretty much like the first one shown on the website, except that mine has a magnet affixed to the back side of the bottle, instead of the stainless steel wire holder hook. No big deal. My unit does not have a pump, and I don't see an advantage having one.
Sounds like SOA is coming to your aid, and also staying abreast of your trouble. I have heard of dealer screw ups before with a number of cars made by different manufacturers. Your saga ranks right up at the top in terms of a dealer induced mess. After a while you can only laugh to keep from crying. I just hope things get better for you, and try not to loose your temper while still dealing with these clowns. Persistantly keep after them with a telephone call every two or three days to inquire about work progress, or drop by to see the rebuild. The situation can only get better.
I flushed the brake fluid in my 2 Subies last summer. I bought both cars used, so prolly the fluid was the original in both. What pumped out was the color of ice tea. I didn't see any "chunks" or dirt, so maybe that was a good sign. I just feel better knowing that fresh fluid is in the system, and both brake pedals are rock hard.
Yes, those plastic clips holding down the sill piece will definitely break if yanked at when cold. The cold makes them brittle. Suggest using a hair dryer to warm up the sill piece and therefore the plastic clips. Take your time to get the sill nice and warm to the touch. Pull up the cover with your hands, or gently pry with a screw driver. Good luck!
Quote:I demanded a refund and a new engine, the manager said I can't have both. My thought is that I agree with the manager statement. It is unreasonable for you to emotionally demand a refund, and a new engine. As unappealing as it is to continue dealing with these clowns at the distributor, they owe it to you to fix your car at no additional cost, and with a written guarantee. How they fix it is really there call. The end result, is that the repair must meet your satisfaction. A written guarantee is necessary to make sure there work lasts a good long time. The SOA rep needs to be advised of this entire mess for sure.
I have always heard that there is no problem recording a telephone conversation between two people if you are one of the parties in the telephone conversation. You have no obligation to tell the other party that you are recording them. If you have to go to court, transcribe the tel conversation to paper, then submit the transcription as evidence in "discoveries" in the court hearing. You can say that you have the tape to play to back up the transcription, if requested to do so. O, now I read that you had a recorder in your pocket. Still, the above advise still stands, transcribe the conversation to paper, and present in court at appropriate time.
I had a 91 Legacy with A/T, the fuse holder for FWD is definitely under the hood on the passanger side near the fire wall. To be in AWD, the fuse holder should not contain a fuse. Yea, I know that may sound wrong, but it is correct information. That big snow storm hits Indiana on Saturday PM with about a foot of snow forecasted. My 2 Subies with AWD are both ready for the challange.
I had the same trouble as you last summer with my 98 OBW. Light would go on then off, finally went on long enough to have the code pulled at Auto Zone. They told me it was the knock sensor. I bought one from them for $80 inc. tax out the door. Installed it myself with little difficulty. That fixed the problem. Use the "search" feature on this forum to read past posts about installation, if you are a "do it your selfer".
I had a failed cat converter in an Audi. Pieces of the honey comb cat material broke loose inside the cat. I could hear the pieces rattling around for some time. Sounded like pea size gravel rattling around. I ignored it, finally one of the pieces lodged itself inside the muffler pipe. It caused such back pressure, that the car would not go faster then 45 - 50 mph. The car would idle just fine. I don't think your problem is a bad cat. Suggest you find the cause of the maf codes that are presenting themselves. Suggest swapping in the injectors, maybe that will help. Spark plugs and OEM Subaru plug wire set may help too.
They have yet to find the problem they created with the car, and now thanks to another mistake of theirs the engine has overheated for the first time in its life. Sure the fans should have been plugged in for power. However, on the positive side, with cold weather, and if you kept the car moving, and not in constant stop and go traffic, the motor would not have over heated that much to cause damage. Cold air being pulled into the radiator while driving would have kept the motor fairly cool.
I think you have the 2.2 motor in your 93, where as I have the 2.5 motor phase one in my '98. Maybe that is the difference. I had a '91 2.2 years ago, I remember changing out the starte on that car, it seemed a lot easier, and a lot faster to do with less junk in the way. All I can say, is that it seemed more difficult doing the job on the 2.5.
If the vibration is at idle, and the car is not moving, then I would consider that it needs a tune up with new spark plugs and spark plug wires. If other then that, if the motor seems okay at driving speed, then I would not have too much concern about the health of the motor. It is prolly a problem that can be easily fixed. If you like the car, use the bad idle as a bargaining chip to get the dealer to lower the price of the car substantially, or repair prior to your buying it. If you have read posts on this forum, you will quickly learn that the 2000 model has a tendency to ruin head gaskets. That is expensive to get repaired. So, it is imperative that when test driving the car to notice if the temperature guage starts reading "hot" after driving for 10 to 15 minutes. That is a sure sign of a bad head gasket.
Pretty sure if your get down on your hands and knees and look under the back end of your Subie, you will see that your duel exhaust system is actually formed with a single exhaust pipe branching into a "Y" configuration. I don't think this is anything more then a cosmetic addition to the car, and does nothing for performance. Perhaps, more exhaust gets dumped into one side of the "Y" then to the other side, so you see more water vapor (steam) out one the tail pipes. This is not an indication that you are having a problem with your car.
If you buy a rebuilt starter from AZ (Auto Zone) or another parts house, they will want your old starter (parts house will call it a core) as a trade in for furture rebuild, as part of the deal. Otherwise, they will charge you additional money, if you don't trade in your core. Since AZ offers a life time warranty on their rebuilt parts, I have always given them my core. With this approach, I am not screwing around replacing solenoid contacts on my own. With a (new) rebuilt from AZ, I am assuming that I will be getting a starter with new solenoid contacts. AZ Subie starters have always lasted a good long time for me.
