Everything posted by Rooster2
Max 14" Tires for Legacy with Outback struts
Rooster2 replied to uniberp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have used the basic screw type spring compressors to change put KYBs on a VW, and long ago on a Datsun 240Z. Using one of those screw down compressors scared me to death. I was always worried about the "hooks" slipping, and causing someone to get hurt. Later models had clamp "hold downs" to prevent slippage, but still plently scary to work with. So be careful. One bad slip, can put you into the hospital. BTW, I remember using a bottle jack placed under the assembly to raise the replacement strut unit into place for rebolting. It really works slick, so try that if you haven't done so before. As far as tire sizing, it may be trial and error to find a tire that is larger, but will not rub the fender or suspension parts during suspension movement. My suggestion is going to a 195 X 75 X 14 as you are already thinking. Going to a 195 X 70 X 14, will be a little wider, but not quite as tall as the 75 series (195) tire. You may want to go to a small independent tire shop who will work with you. Going to a large tire store wanting something unusual for an unusual car set up, is not their strong point. A large tire store wants volume production in sales, with as few customer returns as possible. Because of that, I have had big tire stores only willing to sell me the tire that's specified by the car manufacturer as OEM size tire in their computer. The store did not want to take a chance of me coming bad because of a tire rub problem. I hope the advise helps. Good Luck!
Which to buy OBW or Forester?
I have been looking at upgrading to a newer Subie. Looked at several OBW and Foresters built in the early 2000s. What's the differences between the vehicles? Is a Forester just a taller OBW? Is the OEM equipment the same on each vehicle? Is cost about the same per year of manufacturer? Does one keep more resale value? Interior space seems about the same, except that the Forester offers more vertical space, or maybe that is an optical illusion. Any thoughts and advise would be appreciated. Thanks!
heat shield!
Rooster2 replied to aartod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have had the same problem on my 2 Subies. To fix a low tech problem with a low tech solution, I put the car on drive up ramps, with the motor running, I crawled under the car. Using gloves to keep from burning my fingers, I pressed and pulled on the shroud at various spots to figure out where the shroud is loose and vibrating. Once I located the spot or spots, I would take a hammar and pound in a good size bolt as a "door stop wedge" to stop the shroud from vibrating. I found this "fix" a lot easier then working to remove the shroud(s). It has been a couple of years now, since I have done this, and the bolts continue to stay in place and keep things quiet. If one does ever fall out, I will simply replace a bolt. It really takes less than 5 minutes to complete the work.
Towing with a Subaru?????
I posted earlier that I think it is a bad idea, others think so too. Therefore, it doesn't take much imagination for a cop seeing this towing rig to think it is a bad idea also. If so, expect to receive a hefty violation ticket for breaking some law. Next, their would be towing fees and in-pound lot fees, when the whole mess is hauled away.
1998 Subaru Legacy Outback - should I consider buying
Rooster2 replied to jowens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAgree prolly a good price is $4500. That is about what I spent on my 99 OBW last December. Suggest you do an internet search for used car prices by looking at Kelly Blue Book and Edmunds Used car prices. Print out the prices, then use the info to get bargain the price lower. I have both a 98 and 99 OB Wagons, and have not had any trouble with blowing head gaskets. I have heard that the problem affects about 10 to 15 % of these cars. So, I keep holding my breath that I own a car in the 85 to 90% side of the ledger that never has hg problems. BTW, I am very satisfyed with both cars. They both drive nice, with no unusual expensive repairs so far.
Brake Leak Where is It ?
Rooster2 replied to 96OutbackGNW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you looked at the calipers behind each road wheel? Have you traced the brake lines back to each road wheel looking for any wetness caused by a leaking brake line. Usually, any substantial brake fluid leak is not that difficult to spot. I am surprised that so many mechanics have looked at your Subie, and haven't found a leak.
I think you are asking any Subie to do more than what it was designed to do. Towing a loaded car hauler is too much for any vehicle that is of unibody construction such as a Subie. Your tow vehicle needs to be something with a full frame under it, like a full size p/u truck with a V-8 motor.
Disassembling headlight assembly ?
Rooster2 replied to Chip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a 98 also. I don't think the headlight unit can be disassembled. The unit is glued together, and would break the plastic before the glue would separate. On my car the clear plastic lens gets cloudy. A good rub down with tooth paste brings back clarity. You may want to try doing that.
I want to know where the spark plugs are on this motor and if it will work
Rooster2 replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBlow up the pictures. You can see the sparkplug wires going through the valve covers.
Trouble shooting window washer pump
Rooster2 replied to Dickensheets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAgree with Nipper, you are over thinking the problem. I have had a number of window washers go bad in a number of cars, and it is ALWAYS the little pump motor that goes bad. Suggest taking the old unit off, take it with you to an auto parts store, and ask the parts guy at the counter for a replacement. They are somewhat universal, mostly a matter of matching the electrical connector to a replacement. Years ago, I replaced a broken pump motor in a VW with one that was made for a Ford. It worked perfectly. BTW don't run a windshield pump motor very long if it is not pumping washer water. The water flow is used to cool the pump motor. Running without water for a long time will burn up the motor.
Replacing steering wheel on 99 Legacy OB
Rooster2 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the advise. I will try the epoxy fix first. If that doesn't work well, then I will replace the steering wheel.
Differential problem
Rooster2 replied to '92legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInsert a fuse in the holder under the hood near the fire wall on the passanger to deactivate the rear diff. This will let the car drive in front wheel drive only. Depending how long you drove with the rear diff over heating with the smoke rolling out will be the determining factor on wheather you fried the diff or not. A used diff from a wrecking yard shouldn't cost too much.
I bought my car used recently. Only after I bought it, did I realize that the top arc of the steering wheel cover is loose from its steel core from about the 10 o'clock to the 2 o'clock positon. It is annoying to drive the car with the loose cover wanting to rotate in my hands. I can't think of any way to repair the existing steering wheel, so I guess my next hope is to find a good steering wheel in a wrecking yard. Would a used steering wheel be expensive considering that the air bag is in the middle of the steering wheel? What work is involved in doing a swap? What steps do I need to take to prevent the air bag from blowing up in my face during replacement? Any advise is greatly appreciated.
Help: Upcoming oil change, which kind?
Rooster2 replied to calazo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't go out of my way to use Mobil oil lubricants, but I have alway held them to be of high quality. What kind of difficulty have you found with their motor oil, that has you shopping for something else?
OEM vs. Aftermarket
Rooster2 replied to jcniest5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI replaced my plug wires and plugs on my 99 Outback, before joining this forum. Most posts that I read say to use OEM wires and OEM plugs, but I bought plug wires from an up scale foreign car parts house for $40 some bucks. For plugs, I use the basic Bosch platinum with single electrode. This setup keeps my Subie running just fine. I don't think that I would buy cheapie wires from Autozone or Advance, or a parts retailer like them. With that lower grade quality, you would be asking for trouble.
Well, I'm official now!
Rooster2 replied to Towel Rail's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCar looks good, nice to have the po receipts too. Could use a good engine bath. When my motor looks like that, I squirt about a half bottle of dish washing detergent over the motor, then rinse off with a garden hose. Let it sit for a couple of hours with the hood up to let the sun dry off everything before restarting the motor.
A day spent with the Legacy (new exhaust and car wash)
Rooster2 replied to TheSubaruJunkie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSuggest adding an extension to the end of the tailpipe to make up for that missing 4 inches. Otherwise, carbon deposits will dirty up your bumper cover with black soot, and the heat may distort the plastic bumper cover over time. I know, that is what I encountered on my VW a few years back. Yea, the engine sounds mean and great for a while, however you will want to listen to your radio or a CD, but the exhaust noise gets in the way. The extra length on the tailpipe will quiet the system down a little inside the car, but well worth it to get the best of both worlds of a sweet sounding car, and a low restriction muffler system.
Red is Sick (in a bad way)
Rooster2 replied to Sonicfrog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhew.........gotta be a relief that the problem is just the fork, not the clutch itself. Lots less money to repair.
90 legacy question
Rooster2 replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the fuel filter is partially clogged, it generally is most noticable at high rpm or higher speeds on the freeway, where more gas is called for, but can't get enough through the filter. Still, poster wrote that car was experiencing mostly a hot start problem. Might be a sensor problem.
Replacing a rear door window on 93 Legacy
Rooster2 replied to mikeshoup's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is often possible to get the wrecking yard to send a guy with you with a battery or jumper box, if you nicely tell the counter man that you want to pull a door glass, and need a power window lowered to do so. Sometimes, the yard guy with the battery/jumper box will help you pull the glass without asking if he is not busy. Other times, it helps to grease the guy directly with a $5 or $10 bill for his extra help. Watch the guy closely, so you can see how he removed the glass, so you can remember how to reinstall. Also, collect (to take home) all bolts, nuts, etc, that were removed to free up the glass. You never know when you might need some of that extra hardware.
90 legacy question
Rooster2 replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProlly wouldn't hurt to throw a can of injector cleaner into a full tank of gas. Use the good stuff costing about $6/bottle. The cheap stuff doesn't work well.
Electrical Issue
Rooster2 replied to TurboPropAirman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a hunch that your battery has gone bad with a bad cell. I had a VW that did what you described. The car would still start, but guages gave out wierd readings, and the engine started running badly. It was all because of low voltage, like 10 Volts. Once I replaced the battery, everything was fine.
Rooster2 replied to mikeshoup's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am thinking doors from a 90 thru 93 fit on a 93. To change just the glass, you will need to pull the inside door panel. It requires some prying with the blade of a pocket knife to release the plastic cover clips behind the inside door opener lever. It isn't a great Subaru design. Once the panel is removed, lower the window frame holder to the near bottom of the door. Pretty much a matter of vacuuming out broken pieces of glass, and installing new glass in the frame, then raising new glass to adjust. Not a difficult job. The nastiest part is removing the tape residue left behind, when a plastic bag or cardboard was taped to the door frame and roof that replaced the glass.
Best deal on KYB struts?
Rooster2 replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have run KYBs on a number of cars and love them. They can be bought at a reasonable cost, perform very well, and last a good long time.
Shops in Southern Indiana
Rooster2 replied to StructEngineer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI live in Indy, and can only provide you with a name of a good shop in my area. I am not any help in knowing any private garage, that is honest and good at working on Subies in the Louisville area. Since you don't know anyone in your area with a Subie, your next best referral system is to ask a number of people who own Japanese cars where they get their cars repaired, other than at a dealer. I have always felt that their is a certain amount of generic engineering influence that is common among all Japanese cars, and if a shop works on Hondas, Toyotas, and Nissans, they are going to be better prepared at working on a Subie, then say a shop that works mostly on GM cars. You may also want to go to the telephone book yellow pages and look under "automobile repair." Some shops may state that they work on foreign cars. You may want to call some of those shops, and inquire about their familiarity with working on Subarus. If you get some Japanese car repair referrals, and some foreign shop listings, you should be able to meld the two efforts together to come up with a shop or two that can provide good repair work for you at reasonable cost. Yes, this is going to take a bit of work on your part, but if I were in your shoes, that is how I would go about it. Good Luck!
