Rooster2
    11
Everything posted by Rooster2
  1. Whew.........gotta be a relief that the problem is just the fork, not the clutch itself. Lots less money to repair.
  2. If the fuel filter is partially clogged, it generally is most noticable at high rpm or higher speeds on the freeway, where more gas is called for, but can't get enough through the filter. Still, poster wrote that car was experiencing mostly a hot start problem. Might be a sensor problem.
  3. It is often possible to get the wrecking yard to send a guy with you with a battery or jumper box, if you nicely tell the counter man that you want to pull a door glass, and need a power window lowered to do so. Sometimes, the yard guy with the battery/jumper box will help you pull the glass without asking if he is not busy. Other times, it helps to grease the guy directly with a $5 or $10 bill for his extra help. Watch the guy closely, so you can see how he removed the glass, so you can remember how to reinstall. Also, collect (to take home) all bolts, nuts, etc, that were removed to free up the glass. You never know when you might need some of that extra hardware.
  4. Prolly wouldn't hurt to throw a can of injector cleaner into a full tank of gas. Use the good stuff costing about $6/bottle. The cheap stuff doesn't work well.
  5. I have a hunch that your battery has gone bad with a bad cell. I had a VW that did what you described. The car would still start, but guages gave out wierd readings, and the engine started running badly. It was all because of low voltage, like 10 Volts. Once I replaced the battery, everything was fine.
  6. I am thinking doors from a 90 thru 93 fit on a 93. To change just the glass, you will need to pull the inside door panel. It requires some prying with the blade of a pocket knife to release the plastic cover clips behind the inside door opener lever. It isn't a great Subaru design. Once the panel is removed, lower the window frame holder to the near bottom of the door. Pretty much a matter of vacuuming out broken pieces of glass, and installing new glass in the frame, then raising new glass to adjust. Not a difficult job. The nastiest part is removing the tape residue left behind, when a plastic bag or cardboard was taped to the door frame and roof that replaced the glass.
  7. I have run KYBs on a number of cars and love them. They can be bought at a reasonable cost, perform very well, and last a good long time.
  8. I live in Indy, and can only provide you with a name of a good shop in my area. I am not any help in knowing any private garage, that is honest and good at working on Subies in the Louisville area. Since you don't know anyone in your area with a Subie, your next best referral system is to ask a number of people who own Japanese cars where they get their cars repaired, other than at a dealer. I have always felt that their is a certain amount of generic engineering influence that is common among all Japanese cars, and if a shop works on Hondas, Toyotas, and Nissans, they are going to be better prepared at working on a Subie, then say a shop that works mostly on GM cars. You may also want to go to the telephone book yellow pages and look under "automobile repair." Some shops may state that they work on foreign cars. You may want to call some of those shops, and inquire about their familiarity with working on Subarus. If you get some Japanese car repair referrals, and some foreign shop listings, you should be able to meld the two efforts together to come up with a shop or two that can provide good repair work for you at reasonable cost. Yes, this is going to take a bit of work on your part, but if I were in your shoes, that is how I would go about it. Good Luck!
  9. Well, I guess that you could call a Subie dealer, and tell your story to them, and maybe get a freeby alternator out of the deal. However, let's face it, your alternator is 11 years old, and almost all alternators that old have failed by now. If it were me, I wouldn't feel bad about having to pay for a new one. It is a pretty simple do it yourself job, if you are handy with a wrench.
  10. Does anyone have filter parts numbers if I were to purchase a Wix, Napa, or Carquest trany filter?
  11. Agree with Alias.........it would be way too much work rebuilding the trany yourself. It is just so much easier to R&R with a used or rebuilt trany. Best to leave trany rebuilding to a rebuild shop.
  12. Nice work. It is always satisfying to successfully repair your own car. With that success, you might consider a second career as a mechanic at you local Subie dealer. They alway need good mechanics!
  13. Beyond adressing the other issues posted by others in doing the exchange, you may want to consider replacing the head gaskets on the replacement 2.5 motor before installing it in your '97. No easier time to do it, then when it is sitting on an engine stand.
  14. Pull a plug wire, then ground the plug wire to verify that you are getting spark. Then I would pull the spark plugs and squirt some ether (starting fluid)inside each cylinder. Pulling plugs on your 2.2 motor is fairly easy to do. Start the motor, it will help clear out any flooding, and get gas flowing into the motor. Suggest changing the oil, using ether, flooding, and sitting causes the oil to go bad.
  15. I bought my 99 Legacy OBW about 6 months ago. I had no records on ATF change, but the fluid on the dip stick did not look dirty. Anyway, I changed the ATF 2 times, by simply running the car up on ramps, then pulling the drain plug on the bottom of the AT pan. It is a very easy "do it yourself" project, since the drain plug screws in and out just like the drain plug for the motor oil. Now, I know for sure that my trany fluid is new and fresh.
  16. Glad to have helped. Save that 4 foot length of pipe. You never know when that pipe will be the needed tool in the future. Good luck on finishing the rest of your repair project.
  17. It is truly amazing the amount of extra leverage you can get by adding a 4foot bar to the end of your half inch drive handle. It is truly the next best thing to use if you don't have an impact wrench. Squirt on some PB Blaster if you see any rust around the nut. Even using a smaller 3/8" drive, I will add an 18" bar over the end of the handle to gain extra leverage. Makes all tight bolts/nuts a lot easier to remove.
  18. Maybe not flood. Flood damaged cars usually don't require a complete repaint.......but wrecked with a lot of sheet metal damage, that a complete repaint was called for is hard to imagine. For an insurance company not to repair a 2006 model, the accident must have been severe. The only way to buy this car is on the cheap. A bid of $6K is beyond cheap in my opinion.
  19. It may be something as a vibrating shroud around the exhaust system. Both my 98 and 99 Legacy OBWs developed this. It was almost like a "zzzing" sound that would resonate at only certain engine rpm. Mine would not do it at idle, unless I turned on the A/C, which slightly lowered the rpm to create the noise. I put the front end of my car up on ramps, then crawled underneath the car with a long screw driver. Using the screw driver, I pushed on the shroud at various points until I located the source of the noise by stopping the vibration. To cure the problem, I found a large bolt, and hammered it into position between the shroud and the exhaust pipe as a wedge to keep the shroud from vibrating. Sort of a really low tech fix for a low tech problem, but the fix still works perfectly after a couple years of driving. I don't know if your 92 and 93 have the exhaust shroud covers, but if they do, then I would bet the farm that the shrouds are the cause of your noise.
  20. Just my 2 cents worth from here in Indy. I checked my receipt folder on my 99 Outback. Last February, I had the right front wheel bearing, and inner seal replaced. Cost out the door was $199.41. Labor to do the job was 1 hour at $70.00. This was done at a Big O Tire store, a big tire chain outfit. I don't know if they pressed in the bearing themselves, or sent it out to have it done. A labor time quote of more then 2 hours, sounds ridiculous to me.
  21. Thanks, I will take a look see per your instructions. I guess I am still a little confused, if I see the edge sticking out, then is that the indication that the HG has been replaced? If so, then I should infer that the original HG must not stick out? You are very lucky that you bought your last two used Subies with replaced HG replacements. Sure, no guarantees that they will hold up, but beets relying on the ones that came with the car new. My previous experience on bad HG was on my 91 Subie Legacy with the 2.2. The HG went bad, then excessive pressure caused the radiator to leak. The motor had about 175K miles on it, so I went the route of replacing the motor with a 2.2 from a wrecking yard out of a 92 Legacy with 112K miles on it. Overall cost came to about $1,000 to complete the swap. That was a great running motor for about 3 years, then traded in the car when the auto trany went south. Car would not shift into high gear.
  22. I have two OBW, a 98 and a 99. Both were bought used, so don't know if PO replaced the HG. Remember someone posting earlier about looking for a corner of the HG sticking out to see if it is the new three layer type of metal HG, but, I am not clear about preciesely where to look around the edge of the heads, and exactly what to look for. Should I first power wash around the heads to produce a good clean view? Thanks for any advise.
  23. If I were to ever own a Pilot............I would name it "Pontius."
  24. I find the 200K list pretty ridiculous. With proper maintenace, like change the oil every 3 K miles, and driven with reasonable care, every car made today should easily be able to make at least 200K miles before hitting the wrecking yard. It is a real shame to go to a wrecking yard, and see cars that are there, not because they were wrecked, but because they were poorly maintained, or simply hard driven into the ground. What a waste of money!
