Rooster2
11
Everything posted by Rooster2
Getting back to fixing my p/s pump problem. Life has gotten in the way to fix this project. I don't see a leak, so it must be a mechanical problem. I checked you tube, all I see is how to r&r all the seals to fix leaks, not anything on how to repair the mechanical action of the pump. How much is a new genuine Subaru pump? Any way to tell if a pump from a yard is genuine? Thanks for any advise. Rooster2
I have been buying more and more parts form Rockauto.com. Quality is good, so is pricing. I generally buy their mid priced offerings, not the cheapest, or most expensive. Rock Auto delivers quickly, and if a return is necessary, they will send you a Fed ex return label on line that discounts cost of return at the Fed ex store.
My 2.2 1995 Subie motor in my 98 Outback jumped timing. I was surprised this happened as entire timing belt kit changed in summer of 2019. Found the source of the problem to be threads in the block pulled out upon removal of " loose pulley" next to tension-er. I had never heard of this before. Fixed the problem using a helia-coil. Thank God the 95 Subie motor is non interference, or things could have been a lot worse. Anyone else have this happen?
I have used the "universal fit," hoses the ones with the coily spring inside the hose, where you can bend it into any shape you want. They seem to work okay, but you need to really tighten down on the clamp. Also, check weeks later that the hose is tight, may need to tighten up some more. I am using one of these on my 99 Legacy Outback. Works just fine, but I have two hose clamps to make sure it stays tight.
Like you, I have a 99 Outback. I bought it back in 06, with 148K on the odometer. I now have 256K on the odometer, and she still runs strong. I put on KYB struts at around 160K miles. I did not replace the springs, and have not regretted it. The KYBs run great, and last a long time. The probable original springs still seem good as new. 99 Outbacks have an inherent problem with the transmission, in that it will develop a delayed forward engagement from park. The problem is that Subaru went to a revised tranny in 99, and a valve unit fails to operate properly. It can be corrected with a tranny additive. If your car has, or develops this problem, do a google search for "Subaru, delayed tranny forward engagement." I started the topic back in 2008, and it has helped many Subarus.
I have bought and used the "do it yourself" rust proofing kits. They are rattle spray cans. Some cans for inside door application, some for metal exposed to the elements. They work well in my opinion. Just make sure the metal is clean and dry before spraying on outside metal. It has been a long time, since I have bought one of those kits. I don't know if they are even sold anymore. Worth checking out. Cost is cheap.
Mitchy, I have been hammering in sheet metal screws, bolts, what ever I could find to hammer in to stop the shroud rattle around the exhaust for years. I have never used nails. Nothing has ever fallen out that I can ever tell. It is a red neck fix I know, but a good one in my opinion. Sometimes the shroud can easily be removed, so I do that to fix the noise problem. The shrouds are there to protect against starting a grass fire, should you ever park in tall dry grass. I never park in high grass, so no problem.
Just this Fall, I did an oil change job. I bought an oil pan bolt with a fiber washer from Advance Auto parts. So far so good, on not leaking, but it does need to be tightened really well. I never could get the Subaru crush washer to work more then once without a small leak. I will keep a check on the fiber washer to see if it leaks or not.
