Rooster2
11
Everything posted by Rooster2
I read something about that too, but never have seen the evidence. Seem to remember it being pointed out that the corners are where to look for the head gasket sticking out a bit.
- 11 replies
- Outback
- used outback for sale
(and 1 more)
Tagged with:
Your original post was 2/15, and follow up today. Guess all is well with the replacement diff. Installing a used diff was a smart move. That is what I would have done under the circumstances.
- 5 replies
- differential
- baja
(and 3 more)
Tagged with:
I have a 98 Outback, been a good car. Head gasket trouble is the weak point on this model. It presents itself as engine over heating, not oil mixed with coolant. Doubt that the dealer will have any vehicle history to tell you that the head gaskets have been replaced. Unaware that there is much trouble with the auto tranny.
- 11 replies
- Outback
(and 1 more)
Tagged with:
Well, so much for the sticker saying the unit passed "triple checked in Malaysia". Maybe going to a quad check system will improve quality. Hard to believe a reman shop in Malaysia would export their work to the USA. You would think that shipping cost would eat up too much of their profit. All the parts stores sell reman products with varying degree of creating a quality product. Just impossible to learn what company did the reman work. Over the years, I have heard a number of stories of remans returned to AZ, but not so much so to Advance Auto. It has been my experience that all the parts stores have no problem in swapping out a defective reman product under warranty, usually with no questions asked.
I, too, have had good luck with Advance Auto starters and alternators over the years. AA always has coupons available on line to cut cost. Couple weeks ago, I had the alternator go bad on wife's 98 OBW, with 1995 2.2 motor. I was able to buy on line, and with coupon, cost was about $80.00. Part was in stock, for quick, and easy pick up. I guess I am lazy, as I did not want to find brushes, and try to do my own rebuild. I just don't have enough time and energy for that. An alternator swap out is easy and quick on a Subie.
Sounds like your shifter bushings are worn out. Sounds like you are experiencing a lot of "slop" with a loose shift lever when changing gears. Check the archives on this subject on this website. Lots written on the subject, and how to replace the bushings. I have never done that job, but seem to remember reading that it is not a difficult job. Just need to get the car up on a lift to gain access to the shifter. A repair garage should not charge much for this work. Don't think it is labor intensive. The lever "slop" could also be the source of your back up lights not working. I wouldn't be surprised that the shift lever is not depressing the back up light switch. If so, then the switch is not activated to turn on the back up lights.
I have done well ordering parts on line from Advance Auto Parts. Sometimes the part I want to order is in stock at a nearby store. Advance always has discount coupons for on line orders. My last $50 order for a Subie valve cover gasket kit, antifreeze, and oil filters was discounted 30% on all items. I picked up the part at their store. Price was then substantially lower then any other vendor on line. If I needed to return, that was easily done for a complete refund. Not always can you find Subie parts in stock, but often enough. Even if shipped from a warehouse, the part can be returned to any of Advance stores easily. That works out so much better, then returning something to an on line car parts vendor hundreds of miles away, then hoping and waiting that a correct credit amount will be added back onto your charge card.
I am not familiar with the Uniroyal Tiger Paws. However, since you state they are Touring tires, they are at their best on dry clean roads. I am guessing the tread pattern is non chunky, prolly with many straight lines, with few cross pattern cuts, which is typical of Touring tires. Driving soft-road and in the snow would be a challenge for the Tiger Paws. The price is certainly good, but count on sliding around some on these tires, when the weather turns bad.
List on USMB, "Market place - Vehicles for sale, or your local Craig's List. Should sell for as much as $1,000. Unless you just don't want to mess with it anymore, then donating the car to a charity that auctions off vehicles, would be the way to go. Don't recommend taking to a wrecking yard, since you say it still runs.
Imdew............Thanks for the advise. Having a mechanic friend install the Felpro kit tomorrow. I got a better price from Advance Auto Parts on line with a 30% off coupon, when purchasing the Felpro kit. Sparkplugs I replaced last Fall. Good advise though. Just doesn't look like much space to do the work. Hope my friend doesn't cuss the Subaru design too much doing this job.
Take a good look at the rad hoses, and heater hoses for leaks. Even a small leak will empty the reservoir over time. Keep a watchful eye for any leaking coolant spots that may form on the driveway or garage floor, that would indicate leaks. Your Subie motor is prone to external head gasket leaks. Subaru sells coolant conditioner (stop leak) to somewhat fix the problem. If the leak is too severe, then the head gaskets will need replacement. Others on this forum have used the coolant conditioner before replacing the head gaskets, and had good results
Remove the dust cover at the top of the strut under the hood. Try tightening the large strut nut, and other smaller mounting nuts. Could be something loose there. If all is tight, then take it to a shop, maybe an alignment shop, and ask to have the ball joints, and tie rods checked for looseness. Once the car is up in the air on a lift checking ball joints and tie rods for "play" is a 30 second job. An alignment shop likely will do this at no cost. I
