Rooster2
11
Everything posted by Rooster2
No, I have not bought any after market alloy wheels. Plenty to see at most tire stores. They like to sell alloy wheels and replacement tires. My reservation about alloy wheels, is if you live where the roads develop pot holes in the late winter to early spring from the thaw and refreeze of snow and ice. Alloy wheels are known to break, and blow out tires if you hit a really bad pot hole at speed. My daughter blew out two alloy wheels and tires, when she lived in Pittsburgh going to college. What an expensive PITA to get those wheels/tires replaced.There may not have been as much damage, had the car not had low profile tires with little sidewalls. Going to a 17 or 18" tire will be low profile tires. As described above by Ol' Subaru Guy, the 15" Subaru 5 spoke alloys will prolly be just fine. Chuck hole damage with a 15" tire is not as likely.
I have a 98 OBW with the electric antenna. Suggest you lube the mast with graphite, or a light oil. Clean off all the dirt first, before adding lube. If that doesn't fix it, then you will need to remove the power mechanism to see if the cable is broken, or something is wrong with the winding mechanism. It has been my experience with several cars with power antennas, is that they all develop problems over time. Lacking an easy fix on some, I have replaced the power antenna with a non powered unit.
Subarus are not known for a bad head gasket causing coolant to mix with oil. Other cars do that, but not Subarus that I have ever heard of. When your 97 model blows a head gasket, it causes exhaust gas to get pushed intothe coolant system, that then causes the over heating. Air bubbles (exhaust gas) in the radiator over flow tank is a sure sign of bad head gaskets. There is a good chance taht the over heating caused the radiator to leak, not the other way around. Since you don't like, or want to keep the car, then I guess that selling it "as is" is your next step. Kinda surprised you would take the time to post your trouble, since you simply want to get rid of the car. Seems more likely that you like the car more then you have said.
Overheat
Rooster2 replied to xdeadeye1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
It is an easy swap to install a new radiator. I did it on wife's 98 OBW a few years back. Check out both the top and bottom radiator hoses. If worn, it is a good opportunity to replace them. The tranny ATF gets cooled through the radiator, so you will need to add some ATF that will be lost in the swap. -
Nice work, but sounds labor intensive. Were there any Subies around in wrecking yards, where you could have bought an entire hatch, and swapped that in?? Would think that would have been a lot easier.
- 7 replies
- glass
- rear glass
(and 4 more)
Tagged with:
I have been pleasantly surprised with the quality of Walmart batteries. I have bought their top of the line with a 3 year warranty for both of my OBWs. Both are going strong, one with 5 years of service, the other with 4 years of service. It still shocks me to see that the price of batteries has gone up about 35% in the last 4 years. Yea, the price of lead has gone up big time, but is there really a lead shortage to justify the big price jump? What gives??
A history update.........brakes have felt like manual brakes, not power brakes for some years. Last January, I had brake lines replaced at the rear, as they had rusted out. Work was done at a shop that I trust, and felt they did a good job of bleeding the brake system after installing new lines. As stated earlier, the brake booster unit was replaced about a year ago. Still, the brakes felt like manual brakes even with a new brake booster. The brake pedal feels good and solid, when brakes applied, so I don't get a sense that the master cylinder is the problem. Front pads replaced within the last 10K miles, so I think the pads are okay. Still a mystery to me. The car's brakes make the car good and driveable, and not a safety issue. Still, it would be easier having power brakes once again.
Took me a while to get around to working on this. I checked the vacuum hose for vacuum, and it seemed just fine. I replaced it anyway, but found no imprvement. Brakes conntinue to work just fine, but just don't feel like power brakes. It still takes some extra effort brake pedal effort to stop the car. I replaced the brake booster, but that has not fixed the problem. The problem is on my 98 OBW. I also have a 99 OBW, so I can easily tell that the power brake function is not working well on the 98. Any suggestions..............Thanx
what about the water pump is it possible for a water pump to work Intermittently? No, water pump works full time, when motor is running. can my water pump pulley seize up and then break free? seize up again and break free again? or does that never happen? No, water pump works full time, when motor is running. would the belt just slip past it and keep spinnin? No, that could not happen. The next time you start to see the temp gauge climbe above normal, stop the car, open the hood, and check for bubbles in the rad over flow tank. If you see bubbles, it is a sure bet that it is a bad head gasket.
says he swapped in a 2.2 that is phase 1, so would not be OBD2 equipped, so code cannot be read. Agree with you that the actual engine temperature needs to be determined. Swapped in motor with after market cooling parts, and rigged in resistor can't be relyed on to create an accurate temp gauge reading. Seems strange that the fans never come on. Something is not right about this. Are you sure the fan is getting power??
Since the over heating problem is not consistently severe, but randomly, there may not be sufficient hydrocarbons in the cooling system to show up on a test, so it still could be bad head gaskets. I am also guessing the owner is ocassionally replacing coolant, after experiencing a coolant boil over, so that too could lessen hydrocarbons in a test.
I am betting it is a head gasket problem. Subarus with 2.5 motor in 1996-1999 cars are famous for bad HGs. Having blown head gaskets in a 98 and 99 Outbacks, I have some experience. A blown head gasket won't present itself all the time, but most likely to do so, when stressed at highway speed, or climbing steep grades. Then, the temp gauge spikes to HOT in a hurry. Bubbles in the rad over flow is classic symthom of a bad head gasket. It is caused by exhaust gas leaking through the bad HG into the cooling system, so produces bubbles in coolant, and causes motor to over heat. I don't think trying a new T-stat will help the issue. Some people have removed the T-stat, and driven for a while to mitigate the over heating problem. But, that is not much fun driving that way in winter, as it results in minimal cabin heat. What ever you do for the present, do not drive the car when the motor is over heating. Continuing to do that will destroy the motor. Subarus don't like to be over heated. There is a much written on this issue in the archives of this forum. Use the forum "search" feature to do this. Read what others have written, and I think you will come to the conclusion, that bad head gaskets is your culprit.
If I got a second hand EJ25 from a wrecker what other parts would you recommend?Obviously I need to do an oil change and new filter. My water pump probably needs replacing too. Anything else? Well if you decide on an EJ25 from a wrecker, it will need to be from a 1996-1999. Hopefully find one from a car that has been in an accident. That at least gives you comfort that the engine was running at the time the car became a wrecker. All EJ25s from that time era have the weakness with head gaskets going bad. Subru replacement head gaskets were upgraded over the years, so new head gaskets reduce the weakness to some degree. It is always a good idea to replace the timing belt, idlers, pulleys, water pump, and oil seals before installing the engine. When completed, the engine should be good for 160K km. This all adds up to a lot of work, when you know the car's value is 2500 NZD. At some point, you have to decide if you want to take the time and money to repair your car, or take the same amount of money and apply it towards buying a replacement car.
