Rooster2
11
Everything posted by Rooster2
Don't drive the car with this problem, or even running the motor with the timing off. Just more of a chance to bend the valves. Check out timing belts, idlers, and water pump kits on e-bay. Prices are great, and quality is good. If not something you want to work on yourself, then prolly best to have the car towed to a garage, and have them do all the work.
Since for sale by a private party, guess that means owner, not dealership, I would ask the owner for maintenance receipts to show what work has been done to the car during their ownership. Look for oil change receipts. If oil has been changed regularly, it is a good chance the motor may well be good for 300K miles. Best to check for rust, as mentioned above. Usually caused by salt added to roads in the winter. Does Maine use salt on your roads??
+1 on swapping in a 1995 2.2 motor. That is what I did to replace the 2.5 motor in my OBW. The 95 model is a direct swap without having to change the Y pipe. Also the 95 motor is non-interference. The 96-99, 2.2 motors became interference motors, so be aware of that too. My auto 99 has the delayed forward tranny engagement problem. Trans-X is the solution. Much written on this forum about the Trans-X tranny fix. Here is the link to the post, that I originated back in 08................ FIXED!! Trany delayed forward engagement
Seems unlikely that all the fuel injectors have gone bad. More likely just dirty. Before going back to that shop, and spending $259, I would pull out a spark plug to see what condition it is in . My guess, is that it needs new spark plugs. Spark plug wires may be okay, since you don't mention that the motor is miss-firing. The plugs are easy to remove and replace on a 2.2 motor. Not anymore difficult then removing and replacing a light bulb. Would also recommend adding a can of fuel injector cleaner. Buy the good stuff like Techron, that cost about $7.00 a bottle. Don't buy the cheap stuff costing around $4.00 a bottle. The cheap stuff doesn't help much.
Not having been run in a while prolly won't affect the head gaskets at all. Still a good idea to add Subaru dealer only stop leak product to the cooling system to lessen any leakage of coolant from the head gaskets. Others have said if you know what to look for, after a head gasket change, the corners of the head gaskets will have a different "look," that will indicate that the head gaskets have been changed. I don't know what that "look" will be, but someone on this forum will be able to tell you.
My 99 Outback developed a pin hole leak in the medal tubing that connects at the bottom of the condenser. The leak was just above where it threads into the condenser. Rather difficult to see, as it is at the very bottom of the condenser on passenger side of the car. Subieborder, since you had a leak additive put in your system, you should see leak detector stains at the fitting, if yours is leaking there.
All Subies are full time all wheel drive. There is no adjustable traction control system. On some Subies, you can insert a fuse in a special fuse holder to have the car be in front wheel drive mode only. This is really designed to be used when having a flat tire. The all wheel drive system need all four tires to be the same size. A space saving spare is a smaller tire. Not financially practical to swap out an auto for a stick shift. Far better off buying a stick shift model to begin with, if that is what you want. Subies are super reliable, and excellent in the snow.
Your post reminds me of the old days, when cars had R-12 systems. Then R-12 was discontinued, so systems were converted over to R-134A. All the conversion talk then was the new R-134A refrigerant molecule was smaller then the R-12 molecule. As a result, shops were selling the need to change all rubber A/C hoses to new advanced hoses that would not leak refrigerant. Well best I could figure out, the hose change talk was mostly BS. I converted many a system over to R-134A with insignificant hose leak, that I could determine. Seems like changing out the dryer is still part of that same BS talk. Sure the dryer may pick up a tiny bit of moisture from the atmosphere, but not that much during a hose swap out. It is not like atmospheric gas, and moisture is rushing into the A/C system, just because the system has been evacuated. I opened up my system a few years back to replace a metal hose that had developed a pin hole leak. I replaced the metal hose, and O rings, then simply charged up the system with 2 cans of R-134. My system still pumps out really cold air with no system issues. Conclusion.......replacing the dryer is not necessary.
One thing you may want to check into, is to google "hydraulic hose fabrication." Having a shop make a couple of custom made hoses will cost you far less then $250. There may even be a small fabricator near where you live, that will do a nice job for you. Usually a fabricator is located in a small industrial park, and sells their service to manufacturing plants having hydraulic equipment needing hose replacement. Also, heavy duty truck repair shops need hydraulic hose, so calling one of those shops may be able to refer you to a fabricator.
Having bought my 99 OBW with 148K on the odometer, and now 8 years later, I have 224K on the odometer. You are so correct in that I have had to replace all four struts, ball joints, tie rods, wheel bearing, half shafts, and head gaskets during my ownership. It is just the typical repair stuff you are going to get on a car over 10 years old with a lot of miles on the odometer. So, expect these repairs on any older Subie, and really any other older car, no matter what make. Don't get me wrong, I still love my Subie, it is one heck of a car.
Guess I am confused, as to why the owner is selling cars that either had major engine work, or motor replaced?? Subarus seldom need major engine work, or engine replacement unless they were wrecked, or poorly maintained, usually to the point of running out of oil, which will destroy the motor. If me, I would look for other sources for a good used Forester. Are you sure this company has a good reputation for selling quality cars at market price??
I fully agree with Matt. It makes no sense to spend really good money for a car with a rebuilt title. You have no idea how bad the car was after being totaled. Perhaps even the uni-body has been bent. I am guessing the engine work was necessary after motor was damaged from a traffic accident. You have no idea if this car was rebuilt to meet safe car standards. My best advise is to only buy this car on the cheap, for around $3000, or less. Please don't let your emotions for this pretty car sway you to spend too much for something with a very questionable past.
Tire looks like a studded snow tire. Snow tires are not made to take any kind of heat. So, maybe that has something to do with what appears to be steel belt wires poking out of the tread. Looks like plenty of tread on the tire, maybe take it back where you bought it, to see if any warranty remains on the tire. I sure would not drive on that tire, but perhaps, since it appears to be a snow tire, you no longer have the tire on your car.
My 98 OBW has power brakes, but the "power" seems gone. Pushing on the pedal feels like standard old brakes, on cars that I have owned long ago. The brakes work just fine, just have to really press down on the pedal to stop. I am thinking the power brake booster has gone bad. I don't detect any vacuum leaks anywhere. Anyone ever have the same problem, and if so, how did you fix it??
A/C Compressor
Rooster2 replied to ukroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If replacing the compressor, then yes, add some PAG. I can't remember how much, maybe 2 ounces, but others will know. -
A/C Compressor
Thanks, that was what I remembered, but I am getting old, so my memory plays tricks on me.
