Rooster2
11
Everything posted by Rooster2
I had the resonator break on both of my Oubacks. I took to my local family owned muffler shop, where I had them cut out the resonator, and replace with a piece of straight pipe, that they welded in. Surprisingly, both cars are no louder then with a good resonator. I don't know why Subaru bothers installing a resonator. It is not needed. Cost was cheap to repair this way.
Yes, my OBW has been doing that with the evap code. Pretty sure it is my gas fill pipe causing the problem. Recently removed it, sealed the rust holes best I could, only to have the CEL come on two weeks later, but the CEL turned itself off a few days back. However, I wouldn't be surprised if it reappeared.
Good advise, also check the oil level on the dip stick, make sure the oil level is full. You don't say what was repaired, but to be on the safe side, check as much wiring and vacuum hose connectors that you can that are under the hood. Even check to see that the battery connectors are tight. Stuff in a body shop gets disconnected, and maybe not reconnected properly. I have had that happen in the past.
There is a drain plug on the auto tranny, so it is just like draining and changing oil. If and when you change the A/T fluid, do so 3 times, to get a good swap out of fluids, as only about half of the ATF can be changed during a drain. There will also be an external filter on the automatic tranny, so change that out too. Hope you enjoy your new Subie!!
Then I recommend the JB Weld approach. It is an epoxy putty in one tube, a hardner agent in another tube. Kit cost about $6.00 It is easy & quick to apply. Finished area doesn't need to look pretty, as it is out of sight on the muffler. You just need to let the product set up and dry, so don't drive for several hours, or best to let it dry over night without driving to get the patch material good and hard. Years back, I applied to a small hole on an exhaust pipe. The JB weld held up for years, never did leak there again. The stuff is amazing.
$400 is a decent price. I hope all goes well in the transplant. As I mentioned before, I recall the mounting bracket for the A/C compressor needs to be moved from the 2.5 to the 2.2 motor. It is no big deal, but the shop needs to know that. The shop also does not need to discharge the A/C system. Just pull the compressor off to the side, then rebolt to the replacement 2.2 motor.
If you have one of those family owned muffler shop in your area that does the cut, bend, weld, approach to exhaust repair go there. Where I live, the store is called "Ralph's Muffler Shop to give you an idea of what the shop may be called. Repairs at a shop like this are around $50. Avoid the chain shops like Midas, Car-X, and the dealer, to avoid a huge repair bill. Hope you find one at a J-yard in good shape. You need to find out exactly what needs to be replaced...........the muffler or the pipe? If the crack is not too bad, you could possibly clean the area and patch with JB Weld. This will hold for a while until the weather warms up to make for a permanent repair. Just be sure to let the JB Weld harden up over several hours before driving the car.
I like Advance Auto Parts on line store. I buy their store brand ceramic pads.There is always a discount code available to take 20%-25% off the cost. If a store is nearby, you can buy on line, then stop by and pick up at the store, and get on-line pricing. Not to belabor the point, but, fyi.......correct spelling is "brakes", not "breaks."
Is your check engine light on? A bad 02 sensor, will definitely turn on the check engine light. It could also be a bad knock sensor. How long since spark plug and plug wires been changed?
- 14 replies
- Bad mileage
- 1999
(and 2 more)
Tagged with:
My testimonial...........when I had a 2.2 from a 1995 transplanted into my 1998 with a 2.5, my trusted mechanic had never heard of doing this. He has spent a life time as a mechanic, owning his own shop, specializing in working on foreign cars. I delivered the 2.2 motor to his shop, and said "put this motor in, it will be fit, and be "plug and play.".............and so he did it, with no issues, except maybe a bracket needed to be moved from the 2.5 to the 2.2 to mount the A/C compressor. On my return to pick up the car, he was installing in a customer's car a 2.2 in a 1997 OBW that had a bad 2.5. I think my mechanic learned a thing or two.
