Rooster2
11
Everything posted by Rooster2
You could still use the donut if need be. Just put the donut on the rear axle, and insert a fuse into the FWD fuse holder under the hood. Inserting the fuse, changes the car to front wheel drive only. Once tire is repaired, and all 4 tires are the same size again, then pull the fuse to have all wheel drive operational again.
I heard somewhere that the phase 1, 2.5 motor's HG problem stems from the design, in that the pistons protrude a tiny bit above the block. This necessitated a thicker HG, but in time they leak. Don't know how true this is. My 99 OBW blew its HG at 187K. I caught it early before it over heated much. I had the HGs replaced at a dealer, and things have been fine for the last 20K miles. Can anyone collaborate that the HG problem is because of the piston rising out of the block??
It is simple and easy to take your car to an auto parts store like Advance Auto Parts or AutoZone Auto Parts. Those two stores, and prolly more will pull the Check Engine Light (CEL) code if it is lit up on the dashboard. They pull the code out in their parking lot at no charge. This takes about 5 minutes. The guy will read the code, and tell you what problem needs to be addressed. Ask what the code number(s) are, so you can report back to this forum with the code number(s) if need be. More then likely the code will refer to the fuel evaporation system, if so a new gas cap is needed. Cost of one is less then $10, plus they will remove the CEL light from your dashboard. A replacement cap won't have a tether strap like the one that came with the car, but the cap will work just fine. I fixed my wife's Subie is this manner.
I too, recommend installing a used hub. I went through 2 bearing changes because my hub was bad, finally wised up and installed a used hub from a wrecking yard. Problem solved. 10K miles later used hub is still working great. I won't ever mess around trying to replace wheel bearings.........just a nasty job. Used hub is the better way to go.
The 2.2 motor in a 92 is not known as an engine that blows head gaskets. However, I had a 91 with the same motor, and it did blow a head gasket. The bigger concern is how much, and how often was the motor over heated with the bad head gasket? If done a lot, then there is greater chance of motor damage, to the point that the motor may need to be replaced. $250 is a fair price under the circumstances, depending on the condition of the car. You need to see the car to see how bad the tree damage is.
An easy way to stretch the plain old green antifreeze another 2 years is to add a container of water pump lubricant additive each Fall to the cooling system, after the first two years. The additive replaces the anti-rust property of the plain old green antifreeze, which wears out over time. My dad, who owned a gas station, taught me this trick some 40+ years ago. Sure saves time, and beats the mess of changing antifreeze every 2 years.
When you drain and fill, you are only able to drain and refill half of the ATF in the tranny. The other half is in the torque converter, and won't drain out. Your '03 has gone 95K miles on ordinary ATF, so switching now to synthetic is not necessary or that desirable. I drain and fill 3 times with short drives between ATF changes, using Walmart brand ATF with no problems. To me ATF is a generic product. I have never heard of anyone ever having trouble cause by any brand of ATF. It is only when the ATF is not changed after 100K+ miles that it gets old and burnt to cause difficulties.
I suspect that the air filter box is not secure..............particularly if the motor was running well immediately before installing the new air filter...................... Check to see that the filter is seated properly, and that the lid seats properly, then it is important that all the closure clips are snapped down properly. Hope this helps!
Agree with your buddy about buying tires that are thicker, particularly in the side walls. At a tire store, take your hand and flex tire sidewalls. The cheaper the tire, the thinner and more flexible the side wall. This also prolly holds true for the tread area as well. After flexing a few tires, you will get a good idea of what is good, and what is not so good.
Good thing little, if any, water got sucked into the motor through the air intake to cause cylinder hydra-lock. Well, with all that moisture frozen, that helps to minimize corrosion at wiring connectors. Like others have said, change all fluids that could have been contaminated with water. I would pull out the entire interior, dry and clean all floor wiring connectors, and wash the floor carpeting, and wipe out the metal floor. Otherwise, the carpet could start smelling like a creek bottom when the weather warms up. Prolly a good idea to use a hair dryer on anything that looks wet, and leave a box fan turned on low for several days to dry out the interior. Keep us posted on your progress. If your son is around, have him do most of the work. He will learn his lesson, that when he screws up, it is his responsibility to help fix the problem.
