Rooster2
11
Everything posted by Rooster2
Update.........upon further investigation, I did see where some sticky soda residue was around the HVAC buttons. I can thank my daughter for that. I cleaned the buttons off well with Windex, and wiped off with a paper towell, but air output is still only through dash vents. In the past I have gotten the Windex to work well, but not today. I had a similar problem with my 98 OBW, and fixed that with a replacement HVAC dashboard controller from a wrecking yard. Maybe I need to do that again. I spotted one at a local pull-a-part recently, so I will snag that one. The mode door actuator sounds difficult to reach on top of the heater box. I would prefer not to replace the unit, without first seeing if a new dashboard controller fixes the problem. Thanks 86Bratman for the offer of the picture. I will get back to you, if and when I need a picture. Thanks guys.....................Larry (Rooster2)
I too suspect this is a wiring problem, but maybe best to replace the bulb to eliminate that from what could be giving you trouble. Possible socket broblem..............Look very closely at the bulb socket and wiring connections to the socket. Look for possible cracks in the plastic socket housing. Check the interior of the socket to see that the spring prongs are making good connection to the bottom of the bulb.
When I swapped out a P/S pump years back, I simply removed and replaced. filled the reservoir with ATF, turned the steering wheel lock to lock multiple times, and the job was done. I sourced the new pump from a yard. It worked great for years. If your simply leaks fluid out, I have read others have replaced the "O" rings to fix the problem. I have not done this, so no comment on how difficult this may be.
Thanks guys, I appreciate hearing the ebay experiences. I have bought and sold cars on Craig's list, and have done well. I have only bought "local" cars, so I could "see" what I was buying, and take to a mechanic for mechanical appraisal. With customary long distance buying on e-bay, I feel uneasy about buying a Pig In A Poke. Just my 2 cents worth.
Occasionally, I will take a curious look at cars up for auction on e-bay. To see if anywhing on this forum had been written on this subject, I did a "search" to read where a guy won the bid on a car. I am curious to hear what others think about buying a car on e-bay........maybe there are some deals to be had, but I am thinking also some heart breaks. Anyone willing to share their experience?? I see that some cars (for a subscription fee) history can be learn through "Auto Check Vehicle History Report." I am guessing that is a competitor to Carfax Reports. Still, I would have concerns about bad car titles, stolen vehicles, flood vehicles, rebuilt cars, without a rebuilt title. Any thoughts??
Tires
Rooster2 replied to monk50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Hard to beat Michelin. Their entire line is quality throughout. They cost some extra $$$, but well worth it, if you plan on keeping the car for a long time, and driving many miles. On a per mile basis, their cost/mile becomes very reasonable. -
I have never heard of a Tribeca being lifted, but I bet someone has tried it. From my Legacy experience, you can easily gain about an extra inch of ground clearance by adding tires one size larger then what came stock, without rubbing something on the body or suspension. From a size stand point, a Tribeca is pretty big for light trail driving. If you encounter large sharp stones, the Tribeca's oil pan and tranny pan could get punctured.
You have already thought out much of the pros and cons on each car. From there, it is really a matter of personal taste of which one fits your needs best. There is prolly a fincancial consideration, of how you would come out selling the WRX to buy the Legacy. Would you loose much money in the transaction??
+1, don't know how many times I have cleaned sticky Coke residue form HVAC buttons. My wife swears she doesn't spill Coke, but I know better. Cleaning with Windex and a paper towell works good. I wouldn't be surprised that your cup holder mechanism is sticky as well. If so, it is easy to remove, clean, and re-install.
When I replaced the motor in my 98 OBW, I never gave JDM serious consideration. Prices seemed high, motor would have to be shipped some distance, and no one local to deal with if I encountered problems with a guarantee. Just none of those thoughts made any sense to do business with them. So, I bought a '95, 2.2 motor from a local wrecking yard that I trust, and had an independent repair shop install the engine. I got lucky, and fortunate to have gotten a good motor for $400. I also knew if I had trouble with the new engine, that the wrecking yard would replace the motor at no charge within 90 days.
I remember what you wrote about the parking brake being left on as a source of warped rotors in the rear, however, most of the braking of any car is with the front brakes, so I suspect the front rotors are the ones causing the problems. Whenever I have had warped rotors, it always felt like the pulsating sensation was coming from the front of the car, and the sensation being transmitted through the brake pedal, and even felt throught the steering wheel. Replacing the fronts usually fixed the problem. After thinking about this, it may be better to replace the front rotors first.
Did your cleaning include removing both battery cables, then clean the battery posts and inside the cable post connector? There is a wire brush tool designed to clean both the post and cable connectorl, but I am guessing you already have this handy tool. If the cleaning work doesn't fix the problem, then I would suspect a bad alternator.
