Everything posted by Rooster2
91 subaru legacy sport
Rooster2 replied to tripletech263's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSuggest you add a "stop leak" additive to your motor oil. The additive softens and swells old seals. My experience is that the various brands of additives will help a good deal, but not totally stop leaks.
96 legacy outback (2.5) rear windshield broken - replace gate?
Rooster2 replied to Neophyte's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are companies that replace windshields, but unsure if they replace the hatch glass. Prolly worth a call to inquire.
Oil Level Varies on Dipstick - 97 Outback
Rooster2 replied to ZigZag97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am concerned that oil passage ways are clogged up, so oil is not circulating properly. Is it possible that oil was not changed regularily in this car? If so, the old oil turned to a semi-solid crud, and preventing good oil circulation. I would advise removing one of the valve covers to see just how clean the inside of the engine is.
1998 subaru forester
Rooster2 replied to miss81's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have read that a clogged pcv valve can cause a motor to use oil. Checked to see if your is clogged. Maybe easier to just replace it, as they don't cost much. See if that helps.
- G'Day Guys, help needed down under (EJ22)
I have a 95, 2.2 motor like yours. My crank sensor went bad, but gave notice with an engine code, when a check engine light came on. It was difficult removing the old crank sensor. It had rusted itself, and and refused to come out. Even using penetrating oil, and PB Blaster, it refused to back out. I finally broke off the top of the sensor, then had to dig it out piece by piece. Still, as others have written, I think your problem is with the engine timing. The timing belt is not properly lined up on the correct marks. Re-do the timeing belt, and I bet it will start right up.
Road noise 1996 outback?
Rooster2 replied to subcyclist's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy vote is that your tires are creating the noise.
1996 outback no start
Rooster2 replied to notruck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWith 235K miles on the odo, I don't feel that there is a good reason to rebuild that motor. Just too many miles on what has to be a tired engine. Better off installing a lower mile 2.2 motor as a replacement. That is what I did on my wife's 98 OBW. Car runs great on a '95, 2.2 motor.
colder thermostat
Rooster2 replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you simply want to run at a lower temperature, then run without a thermostat. It may not idle well when the motor is cold, but as an off road "mudder," who cares.
Rooster2 replied to notruck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf this 96 has an automatic tranny, then it has the 2.5 motor. If the belt broke, or tensioner locked up, then the valves are damaged, so no compression. That being the case, then I am sorry, but it is bad news. If on the other hand, the 96 has the 2.2 motor with 5 speed, then that motor is non interference, so valves are not damaged. Simply replacing the timing belt with new tensioners will put you back on the road.
Questions about my '13 Legacy 3.6R
Rooster2 replied to leetwolf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRead all the above posts..........I am still thinking it is the tires.
Rooster2 replied to leetwolf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell this may be too easy a solution............is there a chance one of your tires is just a little low on air? If so, that extra resistance caused by a slightly low tire, can and does cause drift. Check tire pressure, make sure it matches Subie recommendations. On my 99 OBW, I simply put 37 psi in all four tires. Seems to work okay. Rides a little firmer, but I like it that way.
Longer lasting seats for 99 OBW
Rooster2 replied to gravitate's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI find the same thing in Indiana.....driver's seat is worn out, especially the foam bolster portion of the seat closest to the driver's door. I have heard that the foam from the front passenger seat can be installed in the driver's seat. The passenger seats are always in much better condition in a wrecking yard. Guess the driver's seat is used maybe 75% more then the passenger seat.
Rooster2 replied to gravitate's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a 99 OBW with the same problem, crappy seats. I found leather seats from a "limited" model, installed them, only to realize the driver's seat had bad foam. Latest I have done, is use foam from a "00 cloth GT Leggie seat, and use that to replace the crushed out foam in the original 99 cloth seat. This seems to work pretty well. It is not that big a deal to unbolt a seat, remove seat from the car, then disassemble seat cushion to install replacement foam. The foam for the seat is pretty sophisticated in design and shape, so you need to get foam from a Subie seat, or a replacement seat from a Subaru. Not hard to swap in new foam and tie off with nylon cable ties to replace the hog loops.
Should I Replace the Radiator?
Rooster2 replied to manchuscout's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA couple of years back, I replaced the radiator in my 98 OBW. Cost about $100, bought it on line. Easy to replace. I think I removed the grill to get room to work. I, too, am not in favor of trying to fix a head gasket with an additive. I have yet to hear of a head gasket repair with an additive to a Subie that ever worked. I read that the 2.5 motor in 96-99 Subies, have pistons that ever so slightly raise above the block at TDC, so Subaru used extra thick head gaskets. This weakness eventually leads to a bad head gasket, where exhaust gas enters the cooling system leading to over heating. Strangely, the HGs never break so coolant contaminates the oil. Both my 98 and 99 Outbacks blew their head gaskets, one at 155K miles, the other at 195K miles. So, I know all about being a member of the "blown head gasket fraternity."
Pulling my hair out!
Rooster2 replied to MizzJesi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAgree, blower fan is a separate issue. When my blower fan quit, I went to replace it, and found old leaves and crud had washed down from the windshield to clog up the fan. Once I cleaned out the mess, the fan worked good as new. You would think the fuse would have blown, but no, the fuse was still good. Remove glove box to give access to the blower motor. Really pretty easy to work on.
Rooster2 replied to MizzJesi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy money would be on bad head gaskets. I had a 91 that did that, sometimes over heat, sometimes not. It had a mind of its own. Replaced the HGs fixed the problem.
Swaping out trunk panels in outback wagon.
Rooster2 replied to gravitate's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI own a 99 OBW now, previously drove a 91 Leggie wagon, so I am familiar with both. The cars are similar in size, but I doubt if the panels are interchangeable. Guess you could buy the 90-94 panels from a u-pull wrecking yard on the cheap, and see what you could swap in. Maybe with some cutting and fitting you may get something to fit, but I doubt that it would look good.
Are they still having issues with 2.5 head gaskets needing replacing ?
Rooster2 replied to subie94's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf work was done at a dealership, a print out of work/service should be available from the dealership. Just call and ask for it.
05 Forester Radiator probelm
Rooster2 replied to naldo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnless the water is leaking out so that you can see water on the pavement under the Forester, then the water must be going out the tail pipe via bad head gasket. Also, check your oil level to see if water has contaminated the oil.
A/C Yes or No?
Rooster2 replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wish the AC in my legacy worked - heat/humidity are not my friend at all - but I cant afford to get it fixed - it is still an R12 system so there would have to be some necessary changes made before it could be operational again. I have converted a number of cars to operate from R-12 to R-134. Simply vac out what is left of R-12, then add R-134. All the talk years back about changing A/C components wasn't exactly true. Sure those changes would make R-134 work better, but I have gotten good results, just swapping in R-134, without doing any of the changes.
Head gasket blown?
Rooster2 replied to twister5voy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYea, I agree that you need to redo the head gaskets. You can make this a dui job. Suggest loosening the engine mounts on side you are working on, then jack up the motor to give easier access to the side of the motor. Entirely clean off old gasket material to permit a good seal with new HG. Retorque head bolts. Use Subaru made HGs.
99 OBW Driver seat cushion swap out
Rooster2 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks Grossgary. I have a buddy coming over Monday night, who knows what he is doing with the hog ring pliers. He redid my wife's leather OBW driver seat a couple of years back. Between either restuffing my leather driver's seat, or moving the cushions over from an 00 Leggie GT seat, I hope to get a seat that is comfortable to sit on while driving. Thanks for your advise.
Knocking in 98 Outback
Rooster2 replied to 808Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAgree, if thicker oil quiets the motor, then it is rod knock. Guess you could replace the rod bearings, but with 177K miles on the motor, it would be better to replace with a known good motor. My 98 OBW lives happily with a 95, 2.2 motor.
going to buy a new impreza tomorrow head gaskets?
Rooster2 replied to auto2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAba...........you are correct. I checked Kia specs on line. The 12 model was 6 speed auto, not CVT.
