Rooster2
11
Everything posted by Rooster2
Yea, I wrote the original post on using Trans-X. At the time, several years back, I knew a guy who was kind of a dealer for Amsoil, so I bought some. I have since come to the opinion that Amsoil is not anything special. Since then, I have been using Walmart brand ATF with no complaints. I would not start using Trans-X, unless you are experiencing forward gear engagement problems. I don't know that the expensive synthetics like Mobil-1 etc. are all that much better. It is more important to have good clean tranny fluid in your tranny then anything else. Be aware that your 99 has an external tranny fluid filter. It looks exactly like an oil filter in shape and size, but is different internally. Don't try using an oil fliter. Filter cost is about $35.00 for a new one. It is right next to the tranny pan. Don't bother dropping the pan to change the internal screen. They just don't clog up. Ask me if you need further advise on how to change the ATF. I have experience doing this. Regards, Rooster2
Good advise here. my instinct says to replace the thermostat with a good one, either from Subaru, or the most expensive after market from a parts store, or on line. Cheapie thermostats don't work well in Subarus. My temp guage when fully warm is just slightly below the middle mark. As said, if your coolant level is low, then your heater will struggle to put out hot air. I would be inclined to peal back the duct tape, and see what is going on behind that tape. Have a roll of duct tape available in case the tape there replaces broken plastic.
Very nice looking car. Looks new. I have a 99, but not that clean or nice. Your's is the Limited, so you have the comfy heated leather seats. Be aware that your car's transmisson is a candidate for "delayed forward engagement." All the 99 & 00 models can have the problem. It is easily solveable with Trans-X. Much written here about using that product. My auto tranny continues to drive on using Trans-X.
If it were me, I would go to a wrecking yard, and pull a replacement pump, then swap it in for the one that is giving you trouble. WY sourced pumps don't cost much. Long ago, I replaced one on a 91 Leggie that broke. Pretty easy to swap out. Replacement pump worked great. That was a lot easier then trying to repair a pump that I didn't know what was wrong with it.
If you can find a cut, bend, weld muffler shop, they should be able to fix your exhaust for a lot less then $600. Usually they are a family owned muffler shop, not your Midas, Car-X chain store shops. Both my OBWs had the pipe break at the resonator. My shop torched out the rusted pipe, welded in a new pipe, and I was out the door for about $45. Suggest you look into it.
For starters, what is a 2006 spec B? That is a new one on me. In my experience, "jumping" a really dead battery takes time. I have had to keep the jumper cables on a dead battery a good 5 minutes, before the dead battery receives enough juice to be able to turn the starter. You may not have waited long enough. Also...........you could have prolly turned off the honking horn using the fob, as that sounds like an alarm function. With the new battery, are you sure it was charged up? Usually a new battery is sold fully charged, when purchased new, but not necessarily. Even a new battery can be bad. If new battery has removable cell caps, remove the caps to see if battery is full of water. If me, I would turn on the head lights to see if they work. If not, then I would assume the new battery is dead, then use a battery charger, or try a jump start again. Just give the jump start some time to charge up the dead battery. I would be surprised if a fuse is blown. Sounds like a battery problem only.
Timing Belt
Rooster2 replied to Reggie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
My experience in buying a TB, water pump, and pullies from ebay has been good, at a good price. Prolly only a 60K mile belt, but for money spent it is a good value. -
I think all Subies went to obd2 starting in 1995. Ball joints and tie rod ends wear out just like on any other car. Originals should last 150K miles. Easy to replace. Since you have good mechanical experience, you won't find anything unusual. The boots on ends of the half shaft wear out eventually. Nothing difficult to swap out a half shaft. Much written in the archives of this forum under "search" on how to do this job any all other jobs.
The 2.2 motors were in Subarus throughout the 90's only. Most were non interference motors, except the ones sold in cars in roughly the 97-99 time frame. The 2.2 was in both the Impreza and Legacy lines. Same motor in both. Like others have said, motor is easy to work on to replace fan belts, starter, and alternator. All components last a good long time, with all parts readily available. Spark plugs rather easily replaced on 2.2 motor, but difficult on the 2.5 motor, as there is limited space to work with the wheel wells in the way. For a 4 cylinder, all Subaru boxer style motors are exceptionally smooth running at any RPM, compared to in-line 4 style motors. Notice this when you test drive one.
If you learn for sure that the heater core is leaking, you could add some "stop leak" to the cooling system. It could fix the problem. Just don't use more then manufacturer recommends, or you could gum up the cooling system, or plug up the heater core. If your heater core is the leaking culprit, you don't have anything to loose.
- 4 replies
- Antifreeze
- fogging
(and 3 more)
Tagged with:
If by universal, you mean one where you splice wires from old one to new one, then I have to say that in my experience I have never had one last very long. Going after market is good, if no wires need to be spliced.
- 4 replies
- O2 sensors
- fuel trim system
(and 1 more)
Tagged with:
