Rooster2
11
Everything posted by Rooster2
I have both a 98 and 99 Outbacks. Both drip some oil. Like you, more of a nuisance then a problem. I use 10W-40W oil in the winter, 20W-50W in the summer. It is a little thicker, so drips less. There are also additives that can be added to the oil to slow down leaks, which help. The result, is prolly cut my oil drips in half. Sure, you could spend a ton of money fixing the leaks with new gaskets, but with cars this old, it hardly seems like a good way to spend money. Just IMHO.
Like others have posted, the price is way too high. Sounds like what a car dealer would charge. So happens that I own a 99 OBW. I have had it for the past 5 years. Major concern is always head gaskets. Some HGs last a long time, others don't, but eventually all will go bad. My motor lasted to 190K miles, before blowing it's original head gaskets. Problem always presents itself as an over heating engine problem. It can leave you stranded on the side of the road, and cost around $2,000 to have the HGs replaced. Continued driving when motor is over heating will ruin the motor. Other issue is a transmission problem. Tranny doesn't break, but develops "delayed forward engagement," when shifted from R to D, tranny is lazy about shifting into D. It is fixable with an additive to the tranny fluid. Other then those two issues, it is a fine car.
Last year I had a used '95, 2.2 installed in my 98 OBW, after wife cooked the original 2.5 that came with the car. The shop installed the 2.2 with no knock sensor issue, so I guess it is a simple plug and play. Suggest you replace the knock sensor, be careful not to tighten the bolt very tight, or you will crack the plastic casing around the knock sensor.
From how you described the car, it sounds like it has some good life left in it. A '93 would have the very dependable 2.2 motor in it. Yes, there is prolly a good chance that it needs the timing belt replaced, but not to worry a lot, because that 2.2 motor is non interference. Breaking the timing belt just stops the motor without causing valve damage. Just replace the TB, and your good to go again. Good to have you on this forum. Good luck with your "new" 93........Rooster2
It sound like you may be over tightening the worms screw clamps, if you find them cutting into the rubber. I have never had trouble with this style clamp. I have just tightened up the clamp snugly. I could always tighten more, but then the clamp starts cutting into the rubber. No need to tighten that much.
Not long ago, I took a fried 2.5 motor to a wrecking yard to scrap. Was amazed that a young skinny wrecking yard worker picked up the motor from the tail gate of my OBW, and moved it over to the bucket on a front end loader all by himself. I don't know the weight of a 2.5, but something that I am unwilling to try or do.
I am sure that you will not have any problem. On my 99 OBW, I went from 205/70/15 to 215/70/15 with no problem. Your Forester will sit prolly just a tad taller then before. It is important to know that all four of your tires HAVE to be the same size, so no mixing with your current tires. Otherwise, you would be causing trouble with your AWD.
I found some nice leather seats from a 97 OBW, that were in a wrecking yard. Only 5 bolts secure the seats to the floor, so it is easy to swap seats in. From my experience in removing the seats from the car, I would recommend either wrapping the bolt hole tabs with duct tape, or wrapping with a rag, when removing through the door opening. Otherwise, it is very easy for the tabs to scratch the paint on the door openings, as the seat passes through. I learned this the hard way by needlessly scraping my door openings. As mentioned by others, lots of seats will fit your car from other Subarus, but the seat buckle from new seat may not latch the tongue from your existing seat belt system. The solution is to swap out the buckle from your old seat to the new seat. They very easily bolt on. This is what I encountered when installing 97 OBW seats into my 99 OBW. If you can find them, Subaru leather seats are much more comfortable then the standard cloth seats. Many of the leathers are heated seats, so that feature can be added to your car. I paid $75 for a pair of front leather seats in good condition to give you an idea of cost, though I may have gotten a good deal.
Many wrecking yards use United Parcel Service (UPS) to ship parts. Ask a wrecking yard if a tranny can be shipped via UPS. One strong delivery guy should be able to carry the tranny to your front door. Often the yards will use super heavy duty commercial grade cling film to wrap parts for shipping. A used tranny is the way to go, not any sort of a rebuild, which would be too expensive.
What a mess and ugly situation. I hate to hear this happening to anyone. The substance must have been in liquid form to get through the fuel filter. Then, once the gasoline vaporized, the substance turns into a solid. There is just so much of it, I have to think this is sabotage, pure and simple. I am thinking the gas tank and fuel lines are also full of this stuff.
I wrote the original thread years back. Trans-X works great for 99 & OO models Subies that develop the trany delayed forward engagement. With clean ATF, Trans-X will fix the delay within 10 minutes of driving. For me the product lasts a year, then the delay starts to creep back into play. Simply drain the ATF, add a can of Trans-X, and you are good to go for another year. I have done the drain and fill 3 times now, with great results each time. After the second go around, I drained and filled the ATF two times before adding Trans-X, as only about half the ATF can be drained from the tranny at a time. I did not want to leave much old Trans-X in the system.
I, and a friend, did the press out/press in bearing replacement using a Harbor Freight hub tamer. We got the job done with a lot of hard work and cussing, only to have the new bearing go bad in 6 months. Turned out the hub was damaged to begin with, but didn't know that. Suggest having someone press the bearing in to save yourself time and aggravation. I won't press in a bearing again. Hope all goes well.
I had a 95 2.2 swapped into my 98 OBW that came with the 2.5 motor. No need to change the computer. The 2.5 computer works just fine with the 2.2 motor. I bought my 2.2 motor with 150 K miles on odo from a local wreck. Two guys can pick up the motor to move it. I am happy with the results. I agree with other comments that your 2.5 motor has likely been over heated repeatedly in the past, and not worth a rebuild.
